11-05-2022, 06:36 PM | #1 |
Engine vibration while truck not moving in park
Well its been a while. I am back in the 67-72 chevy truck game. I have a vibration while the truck is running and in park. 68 Chevy 350 crate motor, hei dizzy, 400 turbo rebuilt with roughly 3000 miles on it, new TCI flex plate. Truck is up north and I am heading up there next weekend to work on it and see if I can find the issue.
The plan is check all of the plug wires to make sure they are all connected etc, then pull all of the plugs to see if someone is not contributing, if that shows all good then I may go as far as separating the transmission from the engine and pulling the flex plate to see if that solves it. Anything else I can check? Thanks!
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
11-06-2022, 03:00 AM | #2 |
Re: Engine vibration while truck not moving in park
Before I did all that, I would pull my v belt(s) off then crank it for a minute to make sure it isn't an accesory up front. If your new flex plate is for a sb 400 and externally balanced, it will cause vibration. Believe it or not, I just saw that on a BB this week.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5 |
11-06-2022, 03:08 AM | #3 | |
Thanks!!
11-06-2022, 07:01 AM | #4 |
Tutone I think was giving another possible cause, a 400 flex-plate on a 350. Have you checked the torque convertor bolts?
11-06-2022, 09:49 AM | #5 |
I agree with tutone- Sounds like the flexplate has weights on it. (Externally balanced) Incorrect for a 350 engine.
I have also ran into this with Big Blocks.
11-06-2022, 04:26 PM | #6 |
I forgot about that. Thanks tutone!!. I am pretty sure it was for a 350 not a 400 but I will check. Its been a while. I have to get the rust broken off
11-07-2022, 10:41 AM | #7 |
Long tube headers bumping against the frame?
11-07-2022, 03:41 PM | #8 |
Nope. Ramhorn exhaust.
11-14-2022, 02:06 PM | #9 |
This problem is probably rare, but it happened to me.
Shortly after I started driving my truck after swapping engines it would shake violently at idle sometimes when I stopped. After a bit of head scratching I discovered my dist would not return to idle position after revving it up. It had been sitting for who knows how long and the distributor was corroded and sticky. Took it apart, cleaned it up and it worked fine after.
I got a bench seat baby, you don't have to sit over there. |
11-19-2022, 10:42 AM | #10 |
You can give the balancer a look. Check to make sure the outer hasn’t moved and if the rubber is in good condition.
1968 SWB "Little White Truck" 1972 LWB LS 4l80 "Plain Jane!!" |
11-19-2022, 04:14 PM | #11 |
Also check fan blade, a friend of mine had part of his break off on his chenille, had a heck of a time trying to find out what was wrong
11-24-2022, 06:44 PM | #12 |
I had a similar issue with a 82C20 I worked on. Truck had a brand new engine that had never been ran. After breaking it in and putting shakedown miles on it, it developed a bad vibration. Got worse when accelerated. Went thru the regular troubleshoot list and found nothing. Replaced the balancer as last resort before pulling the engine and taking it to the machine shop. Found the balancer was bad, it had dry rotted. My one and only time I had a bad balancer. Check to make sure you have the correct flexplate also.
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
