Old 11-04-2022, 05:54 PM   #3451
Chevys4life
Re: What did you do to your truck today.The 3rd chapter
Welded up all the holes in the passenger fender skirt . Tried a different black for this skirt but I like the SEM Rust Shield better . I use a HF purple gun for this type of stuff.
Those inner wheel welds are looking great!!!!
Chevys4life is offline   Reply With Quote
Old 11-04-2022, 06:37 PM   #3452
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Got the chrome plate today so was able to reassemble my console. Now to focus on my buckets.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 11-04-2022, 08:54 PM   #3453
'68OrangeSunshine
'68OrangeSunshine's Avatar
Factory Fender Skirt, I'd swear.
Old 11-04-2022, 09:03 PM   #3454
72c20customcamper
72c20customcamper's Avatar
You are correct . All the panels on my truck are OEM .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 11-04-2022, 11:05 PM   #3455
'68OrangeSunshine
What I meant was it looks brand new.
Old 11-05-2022, 10:03 AM   #3456
72c20customcamper
Ohhhh lol
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-05-2022, 12:38 PM   #3457
sixtyeightC10
The last thing that I've done recently is start up my truck and drive it around the yard for a few minutes just to keep the seals and gaskets lubed up.
I've been too busy to do anything with my truck this year. Plus I've had some life altering circumstances happen this year that has drawn my attention away from my projects. Once my late granddaughters funeral is behind me I can move on with my projects.
1968 C10, 327 large journal crank, TH400 trans, 12 bolt 3.73 geared rear axle, and rear leaf springs. HEI, Delco 10SI, and brake booster upgrades.
Formerly known as mtndewmaniac66.
sixtyeightC10 is offline   Reply With Quote
Old 11-05-2022, 12:44 PM   #3458
sixtyeightC10
After thought post.
I have already begun collecting parts for my project including picking up a 2001 Suburban for the engine swap, a 72 blazer tank for the tank conversion, and a few odds and ends to make the swap easier.
Old 11-05-2022, 02:19 PM   #3459
'68OrangeSunshine
When they bolted on a rebuilt GM 12 Bolt rear-end at Tucson Differential, my '68 C/10 Stepside's Odo read 405,083. I was told to break it in by making runs of 15 - 20 miles, and letting the pumpkin cool down, and to change the 80-140 weight oil after 500 miles.
The other day, the Odo read 405,584 when I got home.
So it's time to drop the cover, drain the gear oil, look for metal shavings, read the wear pattern, bolt the cover back on, and refill with fresh gear oil.
Then I can cruise the freeways without let or hindrance.
Old 11-06-2022, 06:01 PM   #3460
a Good Man
a Good Man's Avatar
Before & after
MY Facebook
( saad_alhajri ) on Instagram
a Good Man is offline   Reply With Quote
Old 11-06-2022, 09:31 PM   #3461
72c20customcamper
Originally Posted by a Good Man View Post
Before & after
Truck came out real nice .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-06-2022, 09:33 PM   #3462
Louisvillekytruck
truck came out real nice .
x2
Louisvillekytruck is offline   Reply With Quote
Old 11-07-2022, 02:54 AM   #3463
a Good Man
a Good Man's Avatar
MY Facebook
Old 11-07-2022, 11:25 AM   #3464
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Before & after
Another good looking truck for your collection!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 11-07-2022, 12:51 PM   #3465
mr.mud1
mr.mud1's Avatar
Before & after
yes indeed,very nice.
mr.mud1 is offline   Reply With Quote
Old 11-07-2022, 02:17 PM   #3466
CAMAROBOY68SS
Made more progress this weekend on the bucket seat swap. After finishing the console, my seat frames were done at the blasters so picked them up and was able to get some primer on them before the rain came back. Now need another dry half a day to get them painted and the bench out of my truck to start figuring out how to mount them.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 11-07-2022, 06:15 PM   #3467
72c20customcamper
Put the inner skirt on . It’s real nice not having to fight the panels . And I seem to have miss placed one of the big washered bolts the one with the f shims . I found one and the four f shims .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-07-2022, 08:22 PM   #3468
Jiggers72-GMC
Jiggers72-GMC's Avatar
Very nice 'Good man'' ....... well done Mark ....... great work guys!!
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 11-07-2022, 08:41 PM   #3469
Steeveedee
Who Changed This?
Steeveedee's Avatar
Back in the day we didn’t have a spray booth just some huge plastic curtains that closed off a corner of the shop . Lacquer dried so fast you almost couldn’t get trash in the paint . But you always had to cut and buff
I was thinking about this after I commented, earlier. With non-metallic paint, I've managed to lay down a lacquer paint job that required only a little buffing. Gotta be careful though, that much thinner can make a run, real quick.
~Steven
Simi Valley, CA
Old 11-07-2022, 09:27 PM   #3470
72c20customcamper
Was talking full car show paint . We used to add clear to the last few coats and retarder . Then a few days later wet sand and more straight clear . They came out smooth as glass but the paint was brittle and didn’t last like the newer paints do .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-07-2022, 10:46 PM   #3471
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yep. But lacquer alone is pretty high maintenance, too. I shot the roof of my truck with base/clear acrylic enamel, because lacquer is tough to find around here, though I prefer it. I painted the roof of my '68 Skylark with that cheap lacquer sold at O'Rielly's. White, with a clear coat. It actually held up pretty well, for the price. Looked good 10 years in, anyway. I sold it after I got my truck, because I only wanted one money pit.
~Steven
Simi Valley, CA
Old 11-07-2022, 10:57 PM   #3472
allchevy58
allchevy58's Avatar
Originally Posted by a good man View Post
before & after
nice!
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 11-08-2022, 03:10 PM   #3473
KW5413
KW5413's Avatar
Originally Posted by KW5413 View Post
I was stationed at DMAFB during the SAC days (Mid 70s). I really enjoyed my time in both USAF and civilian days. Well, except when my '70 Mach 1 floated a valve cursing down the Ajo Highway at 75 MPH.
Took almost a month to find a 351 Cleveland in Arizona. Finally found a wrecked '71 cougar in Phoenix that had one.
But, on to trucks. When I bought my C10 the previous owner put the battery under the bed. What a pain on the B U Tocks. Dealing with some ongoing wiring issues we had crawl under the truck to drop the battery in order to disconnect it. I would NEVER recommend that placement for the battery.
Since there isn't much original about this truck I elected to put a below rail bed box in the truck and move the battery inside the box. Keeping the engine bay battery free. I often drive the truck in a 100-mile radius. Super easy battery access and now have a place to keep tools and cleaning materials.
Will post pictures later.
I know the purists won't care for it much and I get it. 3 of my other 4 classics I kept pretty close to original. But the good news is there is room for everything and everyone.
As I mentioned, the previous owner put the battery under the bed. PITA. Now it is in the toolbox. I went with under rail for a cleaner look and bright and shiny to match the bed / board retainers. Plus, I removed the "LUND" logo and replaced it with a bit of Texas flare. LOL!
KW5413 is offline   Reply With Quote
Old 11-26-2022, 07:00 PM   #3474
Johnl48
Got a fender on today
Old 11-26-2022, 07:34 PM   #3475
LNP
Sweet!
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
