Old 10-29-2022, 09:24 PM   #1
AJs72K5
AJs72K5's Avatar
Body Mount Measurements
I'm working on a chassis build for my '72 K5 (4x4). I have scoured this site and the internet for detailed frame specifications. Yes, the Roadstershop has a K5 chassis, but at $40K, they are way too proud of it.
This post is the only thing I've found with 4x4 Blazer measurements.
http://67-72chevytrucks.com/vboard/s...1&postcount=28
The Factory Chassis manual has some frame measurements, but I cannot locate ANYTHING that has the measurements and frame locations for all 12 body mounts.
I do also have an email out to the GM Heritage Archive with this same request.
Looking for these three things:
  • Location on frame
  • Center of hole across to center of hole - this'll give distance from frame horizontal
  • Distance vertically from top of frame rail surface
Anyone have this or can get them from their frame
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 10-31-2022, 03:12 PM   #2
AJs72K5
AJs72K5's Avatar
Re: Body Mount Measurements
Had an aha moment looking at the diagram in my previous post and the one from the Factory Assembly Manual for the Blazer body mount positions.
The numbers above the body mount location are distance from a landmark on the frame... specifically a hole in the center of the frame rail where the frame bends in at the firewall for the engine compartment. Translating this to distance from frame horn, here's what I have so far:
- AJ
Old 11-13-2022, 11:43 PM   #3
AJs72K5
AJs72K5's Avatar
I goofed on the core support measurement. Corrected it below in green.
- AJ
Old 11-14-2022, 08:42 AM   #4
jaros44sr
jaros44sr's Avatar
Great information, I suggest that we move this to a sticky up top
Well done AJ
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-17-2022, 01:05 PM   #5
1972CST
1972CST's Avatar
Just curious what the plans are for the chassis?
Boxed construction? Modern suspension?
1972CST is offline   Reply With Quote
Old 11-26-2022, 06:36 PM   #6
AJs72K5
AJs72K5's Avatar
Fully boxed chassis. 3 link coilover suspension front, 4 link coilover suspension rear.
- AJ
Old 12-01-2022, 12:50 PM   #7
AJs72K5
AJs72K5's Avatar
Got all of the measurements in hand to complete the chart. Remember, these are for a K5 only. Gave me what I needed to complete the chassis design. Hope it helps someone else.
- AJ
Old 12-01-2022, 01:14 PM   #8
1972CST
1972CST's Avatar
What's the final goal? Tire size, suspension travel, ... ?
Looking forward to this...
Old 12-02-2022, 02:56 PM   #9
AJs72K5
AJs72K5's Avatar
35's with 10-12 inches of travel. I need to make a long overdue update to my build thread.
- AJ
