09-21-2022, 07:27 PM | #1 |
Dougs Complete exhaust LS Swap
Just thought I'd pass along as I hadn't seen anything on the forum but Dougs is making an exhaust system for LS swaps for the trucks now too. Similar to the Holley Blackheart it tucks up. I just ordered it from Summit mainly due to price. Summit has it for $869 right now compared to Holley $1,350 for 3" 304SS system. It does have V bands at the collectors which I'll probably cut off depending how it interfaces the speed engineering headers. Any one else installed this exhaust yet? https://pertronixbrands.com/products...38110459232427 I'll add to my build thread the install when it comes in hopefully this weekend.
67 C10 2wd Stepside (to be fleetside), Factory AC truck, Big Back Window, just got a 6.0/6l90e to jam in it now..... Needed: paint and lots of it. and i'm sure lots more misc. parts. Project 67 short step Build Thread 01 Sierra Crew 6.0 2015 Ford F150 Work gave me truck i really wouldn't buy a ford. |
09-27-2022, 09:25 PM | #2 |
Re: Dougs Complete exhaust LS Swap
Exhaust system showed up today. Started to hang the rear of the system as i need to cut the holes in the crossmember still. Clears the fuel tank and axle and panhard bar nice.
09-27-2022, 09:29 PM | #3 |
Directions are not the greatest so figured I'd post a few pics of some brackets together. Also I have a 67 and my frame only had one of the holes needed on the rear shock cross member and had to drill the other for the bracket.
09-28-2022, 11:52 AM | #4 |
I'm following along out of curiosity as I developed the Hooker Blackheart C10 exhaust system they reverse-engineered their system off of. Hopefully the components of the Blackheart system they purchased to do the copying off of fit our build fixtures really well, or they will have stacked tolerances built into their system. You'll know soon enough I suppose.
09-28-2022, 02:12 PM | #5 |
Looks good, I wouldn't cut the v bands off, I'd add the correct mate to the headers.
Sucks they flat copied the blackheart system though....
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
02-21-2023, 10:02 PM | #6 |
Nice, how did the rest of the system fit? Is it 2.5" or 3" pipe? Thanks!
02-21-2023, 10:38 PM | #7 |
Keep the board in the loop on fitment.
Lots of variables, like your rear fuel tank that make the pre-bent systems difficult. Looks like it has a removable section for transmission removal. Either that or it was made shorter to cut shipping costs? The glass half empty view I guess. When I had my exhaust system installed the only thing I was crystal clear about was the transmission has to be able to come out without cutting the exhaust. When my stall converter arrived guess what? Transmission would not come out without cutting up the new exhaust. Cheers. |
