09-01-2022, 05:03 PM | #1 |
Found a perfect donor
I've been searching everyday for a cheap truck or one being parted out to no avail. A cheap parts truck anyone selling whole still wants $3000 around here and I was never keen on a whole truck I'd likely scrap for a few pieces. For my 66 c10 I want a rear dif from a 71 or 72 to convert to 5 lug and I was considering a square body power steering setup. Today I spied this 71 frame with the 5 lug rear and power steering that I can scoop up this weekend for 800. Only questions I have for the gurus here is will i still need an adapter plate for the steering box? I know the rear trailing arms are valuable if they aren't rotted and if I didn't want to lower my truck id keep the front disc setup but I think that might be easy to sell as well. Let me know what you guys think
09-01-2022, 09:45 PM | #2 |
Re: Found a perfect donor
You will still need an adapter plate to run the power steering gear. Another option is to graft the section from the donor frame into your 66 frame if you don't want to run the adapter plate
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-01-2022, 11:00 PM | #3 |
I didn't think about swapping frame sections. I'll have a few things to consider, one being that normally I like taking the less invasive route especially when it comes to frame surgery. It's not my welding ability that's in question it's the similarities and differences between the two frames. Ideally I'd like a common reference point on both frames to do my measuring from but I dont know if that exists. Another hurdle is finding or fabricating a ps pump mount for my 250.
09-02-2022, 09:50 AM | #4 |
Moderator
Engine brackets:
https://davisspeedequipment.com/prod...62-84-194-250/ http://www.alangrovecomponents.com/C...x_Cylinder.htm
09-02-2022, 07:09 PM | #5 | |
09-02-2022, 07:56 PM | #6 |
But why can't you keep the disc set up AND lower the truck too...just swap in some drop spindles and you're on your way.
09-02-2022, 08:13 PM | #7 |
09-02-2022, 09:19 PM | #8 |
Moderator
On the Alan Grove site go to Technical section and lookup 602L it will download the instructions (pdf). It is not a one bolt attachment.
Here is the link to the instruction page: Lower section on the right - 602L http://www.alangrovecomponents.com/Important_Info.htm
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 09-03-2022 at 06:22 AM. |
09-06-2022, 06:52 PM | #9 | |
