Anyone install chrome or staineless upper radiator hose?
I've seen some nice upper radiator hoses (not rubber) installed, I'm not sure if they are chrome or stainless.
I've read some reviews, and some brands are problematic, mostly the rubber adapters. Anyone using these metal hoses for the upper radiator |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Anyone install chrome or staineless upper radiator hose?
I think the last time I used those was around 2008 on a different vehicle. Mine worked without issue at the time.
It's Better With Nitro
I tend to make my radiator hoses for my race cars/hot rods. I use 1 5/8 and 1 3/4 steel tubing and ceramic coat them.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
^^sweet^^
![]() Join Date: Oct 2006
I have run a ribbed stainless ( Mr. Gasket ) for my upper and heater hose for years no issues other then they do get hot to the touch
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
I have had some for over 15 years. I even reused it after I totaled the truck. Great to make a template out of if you want to go the hard line route above. Sure is nice to not have to search for the right rubber one. Goes around weird configurations as well.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
