10-27-2022, 06:12 PM | #1 |
Saginaw 3 speed to Transfer Case Adapter
I have a 1972 K10 that has a Saginaw 3 speed in it. I pulled the transfer case and transmission and I am wondering how you get the adapter separated from the transmission? I took off the 5 bolts holding it to the transmission but it will only come back like an inch. Any help is appreciated.
Posted via Mobile Device |
10-28-2022, 06:22 AM | #2 |
Re: Saginaw 3 speed to Transfer Case Adapter
I would like to see that! Pics?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
10-28-2022, 10:28 AM | #3 |
Just guessing here but it my be like the 4 speeds and you will have to pull the tapered pin from the reverse lever. This will allow the slider to pull loose from the gear.
Having never seen a 4 wheel drive three speed this is just a guess and I could be full of it. Most manuals I have worked on were 4 speeds. Cheers |
10-28-2022, 02:58 PM | #4 |
I figured it out. It’s actually a Muncie HD 3 speed and not a Saginaw. I rotated the adapter and was able to see a circlip in there that needed to be squeezed. I’m all set. Thanks.
FYI. I’m guessing this was kind of rare but this K20 had this Muncie 3 speed backed by a NP205. There isn’t a whole lot of info out there on these. Posted via Mobile Device |
10-29-2022, 05:11 AM | #5 |
Pics!!!!!
11-07-2022, 06:53 PM | #6 |
Here is a picture of it with the adapter. I can’t get them back together now, not sure what I’m missing here.
11-08-2022, 06:35 AM | #7 |
That sure looks like a car style 3 speed. I bet you could pop a 4 speed in there. I've never seen one. That must be rare. COOL!
11-08-2022, 07:28 AM | #8 |
I knew the 3spd was standard but never saw a 3spd K/20. I had a 3spd '71 K/10 with NP205 but never had that apart. The 3spd K/5s coupled to a small transfer case, maybe a Dana 20?
11-08-2022, 09:25 PM | #9 |
That’s what this is, 1972 K10 with 3 speed backed by NP 205.
11-09-2022, 09:46 AM | #10 |
'72 k10 SWB 400sbc 3 speed Muncie
I remember having the same issues as you are. The adapter is a tight fit and the bolts will draw it in if you tighten them evenly, a little antisieze helps too. It's actually a very heavy duty transmission except I hate the non syncronous 1st gear.
1966 Custom Camper -327, 3OTT 1968 Chevrolet K20 - 350, 4 speed 1972 K10 SWB - 400, 3OTT 2003 Corvette Z06 - LS6 350, 405HP 2004 Tahoe LT 2015 Silverado 2500HD - 6.0L V8 |
11-09-2022, 06:00 PM | #11 |
That’s it. Ok, thanks. I’ll try using the bolts to get it back together. Any idea what it’s worth?
11-09-2022, 08:30 PM | #12 |
Parts for these aren't easy to find, it doesn't neccesarily mean its rare or valuable but you don't come across these trannys everyday either.
I do keep an eye out for them just to have as a spare. My guess or hope would be under a $100.
11-09-2022, 08:46 PM | #13 |
Ok thanks.
11-10-2022, 09:20 PM | #14 |
All about them K’s
Thanks for posting pics up! My dad had a 71 K10 30+ years ago that had the same setup, before he swapped a 465 in it. You don’t see them very often in the K trucks.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
