Old 10-27-2022, 06:26 PM   #1
prg machine
prg machine's Avatar
Cab Roof Lights
I am interested in putting some Clearance Lights on my K-20. I have numerous questions:
1 Is there ample clearance between the conventional, non raised, outer roof skin and the inner Cab panel for drilling holes and routing wiring?
2 Can someone post dimensions from Center of the roof, where the center light mounts, to the center of each adjacent light closest to the center light, and the distance from center, or the outside edge of the roof, to the 2 lights closest to the outside? I would also need a dimension from the front edge of Cab to the front edge of the light base.
3 How do the Pacer aftermarket lights compare to the original Yankee 77s? Are they all Plastic? I've read that most aftermarket base gaskets are cheap foam and not quality rubber like the original. They seem awfully cheaply priced to be of any quality.
4 The ones that NAPA sells are over 50.00 dollars, but look like the real thing, can't tell if the bases are Chrome metal or plastic. Anyone know about these?
Thank you!
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 10-27-2022, 06:32 PM   #2
CG
BlahBlahBlah
Re: Cab Roof Lights
Like mentioned on this same post over on the burb side they are called Yankee 77 and yes there is room. Here is a link to a ton of posts over the years on this subject ... https://www.google.com/search?q=cab+...client=gws-wiz
Another place to look for these are decent sized truck stops if you have one in your area.
Here is a pic of a placement sheet from GM for holes for the lights ..
Old 10-27-2022, 06:34 PM   #3
prg machine
Re: Cab Roof Lights
Thanks for the diagram!!!
I would have never realized that the 2 outside lights are set at an angle.
Yes, I mistakenly put my post in the wrong forum originally.
383 .040 over
Old 10-27-2022, 07:00 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: Cab Roof Lights
One of the instruction sheets I have show all of the lights pointing straight forward. That is the way I chose to install mine.
http://67-72chevytrucks.com/vboard/s...=829820&page=5
Post #119, 120, 126, 127, & 131
LockDoc
Leon
Old 10-27-2022, 07:34 PM   #5
Johnl48
Re: Cab Roof Lights
Put them on mine. Just followed measurements in the assembly manual. Hardest part was getting the wires up there from the B pillar
Old 10-28-2022, 01:10 PM   #6
prg machine
Re: Cab Roof Lights
In order to run wires up to the lights and go through the Cab Pillar, where is the access? Inside the Cowl? Up through under the Dash?
383 .040 over
Old 10-28-2022, 01:27 PM   #7
CG
BlahBlahBlah
Re: Cab Roof Lights
Here is a link, its among all the links I posted in the board search for you. LocDoc also covered it in the thread he posted
https://www.youtube.com/watch?v=-53fdPXgVLA
Old 10-28-2022, 04:10 PM   #8
prg machine
Re: Cab Roof Lights
Thanks again!!
383 .040 over
Old 10-30-2022, 12:17 AM   #9
prg machine
Re: Cab Roof Lights
I felt around up under the Dash adjacent to the Pillar on the Driver's and Passengers side and I can't feel a hole anywhere. Used some welding wire and couldn't push it up into the pillar either. I had thought about running the wiring down the Passenger's Side Pillar since I want to eventually drill the Driver's side for a Spotlight.
Old 10-30-2022, 08:28 AM   #10
Johnl48
Re: Cab Roof Lights
If it's not a cab light roof there is no hole. You have to go up the B pillar. Follow the dome light wires. Now getting the wire to the front is the hard part. I had to fish welding wire via the headliner trim holes inside
Old 10-30-2022, 09:35 AM   #11
chewychevy67
Re: Cab Roof Lights
This is the hole in the pillar. I would have assumed they all had this hole but mine is a cab light truck. They re the reason my roof had to be replaced because of dents and when they were welded up it warped my panel. My new roof will not be getting them on it.
chewychevy67 is offline   Reply With Quote
Old 10-30-2022, 10:58 AM   #12
sloGMC
Re: Cab Roof Lights
I believe there is an unpunched hole just above the driver's kickpanel. If you have an assembly manual the cab-light drawing should help you locate it. I added cab lights to my '71 (also not originally equipped w/ U01 markers) and had no issues fishing wire through the A pillar.
There are some other threads that mention that removing the rear-view mirror and sunvisors to assist in pulling wire through. I would also recommend that; the screws from the rear-view mirror mount love to catch wires and it's easiest to fish the wire in a two-step process. I fed half of the harness through the sunvisor to the rest of the roof, and then the other half of wiring through the drivers sunvisor down through the kickpanel.
I also don't ever want to do it again so I wrapped everything with some wire braid and put heat shrink on all the splices.
1971 Pontiac Firebird
1971 GMC C2500
sloGMC is offline   Reply With Quote
Old 10-30-2022, 11:01 AM   #13
prg machine
Re: Cab Roof Lights
Could you post a picture of where the access hole is at the bottom of the pillar behind the Dash on the Driver's side?
Also, is there an opening behind the Dash on the Passenger's side?
383 .040 over
Old 10-30-2022, 11:06 AM   #14
Wrenchbender Ret
Re: Cab Roof Lights
I used black wire & tucked it in the windshield rubber. You couldn't see it at all.
I put an extra fuse in the circuit wire leading to it. I put a low amp fuse so it there was a short in all that wiring & lights it would not kick out the tail lights.
George
Wrenchbender Ret is offline   Reply With Quote
Old 10-30-2022, 11:26 AM   #15
sloGMC
Re: Cab Roof Lights
Post 10 of this thread has a picture of the roof lights from the assembly manual. Your cab will not have a pre-punched hole. You drill a hole above the kick panel in about the area shown in the picture. Your gauge cluster probably needs to be removed do this.
1971 GMC C2500
Old 10-30-2022, 12:17 PM   #16
prg machine
Re: Cab Roof Lights
Curious here, how big is the hole in the Cab Roof drilled to attach the connectors and fish the wires through to the light?
383 .040 over
Old 10-30-2022, 01:11 PM   #17
chewychevy67
Re: Cab Roof Lights
This is a different truck cab i had done and I made the the hole a bit larger on it cause I added door locks and such but this is where it's located. The stock hole is 1" in diameter. From here it goes straight upthe Pilar to the roof. The wire plugs into the headlight switch.
Old 10-30-2022, 04:43 PM   #18
prg machine
Re: Cab Roof Lights
So how big is the hole through the Cab Roof for the Pig Tail on the Lights?
383 .040 over
Old 10-30-2022, 05:27 PM   #19
chewychevy67
Re: Cab Roof Lights
I don't know. My roof has been welded back together already so I can't measure. Probably 1/2 inch or so.
Old 10-30-2022, 05:49 PM   #20
Bigdav160
Bigdav160's Avatar
Re: Cab Roof Lights
On my Suburban the rear A/C wiring goes through the same hole. It's about 1/2"
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-30-2022, 11:35 PM   #21
prg machine
Re: Cab Roof Lights
Anyway, sounds kike a "fishing" experience getting the wires to route through.
Thanks everyone
383 .040 over
Old 10-31-2022, 04:42 PM   #22
prg machine
Re: Cab Roof Lights
There's a guy selling reproduction Yankee 77s on Ebay, so I ordered a set, a little over 60 dollars for the set of 5.
LED
383 .040 over
Old 10-31-2022, 04:46 PM   #23
prg machine
Re: Cab Roof Lights
https://www.ebay.com/itm/15523002174...Bk9SR9jPyfyFYQ
383 .040 over
