Old 11-20-2022, 05:14 AM   #2751
Wikid61
Wikid61's Avatar
Re: Post Your Craigslist Finds Part 2
1972 Chevy C20 3/4 ton pickup truck. 350cid (5.7L) engine with automatic transmission. Previous owner was in the middle of changing to HEI ignition when I purchased it. Since the wiring needs a bit of attention anyway, I put an internally regulated alternator on it. It will start and sounds like it will be a solid engine once it gets the tune up attention it needs... I would imagine rebuilding the carburetor would do wonders for it, also.
It'll soon need new floor pans, as each side has a small hole forming in the typical place; Towards the bottom/front of the door. Pretty straight and has a nice stance/profile sitting on 20" rims/tires...
$5,750 https://sacramento.craigslist.org/cto/7559147872.html
"Envy is a declaration of inferiority". Napoleon Bonaparte.
Wikid61 is offline   Reply With Quote
Old 11-20-2022, 05:16 AM   #2752
Wikid61
Wikid61's Avatar
67 GMC C25/20 Small rear window cab. Bought from original owners son. It has a replacement 350 GM engine, automatic transmission, power steering, power brakes, working Vintage fridgiking air conditioning. Heater works. Interior is in good condition the seat is original. It runs on the original behind the seat gas tank, also has 2 travel tanks but I’ve never used them. Looks to have had a restoration done once years ago. Has new manifold, edelbrock 4 bbl Carb and air cleaner. Runs good. Rear end was replaced recently with one that has 3.54 gears. Had it refreshed with new bearings and seals. I want $15k obo. https://sfbay.craigslist.org/eby/cto/7559115897.html
Old 11-20-2022, 05:18 AM   #2753
Wikid61
Wikid61's Avatar
1969 Chevy C20 Camper Special
2 wheel drive
Long Bed
350 V8 (rebuilt)
TH400 Automatic (rebuilt)
8 lug running gear
Power steering
Power brakes
Leaf spring rear suspension
Factory Air cab, does not have the under hood stuff for AC
Repainted in original Yellow Green Poly
This is a nice old truck that is ready to go anywhere
It fires right up, and is surprisingly smooth going down the highway
All the sheet metal is 1969. The cab corners are original and solid
The Passenger fender was rotted under the battery and replaced with an 1969 fender
Rebuilt engine
Original block was cracked
Aims Machine sourced a new block of the same generation
Bore is +60
Standard journal crank
Summit Racing pistons
Clevite bearings
Hastings rings
Melling cam, oil pump, lifters
cam is a stock grind
Original Quadrajet carb
Rebuilt Transmission
New Raybestos frictions and steels
Updated to 34 element Intermediate Sprag
New bushings
New seals/gaskets
New torque converter
It shifts up and down as it should
Driver quality paint. Meaning it looks good, but is not going to win any shows
Bed has been coated with Raptor Liner
Original Radiator has been rebuilt
New tires and wheels
LMC seat kit, floor mat, dual exhaust, and front grill
HEI ignition
Retro sound radio with center speaker only
A previous owner converted the front brakes to disks out of a 72ish truck, they work great
Odometer shows 77000 miles. No idea if that is accurate
Truck and I are located in Stagecoach
Clear NV title in my name
I don't have smog checks out here so I can't say if it will pass reno smog
No trades, cash/cashiers check only
Not in a hurry or desperate to sell just ready for the next project
Thanks for Looking! https://reno.craigslist.org/cto/7558576581.html
Old 11-20-2022, 05:21 AM   #2754
Wikid61
Wikid61's Avatar
1972 C10 for sale. I picked this truck up outside of Reno, Nevada 5 years ago where it spent 45 of its 50 years. The numbers indicate it was assembled in Fremont,ca at the GM plant. Rebuilt front end a few years ago including drop spindles, new disc brakes, ball joints, tie rod ends, springs and shocks. More recently put in a Jasper crate 350/ TH350 transmission with upgraded cam. Edelbrock top end, Hedman headers, power master starter. New gas tank and fuel lines. Drives and sounds great.
$15000 OBO https://sfbay.craigslist.org/scz/cto/7559119353.html
Old 11-20-2022, 05:26 AM   #2755
Wikid61
Wikid61's Avatar
https://sfbay.craigslist.org/eby/cto/7558725106.html
Old 11-20-2022, 05:27 AM   #2756
Wikid61
Wikid61's Avatar
https://sfbay.craigslist.org/eby/cto/7558688606.html
Old 11-20-2022, 05:29 AM   #2757
Wikid61
Wikid61's Avatar
6 way electric buckets leather seats
New dash pad, steering wheel, slide stereo with Subs and amp
Muncie 22 Rock Crusher Transmission
Bluprint 355 - Dyno was 400HP/415 Torque
American Racing Rims with Nitto Tires
AC
Pretty much every thing has been done and it is garaged.
