Old 11-29-2022, 12:19 PM   #1
craigg1
WTB: 67 327 original intake manifold & Carb
Looking for an original 1967 327 C10 4 barrel intake manifold and Carburetor. Thanks.
67 C10 SWB Chevy
craigg1 is offline   Reply With Quote
Old 11-29-2022, 03:52 PM   #2
chewychevy67
Re: WTB: 67 327 original intake manifold & Carb
For th400 or standard trans?
chewychevy67 is offline   Reply With Quote
Old 11-29-2022, 04:02 PM   #3
craigg1
Well, it originally was a standard, but has since been changed to a TH-350.
67 C10 SWB Chevy
Old 11-29-2022, 08:42 PM   #4
1rippen6
I have a couple cast iron 4 barrel intakes but don't know if any are 67, is there some way of identifying?
1rippen6 is offline   Reply With Quote
Old 11-29-2022, 08:49 PM   #5
Accelo
Accelo's Avatar
The date code is one each one. Next to the part number.
I believe you have a choice.
The 300hp that a Holley bolts right up to.
Or the Quadrajet. Two large holes and two smaller ones.
Do you want it specifically for a 1967 C10?
The GM Heritage center (gm.com/heritage/archive) only lists the 283 in the C10.
The 327 was available in other models like the Suburban.
It was a 220hp.
I have a 300HP intake but will have to look at the date.
Accelo is offline   Reply With Quote
Old 11-29-2022, 09:13 PM   #6
craigg1
Im not 100% on the intake casting number, but I think for a 67 327 C10 it would have been 3882858.
And the carb would be a Rochester 4G (7027125)
67 C10 SWB Chevy
Old 11-29-2022, 09:16 PM   #7
chewychevy67
The 327 was available in the c10. I have one. The reason I asked if it was a th400 is that a stock 4 jet carb used on these trucks had a different arm on the throttle with a tab that depressed the kick down switch mounted next to the carb. A th350 wasn't available in 67 but a bracket could be easily fabbed. I used a 65 300hp intake on my 327 because it has better runners and the 4 jet will mount to it. Here's pics of a stock style carb for 67 ( except i added a automatic choke, 67 wasnt availablewith this on 327) Also the 65 intake. The stock style intake looks similar to this but not exact. None of this is for sale.
Old 11-29-2022, 09:23 PM   #8
craigg1
It was a 220hp.
Id prefer one specifically for a 67 C10, but might otherwise go with something close to factory.
The GM Heritage website is a good site. First time I've checked it out.
67 C10 SWB Chevy
Old 11-29-2022, 09:27 PM   #9
craigg1
So pretty much any chevy 327 intake manifold will work from around the same year, but only certain carbs may work with a specific intake?
67 C10 SWB Chevy
Old 11-29-2022, 09:31 PM   #10
zicc1835
zicc1835's Avatar
here is what I can offer sitting on my shelf for to long casting comes back 327 although not c-10 67 is one of the years ill just put a price on it per board rules 100.00 plus ship but OBO
zicc1835 is offline   Reply With Quote
Old 11-29-2022, 10:25 PM   #11
chewychevy67
I wouldn't say al intakes because some have different spots for the heat ports that are supposed to use exhaust to heat up the carb and intake faster and if they dont match up you could create a vacuum or fuel leak. I plugged mine off. This is the stock intake. You can see the holes are in simular location. You may need a phenolic gasket between the intake and carb with the 300hp intake as mine did. Stock just use a gasket.
Old 11-29-2022, 10:34 PM   #12
craigg1
Thats your stock intake to your 67 C10 327? If so, what is the casting number on it? Thanks.
67 C10 SWB Chevy
Old 11-29-2022, 10:59 PM   #13
chewychevy67
Sorry but mines long gone. I am not sure what it was.
Old 11-29-2022, 11:28 PM   #14
LockDoc
The Older Generation
LockDoc's Avatar
I have this one. #3886922 E45 Square Bore. Has coil bracket, vacuum fitting, water outlet, distributor clamp and bolt, breather tube, and front water outlet. 60 bucks plus shipping. Needs blasted & painted..... I will have to check on a carb for it.
Whichever one you use you will have to be sure and get the carb that matches it.
LockDoc
Leon
