06-12-2002, 07:51 PM | #1 |
Polygraphite or Stock?
I'm shopping for front-end rebuild kits, and I've been given the opportunity to either go with polygraphite or stock rubber.
I've heard that the polygraphite parts can be known to squeak a bit. Is that true? Is it anoying? Right now the only reason to go with stock is that it's about $30 cheaper. Since the polygraphite parts don't deflect (from what I've heard) then are they the better route? Anyone have experience?
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
06-12-2002, 09:46 PM | #2 |
I have poly on my Camaro and I like them. They do squeek a little, but not enough to really bother me.
Just sitting here contemplating contemplation. |
06-13-2002, 03:10 PM | #3 |
I put the poly ones in my Monte Carlo SS last winter. They don't squeak. Be sure to get the special grease (it's almost like glue) and coat everything WELL, and you should be ok. I went with the poly because I don't need the practice of changing them often. I'm in the middle of doing my Chevelle now, but progress is slow because I'm sandblasting and powdercoating all the parts. Hope it will be worth the effort when done.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
06-14-2002, 01:22 PM | #4 |
Not sure what polygraphite is (implies graphite lubricated?), but I have polyurethane everywhere on my 69 C-10 -- sway bars, track bar, rear control arms, cab mounts, and also on my Maxima's sway bars. Some come with a lubricant, but I've also used distributor cam grease and have never heard a squeak from any of them. By the way, the only bushings on my front suspension are for the sway bar. My control arm shafts don't have bushings, but instead are threaded on each end and rotate inside large cap nuts. There are grease seals between the nuts and the shaft. Is the C-20 different?
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
