08-06-2004, 12:29 PM | #1 |
Right turn Clyde
Trucks Track times
Best 1/4 ET
16.285 @ 83.04 RT - 1.577 I was very very tired 60 - 2.386 330 - 6.819 1/8 10.425 @ 67.89 Best 1/4 trap speed 86.76 @ 16.356 RT - 1.408 60 - 2.722 330 - 7.184 1/8 - 10.711 @ 69.65 Best RT of the day of 5 runs 1.331 next time I will be better rested. Worst run 17.401 @ 70.79 RT - 1.555 60 - 2.515 330 - 7.020 1/8 10.936 @ 62.15 Engine: 355 Cam: LM1 Heads: WP s/r torquers Rocker: CC roller tip 1.52 Intake: 2101 Edelbrock Carb: 1406 Edelbrock Headers: Hooker Competition, dual exhaust, two catalytic convertors Trans: TH400, stock stall, transgo shiftkit, remote filter Rear: 10 bolt 3.07-8 its 1982-7 used from junkyard Tires: 235-75-15 Bridgestone APTs The problems lol Blown front intake seal #4 cylinder intake valve rocker arm not oiling (bad lifter or flat cam lobe) Plugs are very carbon fouled (not real sure why? carb or ignition probably) timing 12 btdc @ 800 rpm - starting to think the distributor is a tooth off from the way it sets. Bed had a set of tires in it Lose negative battery wire That's about all I can think of I knew about the problems before I went. Just wanted to see what it would do. I plan on fixing what needs it then running again. It still feels pretty good to me for what it has and what it does. I had fun doing it, even though I was the slowest one there. It was my first time running ever and forsure wont be the last.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
08-07-2004, 10:27 PM | #2 |
Right turn Clyde
So is my trap speed good for what I have? Im not real good at reading into the slips just yet.
08-07-2004, 10:48 PM | #3 |
Hmm..I GUESS it's good.
Just for reference, my stock 93 Saturn SC2 automatic, in DECENT weather, trapped 85mph. But you have a lot of things going against you. LWB, 3.07's, TH400, Pegleg, and maybe not decent weather. |
