Old 10-11-2022, 08:30 PM   #226
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Re: '57 Stepside, Big Window Project
Originally Posted by FleetsideBill View Post
Check your wiring to the ignition switch the coils and injectors need power during cranking, I made this mistake myself
Thanks!
That's what I'm having the shop do...
/Ken
87Lowrider is offline   Reply With Quote
Old 03-10-2024, 07:10 AM   #227
PowerdbyChevy79
PowerdbyChevy79's Avatar
Loving this build.. any updates??
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 11-28-2024, 11:07 PM   #228
87Lowrider
87Lowrider's Avatar
Finally got the finished version (they're never finished are they?) on the road.
Here's a few pictures for ya.
Old 11-29-2024, 12:17 AM   #229
dsraven
Sweet.
Now for the next tweak......never done. Haha.
dsraven is online now   Reply With Quote
Old 11-29-2024, 10:10 AM   #230
57FleetsideC4
Nice looking truck. Came out great. Enjoy it.
Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 11-30-2024, 08:25 PM   #231
87Lowrider
87Lowrider's Avatar
Trying to decide on a console for it... will need to house some cup holders, bluetooth media player, Subwoofer/Amp. I have a design in mind, just need to get it built. Here's some interior pics...
Old 11-30-2024, 08:50 PM   #232
87Lowrider
87Lowrider's Avatar
Some additional pics...
Old 11-30-2024, 10:12 PM   #233
dsraven
Nice looking truck.
I wonder about the driveshaft yoke and if it is pushed into the rear of the trans enough. You could jack the truck up by the frame, so suspension hangs, and eyeball the yoke at the same time just to check. It would suck to lose the shaft over a whoopee bump. Could be expensive.
One point on your console, since the interior mostly has rounded edges and corners, I wonder if the console would fit in the look better if the edges and angles had softened corners too. Harder to build, I know.
Old 11-30-2024, 11:52 PM   #234
87Lowrider
87Lowrider's Avatar
I can mark it and remove the driveshaft to measure how far it is inserted. Do you know how far it should be inserted into the trans?
I didn't put the drivetrain in. I had the shop who finished it for me do it. But, knowing how much stuff they Eff'd up, I wouldn't be surprised if it isn't the proper length. They supposedly measured and had a custom shaft made to mate the 4L65e to the Jaguar IRS.
I like the rounded edges idea... I should be able to use a router to soften the corners and edges before wrapping it with the internal material used on the door panels and seats from TMI.
Old 12-01-2024, 12:10 AM   #235
dsraven
The jag rear should be relatively stationary at the center section, so no real up/down movement that would affect the driveshaft length like a regular solid axle would. Sorry, On my phone I didn't see the pic detail of the rear axle. That said I would still mark the yoke and pull the shaft to see the amount the yoke is inserted. Frames flex, mounts allow movement, stuff happens, better safe than sorry.
Router the edges, a little foam., soft corners. Done deal.
Old 12-01-2024, 12:18 AM   #236
87Lowrider
87Lowrider's Avatar
Good advise... Thanks, I'll do just that and post the results of my investigation!
