Old 08-11-2022, 02:28 PM   #1
kens65fb
How low can you go ??
How low can you drop the front of a 65 C10 without air bags?
How low, is too low, or what is the minimum clearance for the suspension, on the front.
Any advice
kens65fb is offline   Reply With Quote
Old 08-11-2022, 02:38 PM   #2
SkinnyG
SkinnyG's Avatar
Re: How low can you go ??
My daily-driver '77 C10 (basically same suspension) is 3.25" at the bottom of the front control arms. 3" BellTech spindles, and cut 1-ton coils. Tires taller than 245/60R15 will need the inner fenders altered. I can make it over any speed bumps, but have snagged header collector flanges on occasion.
If you're willing to cut and weld, you could pancake the front crossmember about 1.5" and cut less off the spring - this would ride low but increase ground clearance.
My '61 Apache is 2" pancake, 2" spindles, and sits 5" off the ground. Yes, it's bagged, but when the novelty wears off, I'll go back to cut coils to maintain the ride height.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 08-11-2022, 02:39 PM   #3
SkinnyG
SkinnyG's Avatar
Any part of the vehicle hanging below the rim is dangerous. So.... run taller rims.
Old 08-11-2022, 03:38 PM   #4
forestb
forestb's Avatar
I have a 4 inch drop up front. It will scrape if I go over speed bumps too fast I and have bottomed out my lower a arms going too fast over some dips in the road. When I had a 6 in drop in the rear the axle would bottom out on the frame. I now have a 5.5 in drop in the rear.
forestb is offline   Reply With Quote
Old 08-11-2022, 04:30 PM   #5
kens65fb
Right now I have 2 1/2 drop spindles, 2 inch drop springs., with CPP Tubular Control Arms.
Control arms have been on a few years, drop springs and drop spindles, have about 10 miles driven, since installed, prior to 2 years at paint shop
Truck will come home from painters next week
Tires are 245/45/18
I think that 1 more inch drop would look better.
Old 08-11-2022, 04:54 PM   #6
forestb
forestb's Avatar
Tires are 245/45/18
I agree but you are being really mean by only showing us that much of your truck.
Old 08-11-2022, 06:14 PM   #7
kens65fb
Many more pictures to follow next week !!
Old 08-11-2022, 07:59 PM   #8
kens65fb
I would like to drop the rear a little too, any suggestions.
Right now I have a C notch, 4 inch drop springs, rear shock relocation bracket
with drop shocks, and 1 inch lowering blocks.
Any suggestions ??
Old 08-11-2022, 08:32 PM   #9
SkinnyG
SkinnyG's Avatar
This is how it all starts.
"just one more inch...."
Old 08-11-2022, 09:10 PM   #10
forestb
forestb's Avatar
I would go for a 2 inch block for staters. That’s the easiest and cheapest way to do it and you won’t have to get different shocks.
Old 08-11-2022, 11:29 PM   #11
MT65
I used coilovers on all 4 corners, no issues with speed bumps, stock front spindles on the 86 front end that was installed
MT65 is offline   Reply With Quote
Old 08-12-2022, 10:49 AM   #12
61hawk
61hawk's Avatar
If you're going to lower it that much you might as well put hydraulics on it and paint it with boat level metallic flake.. maybe orange and green. But that's just me.
61hawk is offline   Reply With Quote
Old 08-12-2022, 11:00 AM   #13
forestb
forestb's Avatar
You say that like it is a bad thing.
Old 08-12-2022, 11:48 AM   #14
kens65fb
Thanks for the stupid response.
Old 08-12-2022, 01:18 PM   #15
EricS76
EricS76's Avatar
I think you could go an inch lower in the front. I have 2.5 drop spindles & cut a coil out of the stock springs with 235/75R15’s on my truck and it looks about an inch lower than yours. Probably my old springs are compressed a little more. As for the rear, I went 5 inch drop springs & 2 inch blocks to get it level. No problem with a c-notch.
‘66 Chevy C-10, long bed fleetside, 350, 3 on the tree, 4-7 drop.
'77 chevy C-10 Custom Deluxe, 350, SM465 4 speed, flatbed.
'80 jeep CJ-5.
‘14 Chevy 1500 Z71…
EricS76 is offline   Reply With Quote
Old 08-12-2022, 01:44 PM   #16
theastronaut
theastronaut's Avatar
My old '66 was as low as you can reasonably go up front. On medium bumps the tires would rub the inner fenders and on big bumps the crossmember would bottom out on the ground. It had 215/75-15 tires, drop spindles, and 1.5 coils cut off the stock springs. The bump stop brackets were completely cut off and the shocks were relocated to regain full travel. The rear had a 2" deep pipe notch with relocated shocks and never bottomed out. Any lower would need a step notch and raised bed floor to keep enough travel to keep from bottoming out.
theastronaut is online now   Reply With Quote
Old 08-12-2022, 07:05 PM   #17
AcampoDave
AcampoDave's Avatar
Have you considered getting a tire with a bit more sidewall Ken? A little more side rubber would fill the opening a bit and bring the fender closer to the tire. I'm just saying that you have a mighty nice truck to risk driving it at highway speed with your undercarriage barely above the pavement.
