08-24-2022, 11:36 PM | #1 |
Front Lower Shock Mount Destruction
My 72 Balzer K5 has about 6” lift and on the front I am running a dual shock mount kit from Skyjacker… like the setup but for some reason the factory lower spring mounts
Keep breaking (2 broke in last 10 years, and currently I have one more stressed and ready to break). So 2 questions… 1. Does anyone make the factory shock mount for the axle tube? I will need a duplicate of the foxtrot to keep the dual shock kit! 2. If not a factory what else have you replaced them with? Surely I am not the only one that has had this issue… Someday I want to rebuild the entire thing top to bottom but for now 2 kids at home, dogs, wife, chickens, and more are consuming my time…
Confidence is the feeling we have before we fully comprehend the situation |
08-24-2022, 11:43 PM | #2 |
Re: Front Lower Shock Mount Destruction
Oh and I am not opposed to going to a single shock that is built really well and spending money on it as long as I don’t keep breaking the lower tabs off…
Anyone know about these mounting tabs from ruff stuff? They tend to have good heavy parts, but looking at the setup I will have to eliminate the dual shock set up and go to a single, but I could buy a good Resevoir shock or performance shock?
08-25-2022, 04:21 PM | #3 |
Carpe manana
Moved - should not evolve into a WTB post.
08-27-2022, 05:38 PM | #4 |
Most of the dual shock lower mounts just use the stock dual shear lower tabs with a longer bolt and a spacer between the shocks. Adding another tab to the axle on the outside of the addon shock will put both shocks in a double shear mount and make it stronger. Look at places like RuffStuff for mounting tabs to modify.
Edit: No doubt a nice single King or Fox reservoir shock could be better. May require some tuning to get it where you want though. Bummer your post got moved into this place. Re-reading the original post I can see no fishing for people to sell you parts.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 08-28-2022 at 03:45 AM. Reason: Added |
08-28-2022, 08:42 PM | #5 |
https://www.amazon.com/Weld-Front-Lo.../dp/B072YWZD8Y
If you are breaking the mounts, a few thing would contribute. Weak mounts to begin with. Improperly welded. OR wrong shocks either topping or bottoming out. Anyways these mounts are pretty beefy--made out of 1/4 plate. I actually used a pair of these on a Toyota I'm building at the moment Last edited by kwmech; 08-28-2022 at 08:48 PM. |
08-31-2022, 02:39 PM | #6 |
Help us help you by providing some photos of your shock mounts.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
09-01-2022, 12:26 AM | #7 |
Who me?
09-06-2022, 08:38 AM | #8 |
09-20-2022, 02:29 AM | #9 |
The lower mount breaking has to do with the additional shock. It is added on with just a spacer. The add-on outboard shock creates a twisting stress on the lower mount causing it to break. Oddly later GM did the 4x4's lower shock mounts the same way when a quad shock option was ordered. Used the Oem quad brackets on my last 72. What made me think of this thread again is I just came across the extra set of GM quad shock brackets I purchased.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
09-21-2022, 10:51 AM | #10 |
The stock mounts are more than capable of supporting a quad shock set-up if the correct shocks are installed and you're not jumping the vehicle or doing real extreme wheelin'. Got a 30 year old suburban with quads on it and there is no damage to the mounting system