I would guess around 4k on engine, as break in stage when I bought it and I put less than 4 k on it, maybe 400 miles a year, except first year bought I drove it to San Diego and Back, no issues. https://lasvegas.craigslist.org/cto/7558599863.html
Old 11-20-2022, 05:31 AM   #2758
Wikid61
Wikid61's Avatar
1972 Chevy C10 stepside short bed
New paint and interior
Clean California title
5.3 LS V8 4L60
Four speed automatic
New tires
Power steering
Front disc brakes
ice cold a/c
Nice dependable truck
No trades
asking $29,5 obo
email me with your number I will call https://sfbay.craigslist.org/nby/cto/7558576876.html
Old 11-20-2022, 05:33 AM   #2759
Wikid61
Wikid61's Avatar
https://sfbay.craigslist.org/nby/cto/7558688060.html
Old 11-20-2022, 05:35 AM   #2760
Wikid61
Wikid61's Avatar
https://sfbay.craigslist.org/sby/cto/7559473943.html 1969 GMC K2500 'custom camper' 4x4
Completely stock, custom order for Alaskan highway. All options.
The good--
-Rebuilt 350ci
-Rebuilt Muncie 4sp w/granny 1st gear
-Power steering
-Power brakes
-Factory ac
-Saddle gas tanks
-14bolt rear, dana44 front
-Spray-in bed liner
-Runs and drives great
The bad--
-Cosmetic issues (dents and scratches)
-Front left hub seal has minor leak
-Rear diff seal weeping
-A/C and saddle tanks not hooked up
-Needs heater core
The ugly--
-Needs bench seat reupholstered
-Headliner drooping
-Dash, interior and radio not 'buttoned up'.
Old 11-20-2022, 05:37 AM   #2761
Wikid61
Wikid61's Avatar
You are looking at a 1971 GMC C2500 RWD 3/4 Ton long bed pickup truck that shows lots of dedication and attention to detail paid during the care and love of this Classic. A very popular body it is ready for someone who wants to turn the key and go cruise around as these never really go out of style and are just great Trucks!!!
Exterior:
Clean California Sun-kissed Green with a white roof on the straight steel panels of this truck. Paint is good with a dare I call it "Patina" as the term is thrown around so much... (see pics) you be the judge, a wide shiny stainless trim painted with a black stripe runs the length of the truck on the bottom. Gaps are nicely minded throughout, and the bright new grille up front is looking spiffy. The new bumpers front and back as well are looking great in shiny chrome. Just behind the cab is the very solid 8ft bed with functioning tailgate nice painted sides and tailgate are ready for trips to the hardware store then load the coolers and chairs and head to the car show. New 16"8 lug Centerline truck aluminium wheels are on all 4 corners and all wrapped with New Yokohama P255/70R/16 tires.
Interior
A swing of the doors and we see black pleated vinyl panels and arm rest. On its edge are green painted metal sills and window frame surrounds. Inside your eyes are bowled over by the rebuilt bench with green and black tweed cloth inserts in this wonderful tuck :note the custom console and cup holder is removable. Also, the steering wheel is a later model 3 spoke style mounted atop the automatic steering column. This fronts a restored dash with a green steel face with a textured black bezel for the all new round gauges, which even includes a Summit tachometer. The dash continues across and in the center is a modern AM/FM stereo with Factory Air heater and AC controls and vents vents :note A/c not functioning Pump was removed for performance increases. Up top, is a black vinyl padded topper that is free of cracks. Down low is a new black carpet and covering the roof is a heavily padded black vinyl headliner insert floating in a sea of green steel.
Drivetrain:
Upfront under the hood is a rebuilt by the previous owner 350ci 4 bolt main V8 in its orange/red painted glory. The engine bay is clean and no rust with supple wiring and hoses. This mill is topped with a
Holley 4-barrel double pumper carburetor atop a aluminium manifold with matching valve covers and has a Fresh Turbo 400 3-speed automatic transmission mated to the back that shifts smoothly through all gears. A 12-bolt rear axle is on the back and as for the front every thing has been rebuilt with a fresh power steering box, drop springs, and power disc breaks. Looking clean and original under here.
Undercarriage
Very clean the frame is stout and structurally sound. Body hangers are rust free as are fender undersides and rockers. No invasive rust anywhere to be seen, and noted the engine shows as very clean on the bottom end. CPP 3" drop suspension springs and fresh bushings provides the smooth truck-like ride, we note power front disc brakes working in conjunction with power rear drums stops on a dime. All new dual exhaust system from the Headman headers to the with Flo style mufflers the stainless tubes snakes its way rearward, ending with dumps just behind the bumper.
Drive-Ability
I love the perspective one gets behind the wheel of a Full size 70s pickup truck, this truck fired right up with the twist of the key and off to the Highway I went. On the Highway the truck performed with fantastic power, good bias free braking and superior handling. A smooth ride for a truck as well. All functions were operational during my drive save for the the horn not tooting, and I didn't take the time to test the grip of the knobby rubber by doing any off-roading.