The roads where I live are not good, rolling along with cut bump stops and avoiding obstacles in the name of style may work most of the time, but it's also nice to have a smooth ride and feel at ease behind the wheel. Stuff happens out there.
AcampoDave is offline   Reply With Quote
Old 08-12-2022, 07:32 PM   #18
forestb
forestb's Avatar
You could always put Some weight in the front to lower it down an inch and then see if you start scraping on things. I think if you go any lower you are probably going to start scraping on stuff.
Old 08-17-2022, 06:07 PM   #19
SCOTI
SCOTI's Avatar
The front x-member needs to be minimum 3" off the ground w/4" being better to limit contact.
Aftermarket front 'raised' x-members shine here but add complexity/cost because they need matching arms & the swap to R&P steering.
'Z-ing' the frame is best for a old-school/budget build approach. Combine it w/drop spindles & springs & you can yield close to 7" front drop while keeping the x-member close to 4" off the road. There is still complexity but it comes @ different areas vs requiring different parts.
There's also sectioning (pancaking) a stock front x-member. It fits somewhere in between the above choices & can be an easier solution complexity wise.... but it has compromises.
Having done all three options.... I'd do a frame-Z. Properly done, it yields the same results as an aftermarket x-member while using the tried & true OE chassis set-up.
4/6 dropped trucks drive around w/o issue & work well. Going to that next level of drop is where it get's complicated. The 'Z' would utilize the same proven 4/6 parts combo but get you that much lower. It all comes down to each guys specific needs/wants.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-20-2022, 03:34 PM   #20
short&wide65
For me, the aftermarket front crossmembers correcting the poor factory geometry while converting to rack & pinion is what makes them so attractive. Their only downside is cost.
1965 GMC 910 Short Fleetside. 230 CI 4-speed.
short&wide65 is offline   Reply With Quote
Old 08-20-2022, 03:55 PM   #21
forestb
forestb's Avatar
Based on the photos you took of the truck after it came back from paint in the other thread I think that the height looks Great. What helped reassure me that my truck is a good height is seeing someone else drive it. While I watched. For some reason that made me realize how good it looks. What also helps is bottoming out on stuff. That always keeps me from lowering more.
Old 08-20-2022, 06:20 PM   #22
SCOTI
SCOTI's Avatar
You can tweak the factory stuff to correct the Geometry. Tall BJ's, Caster mod, perf alignment vs stock spec, a new/faster ratio steering box, & lower center of gravity change things completely.
R&P set-up's are nice but again significantly add to the cost/complexity vs whats already there.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-21-2022, 01:12 PM   #23
short&wide65
It would still be just tweaks that make it slightly better than stock so I disagree that it would change things completely.
I should add that I'm setting my truck up for autocross use so handling is paramount to me.
Old 08-23-2022, 09:33 AM   #24
verdell
verdell's Avatar
Very good point here. I switched from a 245-45-18 on the front to a 235-50-18
and it works great.
verdell is offline   Reply With Quote
Old 08-23-2022, 11:10 AM   #25
SCOTI
SCOTI's Avatar
You can disagree but tweaks made to the original 63-87 C10 geometry can change things completely; it just depends on one's definition of 'tweaks'.
There is nothing 'wrong' w/the stock set-up. It's not ideal vs. what's offered under current performance cars/trucks but neither are the aftermarket x-member kits being sold to achieve aggressive drop heights. R&P steering set-ups are an improvement over the original equipment steering box/set-up but only when everything is set-up & dialed in w/o compromise. Otherwise, it's just R&P steering that's easier to adapt to the raised x-member arrangement. A new perf spec steering box would also make a big difference in steering function.
If you're building something for autocross, using a Porterbuilt, GSI, Choppin Block, or Thorbeck Bro's raised x-member style set-up seems like a poor choice vs other more specific options. The aftermarket x-member kits do have updated geometry but again the OG stuff can be tweaked to rival the those offerings.
Autocross would benefit from a No Limit Engineering, Detroit Speed, SpeedTech, Scott's, or something from Roadster Shop (or maybe one of the very recently released to market QA-1 set-ups). These would be more aligned w/purpose built driving w/a nod toward autocross ambitions. They're also an even bigger investment vs. the aftermarket raised x-members.
So.... My question would be what do you consider to be 'just tweaks'?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
