Old 08-17-2022, 11:59 AM   #1
jweb
jweb's Avatar
Ididit Retrofit vs Universal column
What's the difference between the retrofit and universal?
The Retrofit is $150 more and a long wait time.
I will be installing this in a 64 Suburban with No limit rack and pinion and LS swap.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 08-17-2022, 12:14 PM   #2
61hawk
61hawk's Avatar
Re: Ididit Retrofit vs Universal column
Summit Racing has seven in stock.
https://www.summitracing.com/parts/i...rban/year/1964
61hawk is offline   Reply With Quote
Old 08-17-2022, 12:50 PM   #3
jweb
jweb's Avatar
Originally Posted by 61hawk View Post
Nice, looks like I just need to figure out the difference and decide if it's worth it.
Looks like the retro is 2" diameter and 3/4-36 on the lower shaft.
The universal is 2 1/4" diameter and 1" DD shaft. So it may just be a matter of how the 2 1/4" fits against the dash.
Old 08-17-2022, 12:59 PM   #4
jweb
jweb's Avatar
That link is the non tilt version.
Here's the tilt version, also in stock:
https://www.summitracing.com/parts/idt-1140650010
Still about $150 difference from the universal.
Old 08-17-2022, 02:42 PM   #5
MT65
I have used both styles, the universal fit will function with a bit of tweeking, the other will fit easier in the mounts…don’t worry about the end of shaft connection, there are ujoints that will simplify it for you
MT65 is offline   Reply With Quote
Old 08-17-2022, 03:05 PM   #6
jweb
jweb's Avatar
Any details on the tweaking required to make the universal fit?
Just trying to justify the $150 difference
Not worried about the spline vs DD end, I will have to buy u joints either way.
Old 08-17-2022, 06:07 PM   #7
vin63
It's Better With Nitro
vin63's Avatar
I haven't been able to verify this myself, but I've had a couple of people whom I did steering wheel restorations and a couple of others relay to me that the universal column requires using the horn kit with aluminum ring (or other transition kit) to fill the gap between the barrel end of the column and the back of the steering wheel.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-17-2022, 06:24 PM   #8
jweb
jweb's Avatar
Good info, I plan to use a stock steering wheel if I can. Sounds like this plus the fact the 2" diameter will fit better against the dash will make me spend a little more $$.
I had to make a few custom parts to fit the stock wheel of my 51 pickup onto the Ididit column which was a pain. So I think it's worth the extra cost.
Old 08-17-2022, 10:09 PM   #9
MT65
I think vin63 is correct on the ring spacer for one of the tweeks, column diameter was another and if I remember correctly, where the wiring exits the column was another….all doable, just can be frustrating, doing it yourself would just be your time, paying shop rates for this would make the $150 cheap….
Old 08-18-2022, 10:41 PM   #10
61hawk
61hawk's Avatar
I'm using the original wheel, you do need the trim ring.
Old 08-21-2022, 01:24 PM   #11
short&wide65
I'm looking at the same column (also with a No Limit rack) and also want to use my stock wheel. Ididit's website states that "A stock 1960-66 wheel can NOT be used with a 1960-66 ididit column"
Any insight on this?
1965 GMC 910 Short Fleetside.
short&wide65 is offline   Reply With Quote
Old 08-21-2022, 06:58 PM   #12
61hawk
61hawk's Avatar
First thing I did with my retro column was to test fit the steering wheel. It fit without any problem and all I had to do was order the aluminum spacer ring.
