Old 07-30-2022, 02:43 PM   #126
28TudorAZ
28TudorAZ's Avatar
Re: Ford Model A Tudor Modern Twist on a Classic
Damn...that thing is going to be scary on the street.
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085
Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133
28TudorAZ is offline   Reply With Quote
Old 07-30-2022, 09:18 PM   #127
gigamanx
It certainly sounds the part when I don't have much of an exhaust yet. Just for you guys/gals sneak peek of the first engine start.
https://youtu.be/u0ejBlZbd-U
So here's the issue.... I've racked my brain on the Terminator X manual and wiring the harness. The video shows the engine running but only when I have the key in start. As soon as I release to the "On" position, the engine dies.
- There is constant power to the Ignition pin when turning the key to start
- The terminator X harness has the ignition red/white wire going to this ignition pin on the key
- Fuel Pump is working
- There are no error lights on the Terminator X ECU
- I data logged tonight during a start up and it does show the MAP, MAF, and - TPS reading along with REVS.
- ECU power comes straight from the battery terminal
- The ignition key switch "BAT+" terminal comes from the large hot pin on the starter.
The alternator is currently not connected
Fuel pressure is not connected, but also not required says the manual
Oil pressure is not connected, but also not required
Tomorrow I'm going to try connect the alternator +/out to the large starter pin/peg and see if there is some reason the ECU is cutting off because it doesn't see voltage.
Taking suggestions!
SOLVED -- After reviewing every wire I had plugged in I decided to check the relay that wasn't triggering for the fuel pump. The other end of that relay goes to a collective ground wire for both the Terminator X relay and the ignition coil harness. I decided to reground it a little better than the painted door post I was using as a temporary fix. Bam, everything ran! What a rookie
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 09-26-2022, 07:22 PM   #128
gigamanx
How's everyone's summer going!? Just started the car up again for the first time after pulling all the wires through correctly and finishing up some minor paint items. Pedals installed, steering is getting reconnected, and I'll spend the winter working on the gauge panel...
For now, hoping to drive under it's own power here before packing things up for the winter. Looking very official underneath with a finished exhaust!
Decided to get started on understanding interior upholstery so I went and found a gently used Sailrite Fabricator to play with. Serious sewing machine!
Finally, I had to say goodbye to my companion and shop buddy this summer. Left a big hole in my life where she fit nicely.
Old 09-26-2022, 10:03 PM   #129
mongocanfly
mongocanfly's Avatar
Nice looking dash..!!
Its always hard to lose a friend....I sometimes still have a hard time with losing mine..and its been a couple of yrs now
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-10-2022, 09:14 PM   #130
gigamanx
Here she is! First shake down drive video: https://youtu.be/lP9bVRnLvTU
Glass is ordered from the shop. Bled the brakes a few times until they felt solid. Working on issues with seating and steering arrangements at the moment. I am only 5' 10" and keep hitting my knee when I turn. Looks like a 15" wheel isn't going to cut it in this car. Considering building bucket seats so I can get them dialed in perfect for the cabin space. I have not found any seats thin enough at the base to fit.
Old 10-10-2022, 10:24 PM   #131
mongocanfly
Congrats!!!!!!!!!!....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-11-2022, 09:23 AM   #132
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by mongocanfly View Post
congrats!!!!!!!!!!....
x2!!!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-09-2023, 12:54 PM   #133
gigamanx
Wasn't happy with the seats, so why not cut my bucket seats in half and take out a section, weld them together, buy a sewing machine, learn to upholster, buy some foam, sew seat covers....
Old 03-20-2023, 09:03 AM   #134
gigamanx
Hit a road block, but progress has been made every week. Trying to get to a point to be registered so I've been working on mirrors, wipers, lights, and all the electrical. Closing up the rear panels to cover the gas tank and battery.
My road block is the front brakes. A drive around the block will cause them to heat up and "stick" to the rotors. Both rotors seem to do the same thing and they are Wilwoods. I am feeding the front brakes from a single line with a T near the left front. I'm thinking something is happening upstream in the proportioning valve or master cylinder, but not sure how to start troubleshooting. Brakes feel firm and stop fine, but definitely couldn't drive this a mile without overheating the rotors.
Old 03-20-2023, 10:25 AM   #135
mongocanfly
Looks great..!!!..
I'd believe I'd start with the prop valve..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-20-2023, 11:00 AM   #136
Ol Blue K20
looks great..!!!..
