09-02-2022, 09:19 AM | #1 |
Window glass
I found a guy who has a few pieces of window glass w/tracks, and some have metal frames around them. They are the same size as 64-66 glass. What years could these be from with the frames?
09-02-2022, 08:52 PM | #2 |
Re: Window glass
I have a 61 that has a metal frame around the door glass.
09-02-2022, 10:41 PM | #3 |
Re: Window glass
Some 64-66 trucks were optioned with the metal framed glass. A lot of those were medium or heavy duty trucks. The glass is two laminated panes, and they are thicker than the non-framed, single pane safety glass.
That extra thickness is a problem with the aftermarket window weatherstripping made for the non-framed glass being too tight for the 64-66 framed glass. The framed glass was more common in the early 60-63 trucks, but I don't know if the aftermarket weatherstripping that fits the 60-63 framed glass would also fit in the 64-66 doors
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-08-2022, 10:17 PM | #4 |
Re: Window glass
I have a 1961 truck I am working on, I plan to replace both door glass, but keep the factory vent window glass.
Mine has the steel outer on both doors. I am not going to use it because it is too heavy. Trying to shave weight wherever I can. |