Signs of it previous life as a work truck still shows hear and there with some small chips and dents... that said it shows "Very Well" Overall just a solid old truck, See pics!!!
In a nut shell, if you love old Chevy and GMC trucks it might be because you have memories from your youth when riding in one of these models. This is not a museum quality truck rather a original truck that has been loved and cared for its whole life with many upgrades and all the recites in a folder to go with it. Its ready for someone to just enjoy as a nice driver or take it to shows not a trailer queen by any means but it's a cool truck. Any and every-time I drive this truck I get nothing but waves, thumbs ups, conversation, I cant come out of a store with out somebody standing there looking in!
This is a California Truck and always has been to the best of my knowledge. CA Commercial Plates. It is a good driver with clear CA title in my name and in hand. Visible Vin and Body Tags. Drive as is or restore it, must see to appreciate!!!
Feel free to message me or call with questions for more details ---------$16,500--------FIRM or maybe Trades plus cash? 50's bomb rat rod custom kustom with wide white white walls thats lowered or chopped or a vintage old rockabilly style car thats bagged with air ride or air bags any rat rod racing hopped up old school or something with hydros like a low rider thats juiced maybe a hot rod deluxe ratrod mechanic special american graffiti style Mercury 50's or 60's Vespa Gasoline or Automotive Memorabilia rare canned ham retro yard art from the 40s or 1930 vintage general motors America. https://sacramento.craigslist.org/cto/7559323278.html
Old 11-20-2022, 05:38 AM   #2762
Wikid61
Wikid61's Avatar
https://sfbay.craigslist.org/nby/cto/7556796128.html
Old 11-20-2022, 05:42 AM   #2763
Wikid61
Wikid61's Avatar
https://sfbay.craigslist.org/eby/cto/7558380921.html
Old 11-20-2022, 05:45 AM   #2764
Wikid61
Wikid61's Avatar
https://sandiego.craigslist.org/nsd/cto/7557340342.html
Old 11-20-2022, 05:48 AM   #2765
Wikid61
Wikid61's Avatar
https://inlandempire.craigslist.org/cto/7549845736.html
Old 11-20-2022, 05:50 AM   #2766
Wikid61
Wikid61's Avatar
https://losangeles.craigslist.org/sf...558597375.html
Old 11-20-2022, 05:51 AM   #2767
Wikid61
Wikid61's Avatar
https://sandiego.craigslist.org/esd/cto/7559405364.html
Old 11-20-2022, 05:52 AM   #2768
Wikid61
Wikid61's Avatar
https://mohave.craigslist.org/cto/7559331474.html
Old 11-20-2022, 05:53 AM   #2769
Wikid61
Wikid61's Avatar
https://losangeles.craigslist.org/ws...559017232.html
Old 11-20-2022, 05:54 AM   #2770
Wikid61
Wikid61's Avatar
https://orangecounty.craigslist.org/cto/7558671264.html
Old 11-20-2022, 05:58 AM   #2771
Wikid61
Wikid61's Avatar
SELLING MY 1972 CHEVY C-20 HIGHLANDER PACKAGE ORIGINAL PAINT TRUCK AND RUST FREE.350 MOTOR AND 350 TRANS AND TILT WHEEL.16 INCH WHEELS AND CAPS AND NEW MICHELIN TIRES.MOTOR WAS REBULT DISC BRAKES POWER STEERING AND BRAKES .AND RUNS AND DRIVES GREAT.FACTORY HUGGER ORANGE ORIGINAL PAINT.FRESH NEW DUAL EXHAUST WITH FLOWMASTER 3 CHAMBER MUFFLERS.HAS ICE COLD FACTORY AC.
ASKING $20,000
CLEAN TITLE AND CURRENT REG
CALL show contact info IF INTERESTED
WONT RESPOND TO TEXT !!!!
IF INTERESTED CALL WONT RESPOND TO TEXT
ASKING $19,000
NO TRADES https://sandiego.craigslist.org/nsd/cto/7559504838.html
Old 11-20-2022, 06:02 AM   #2772
Wikid61
Wikid61's Avatar
https://inlandempire.craigslist.org/cto/7559442361.html
Old 11-20-2022, 06:04 AM   #2773
Wikid61
Wikid61's Avatar
https://inlandempire.craigslist.org/cto/7559066856.html
Old 11-20-2022, 06:05 AM   #2774
Wikid61
Wikid61's Avatar
https://sandiego.craigslist.org/ssd/cto/7558901175.html
Old 11-21-2022, 09:22 AM   #2775
Wikid61
Wikid61's Avatar
Selling my 1968 Chevy long bed stepside I bought it from the original owner and from what I'm told it has 80,000 miles on it everything from what I could tell is all original the truck runs and drives you can drive it home the person I bought it from he used to drive it occasionally I drove it from Concord to Tracy and had zero issues it doesn't leak it runs pretty good
it has a
straight 6 motor
4-speed transmission
12 bolt rear end
Bucket seats
Tags are updated and current https://stockton.craigslist.org/cto/7559757124.html
