#2276 | |
Re: My 52 GMC Build
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 ![]() |
#2277 |
Re: My 52 GMC Build
Sure I can I have only unbolted stuff
![]() Just remove about 50 bolts and the front end falls off. Marking all the wires as I go, so far so good.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#2278 |
Re: My 52 GMC Build
Looking good! Can't wait to see how this one runs.
Taking that front end apart is what's keeping me from doing AC in mine. For whatever reason I stopped getting updates a few pages back, they seem to be working now.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
#2279 |
Re: My 52 GMC Build
just wee little chops, sux to have to pull everything under the dash to make them.
that blue looks crazy in there! |
#2280 | ||
Re: My 52 GMC Build
Ya I really like the color.
#2281 |
Re: My 52 GMC Build
A bit of fire wall massaging with a big hammer at the top for turbo clearance and had to cut a bit on drivers side to clear exhaust up pipe but not nearly as much as I thought. Welded up some holes that I'm not using any more as well. Added double layer of insulation to the fire wall and exhaust up pipes and turbo are wrapped. Closest place has 1/4" clearance with 3 layers of insulation plus the lizard skin on the inside, should be good.
#2282 |
Re: My 52 GMC Build
just enough is all ya need!
but can you work on the exhaust without pulling the engine? |
#2283 |
Re: My 52 GMC Build
Couple more pictures of the Power house Powerstroke install.
#2284 |
Re: My 52 GMC Build
I should not have to ever get to the up pipes, but yes I would have to most likely pull turbo as well.
#2285 |
Re: My 52 GMC Build
Definitely a tight fit!
#2286 |
Re: My 52 GMC Build
Dam that is close to the firewall...
#2287 |
Re: My 52 GMC Build
I have had lots going on, so here we go. New exhaust pipes showed up, old motor had 3" new motor will have 4". All the 3" pipe I bought is for the intake pipes. Decided to make a new tail pipe out of the 6" dia 3/16" wall stainless pipe that the old one was made from. I made a tear drop tip. Took around 30hrs to make and the final cut took 45 min, had to go slow and help the blade go strait down.
#2288 |
![]() Join Date: Jul 2012
Re: My 52 GMC Build
Wow, impressive exhaust creation and sculpting….pure art.
#2289 |
Re: My 52 GMC Build
curious, do you plan some sort of heat shield over the exposed area of the pipe? I ask because I was burned badly by an exposed pipe-on a firetruck at work, but still. it's likely gonna get hot and you likely won't wanna babysit it till it cools off.
nice work on fabbing those pipe bends. |
#2290 | ||
Re: My 52 GMC Build
#2291 |
Re: My 52 GMC Build
Then onto cooling, new horizontal aluminum radiator that I modified to go vertical. It was off the shelf from Summit, they are both 4 core the new one is 6" longer and weighs 15lb less. The new fan is 2400cfm/17" and is 500cfm more and 1" bigger than the old one that worked ok. Had to trim the rad support a bit because the pullies are wider on this motor.
#2292 |
Re: My 52 GMC Build
you are doing some very good work there Bob,
keep it going,
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
#2293 |
Re: My 52 GMC Build
Yes, impressive work on the radiator!
#2294 | |
Re: My 52 GMC Build
#2295 |
Re: My 52 GMC Build
Thank you
I can not take the credit for the welding I tried using my spool gun=lots of little holes so I had someone reweld it for me. Thanks oh I will
#2296 |
Re: My 52 GMC Build
So it has taken a ton of time to figure out what wires I need and where they need to go. (I can't find the right pinout for the computer) I started with the entire engine bay from the truck the motor came out of, whittled it down to what is in the 3rd picture then made spaghetti in my truck. I finally have everything hooked up, so the computer seems to be working properly. After I get the motor started I'll take it back out and make it all neat.
#2297 |
Re: My 52 GMC Build
wiring is fun, isn;t it........
#2298 | |
![]() Join Date: Jan 2015
Re: My 52 GMC Build
#2299 |
Re: My 52 GMC Build
I don't mind it, it would be a lot more fun if I could find the right pinout. But it's in the past now.
Thank you! I really like making full exhaust, I'll show it when I build it.
#2300 |
Re: My 52 GMC Build
Bit of a mish mash of stuff done. New lift pump and filter set up mounted in the rear same spot as the old setup. Then goes to my fuel cooler up to the motor and out through my regulated return system. I have 62psi without motor running, so I am perfect. Started my intake pipes, so far so good. I also got my new Dakota Digital gauges all working and set up, They are really nice to set up.
Tags |
bagged, build, diesel, gmc, hot rod |
