10-03-2022, 10:03 PM | #76 |
Re: 60-66 Trailer made from a 60-66 bed
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-04-2022, 02:50 PM | #77 |
I like the twin tailgate idea. It would also be nice if you were loading truck bed with trailer attached so you could just load through the trailer with small ramps or something.
10-07-2022, 09:00 PM | #78 |
Yes, I do that too.. and when both gates are down there's 12 feet of platform.. This thing is great, It's like having another work truck..
03-16-2024, 03:53 PM | #79 |
But Found Her 25yrs Later!
Old thread, but the one having the most posts
. How do these trail? I have a utility trailer that you have to load correctly or it'll really start whipping around.
03-17-2024, 04:05 PM | #80 |
Pretty much any single axle is going to be more sensitive to weight distribution but we have built 3 truck bed trailers (no 60-66 unfortunately or would that be fortunately?) and they pull pretty well and seem less prone to wagging than my 5x8 utility trailer but I think we always had longer tongue's on them. We would cut the truck frame right behind the middle cab mounts and V the frame in right infront of the rear cab mount.
03-18-2024, 09:33 PM | #81 |
Mine pulls really well, but I do take care to have a somewhat ideal weight distribution. I haven't had any issues with trailer sway, and that could be because it's built similar to how 350TacoZilla would build them. The original truck frame and 8 foot bed in my case provides a decent weight distribution loaded or unloaded from what I've experienced
06-05-2024, 11:00 PM | #82 | |
Great idea so you don't have to always chock the wheels.
06-06-2024, 12:00 AM | #83 |
How hard is it to bend the frame in?
Does it need to be heated with a torch?
06-06-2024, 06:00 PM | #84 |
So we have heated just the top and bottom of the C channel and then folded them in using a pipe for leverage at the front and one we cut small notches in top and bottom and folded in then welded the seam up. I keep thinking all of them had a small flat bar crossmember welded across the top right at the bend point also to reinforce the area.
06-06-2024, 08:47 PM | #85 |
Perfect! Thanks!
06-19-2024, 08:29 PM | #86 |
How much do you think these could carry?
C10 = 1/2 ton?
06-25-2024, 03:09 AM | #87 |
Probably the safe way to figure would be to go off what the axle and springs are rated for. If you put a trailer axle under it with brakes the frame and suspension would have no problems with more weight, the functional trailer brakes is a big part of what I would feel safe hauling. We mainly used ours for landfill runs, home improvement store pickups, mowers etc like you would a small 5x8 trailer like I currently have so maybe 1ton upper limit? Though I'm sure there were a few times where we were pushing way past that with firewood in both the pickup and the trailer stacked up to the top of 2ft sides on beds.
06-25-2024, 11:50 PM | #88 |
Thanks.
Yeah, mine will rarely be taken on the road. It'll just be used around my property. Firewood and dirt. I was just curious. Mine is a C20 with a 73+ 14-bolt Rearend.