I'd believe i'd start with the prop valve..
x2
Dale
Old 03-20-2023, 07:59 PM   #137
gigamanx
Thanks guys. Other place I'm considering starting with is double checking the pin between the booster and master cylinder. I thought I had set the depth, but the pads seem awful close to the rotor. Wondering if I'm restricting the cylinder from returning all the way too. As far as prop valve goes, should I just replace it? There doesn't seem to be much I can adjust or check with that thing. It's one of the generic GM style ones.
Update, I'm a bone head.
I loosened the nuts holding the master cylinder to the booster. Figured if there was a gap problem with the push rod then I just created more gap. That did nothing. I then went forward and undid the bolts holding the brake pedal to the booster. Maybe, I thought, I had tightened the bolts too much and causing friction on the pedal so it couldn't return. Low and behold I had installed the pedal before I put the steering column in. The top of the pedal arm hits the column when it returns. This made the pin for the power booster only be able to return about 80% of it's travel thus... brake drag!
Hoping I'm not celebrating too early, have to take a drive to confirm!
Old 03-22-2023, 06:48 PM   #138
gigamanx
Posting for no reason other than hitting 1,000 posts!! wooo
Old 03-27-2023, 08:45 AM   #139
gigamanx
First drive, first fill up!
Old 03-27-2023, 09:43 AM   #140
joesscamaro
Looks awesome! I'm sure you won't be able to go anywhere without getting asked a million questions.
joesscamaro is offline   Reply With Quote
Old 04-04-2023, 11:08 AM   #141
youngrodder
youngrodder's Avatar
Very cool..Yes, diagnosing brake issues can lead one down a rabbit hole. Glad it was a simple/easy fix.
Looks great. I love the color.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 04-04-2023, 05:00 PM   #142
mongocanfly
very cool X2..!!!!!!
Glad you got the brake issue sorted out..
You have a very cool ride..!!!!..color is spot on
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-23-2023, 01:50 AM   #143
28TudorAZ
28TudorAZ's Avatar
I haven't been on here for a while. Looking great. I am currently working on a doing an LS Swap on a 69 International Scout. You should get the same engine cover I did.
Old 04-24-2023, 08:19 AM   #144
richard2717
Equal opportunity joke ofender
richard2717's Avatar
I see you are in Hershey. I would not recommend coming to OC MD with it during any of the cruises. They have a special event zone now that the cops get to make up their own rules and they will impound you for not having fenders or hood among other things. I think the base cost of impound was $900 last year and the tickets went into the thousands for some. Even if you beat the tickets in court, which most do, you don't get the impound fees back.
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 04-25-2023, 07:27 PM   #145
gigamanx
Wow, thank you, had no idea. I'm almost plated and titled at the moment with a successful PA enhanced inspection a few weeks ago. Mechanic suggested a few tweaks to the front end and brakes to tighten things up. I'm glad he said something because I forgot to tighten some pretty major nuts during assembly! I do plan on moving to Annapolis, MD and worry about the changes in what is allowed down that way. It seems like they only want to see Street Rods on a Sunday at a show.
Old 04-25-2023, 07:29 PM   #146
gigamanx
Very nice cover. I am planning on doing a low profile Holley intake polished, but I had to put money other places to get it driving. I also read something as simple as an intake also means new fuel rails, injectors, throttle body, blah blah lol...I decided to save it for another day.
Old 04-26-2023, 08:16 AM   #147
richard2717
Yea the H20i crowd seems to have ruined the car cruising scene in OC. During the special event zone times they basically make up laws or rules to be able to generate revenue. Some people say they have no issues but I have seen quite a few on the hook.
there are a couple FB groups if you are not already on them.
https://www.facebook.com/groups/1427704967475480
https://www.facebook.com/groups/CruisinOceanCity
Members I have met.
Old 04-27-2023, 12:30 PM   #148
daveshilling
daveshilling's Avatar
Get your Alternate Tinkerings thread started!
daveshilling is offline   Reply With Quote
Old 04-28-2023, 05:32 AM   #149
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
The rod looks awesome! Did you get your brakes figured out? I had a similar issue on my vette and it ended up being the MC push rod was adjusted a little too far out. When the brake fluid warmed up it applied the front calipers and they would lock on. It was the strangest thing.
Ryan
1969 Chevy milk truck
Old 04-28-2023, 07:30 PM   #150
28TudorAZ
28TudorAZ's Avatar
Great idea. Done.
ford tudor sedan ls
