10-20-2022, 08:01 AM | #1 |
Lowering Height question
What size lowering would look good on this old truck? Tires are 15x10 275/60/15 and 15x7 255/60/15. I measured 1 1/4” rake. I believe it has factory springs.
10-20-2022, 09:11 AM | #2 |
Re: Lowering Height question
My vote is 2.5/4 on a truck if you want to drive it and not break the bank.
10-20-2022, 10:23 AM | #3 |
3/5 or 4/6.
Assuming it's a truck-arm set-up, 3/5 is as easy as swapping front spindles & rear springs w/some drop blocks & new U-bolts. 4/6 is spindles, trimming the current coils or using new drop coils. Rear would be more aggressive drop springs + some drop blocks & new U-bolts. Watch-outs would be F & R wheel back-spacing. It would also be a good opportunity for fresh shocks.
10-20-2022, 12:09 PM | #4 |
Senior Moment
Really depends on what YOU want it to look like and how much YOU want to spend. There are a Lot of options. What did the Dog say.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
10-20-2022, 12:23 PM | #5 |
IMHO, if dropping front, I would use lowering coil springs vs drop spindles. For me, anything more than 3" blocks in the rear gets sketchy so consider "lowering springs" for that also
Then there will be DL angle adjustments to deal with. Generally, a spacer between trans and rear mount (at least 1/2") and a 2-4 degree shim with the rear blocks. You just need to measure angles and go from there I would look into RideTech for their "progressive" lowering front coils if they make them for C10. I have them on my 67 Camaro and really like them |
10-20-2022, 04:58 PM | #6 |
It is my impression that a 2/4 drop is the easiest thing to do first: since it can be accomplished with springs alone and is not extreme enough to affect DL.
I also think its a nice look for a LWB like yours. And if it is not low enough, keep the springs and get spindles and a flip kit later on.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
10-20-2022, 06:47 PM | #7 |
I did a 2.5" spindle drop on the front and a 4" coil spring drop in the rear.
This pic shows the finished product with an additional 1" drop block in the rear for a total of 5" drop in the back. Please keep in mind this was all new springs etc not squatted out original equipment. |
10-20-2022, 08:04 PM | #8 |
Larger tires help the look as they fill the wheel wells better.
The advice given is valid. Any lower and you end up having to notch the frame in the rear. And the A arms will require work to facilitate the alignment. You will also start ridding on the lower bumpers or worse yet the steel stops. The short story is to go below the above recommendations requires lots more money. Or compromising the ride quality. Which is pretty good for an old truck. Cheers |
10-20-2022, 09:53 PM | #9 | |||||
If a guy is handy w/fab work, you can get these trucks low & still have a decent ride on the cheap. You can also get a crappy ride throwing together a poor combo of shiny new parts.
10-20-2022, 10:09 PM | #10 |
I personally would leave it stock, but if I was going to lower it I'd just use lowering springs and drop it just a bit in the front, a bit more in the rear. I personally don't like lowering spindles on a truck that is going to be used anywhere besides the street. I'd rather have the extra ground clearance under the lower control arms. And using lowering springs can definitely improve the handling. There is a limit to lowering springs in the front though, if you care about proper alignment and tire wear.
Your wheels look great, by the way. |
10-21-2022, 07:00 AM | #11 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
. As long as you dont exceed 4" inches of drop in the rear you generally wont need to C-notch the frame or relocate the shocks. The panhard bar will either have to be bent slightly or replaced with an adjustable one to center the rear axle. Again, if you dont exceed 4" inches of drop or less the rear shocks and panhard bar will work. I gave my truck the 2-1/2" drop spindles up front and 4" drop springs on the rear. I bent the panhard bar and installed a set of shocks that are 3" inches shorter. I didnt have to do anything to the drive line angle because the pinon angle is still well within spec. Larger diameter wheels and tires will help with filling the obvious opening around the tires but keep in mind, larger diameter tires will change (lower) the speedometer reading...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 10-21-2022 at 07:10 AM. |
10-21-2022, 11:38 AM | #12 | |
10-21-2022, 01:39 PM | #13 |
Beep! Beep!
I've got the same size tires as you, with the exception of the wider rear rim. I have a 2.5" spindle set up front and 3" spring in the rear. As SCOTI mentioned above, I had to trim my lower A-arms to work with my rims. I recommend scouring photos and finding the look you like and go from there. Here's mine as I just need a reason to post it.
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport 2003 Chevrolet 2500HD CC 6.0 4wd 2004 Jeep Rubicon some aftermarket stuff... 2019 Jeep Unlimited Rubicon (the wife's baby hauler) |
10-21-2022, 03:53 PM | #14 | |
10-25-2022, 04:43 PM | #15 | |
10-25-2022, 05:16 PM | #16 |
It's all about wheel back spacing.
Unless you know the back spacing figure something like a 15X8" doesn't mean a thing. BTW my wheels have a zero offset, no backspacing the hub is exactly in the middle of the wheel. Cheers. |
10-25-2022, 06:09 PM | #17 |
'Zero offset' is 4.5"BS on an 8" wheel width. Old school math vs Metric era math is still math (for those that are unfamiliar w/the topic).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-25-2022 at 06:11 PM. Reason: Added Disclaimer |
10-26-2022, 02:57 AM | #18 |
70+ ( Old Skool Club )
Pictured is my truck with 255/60 17 tires on 17 x 8 TT2's. Those tires are the same height as the 255/70 15's I've had on my stock height trucks. Its in the process of getting a 2 1/2 inch drop front spindle and 4 inch rear dropped spring with an adjustable panhard bar and shock relocators. Also the whole front end is being replaced with the exception of the control arms and I'm from what I've read shouldn't have any issues. Just wanting the little lower and level look I see on trucks and really like.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
10-26-2022, 07:37 AM | #19 |
That's an important consideration: but if using springs only, could you not correct the geometry changes with an alignment and new shocks? The reason I ask is because I have a drum brake truck, and I am simply not ready to put discs in front. That is a few years down the road for me.
10-26-2022, 09:27 AM | #20 | |
The main benefit of the drop spindles is the travel distance of the suspension remains unchanged. When using a drop spring, it reduces the travel range of the suspension as it cycles. For the best ride quality, you want to target the longest spring/shock combo you can fit within the mounting points. Mild drops w/springs only are certainly possible & can function w/o issue. There are occasions where Camber alignment to era specs is a PITA but if targeting modern Camber set-points it's usually not an issue.
10-26-2022, 07:48 PM | #21 |
Another 2.5/4 drop here. Spindles in front and progressive springs in the rear. Not as slick and sexy as 72afr’s truck, maybe someday though.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
10-26-2022, 08:42 PM | #22 |
Great stance on the truck. Are those 275 tires front and back ?
10-26-2022, 10:21 PM | #23 |
The first picture is with 2/4 drop and 17" wheels. The second is with a 3/5 drop, with 22" wheels.
10-27-2022, 10:52 AM | #24 |
Beep! Beep!
Ha! My truck's nickname should be Lucky. The stars aligned just right for this to come together the way it did. I had no business getting this result and if I were to do it today, it'd be no where close. Your build is coming along great! You just gotta leave that CJ5 alone for a bit.
10-27-2022, 11:09 AM | #25 | ||
