#526 | |
Re: My 56 build
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
#527 |
Re: My 56 build
Love the color choices and it came out great. I did the raptor on mine also and really like the way it came out. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
#528 |
Re: My 56 build
Thanks everyone for the compliments. I can’t wait to see it out in the sun. I’m color sanding today, then it goes back on the frame for the last time.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
#529 |
Re: My 56 build
Cut and buff is neatly complete. May need to finesse a few spots then polish. Hopefully I’ll have it back on the frame this weekend
![]() Here’s a link to a video: https://youtu.be/6Rm8FWEcpNs
#530 |
Re: My 56 build
Looks Great. Love it!! Steve
#531 |
Re: My 56 build
Very nice! Good choice on color.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
#532 |
![]() Join Date: Jan 2015
Re: My 56 build
lookin real good!
#533 |
Re: My 56 build
Update. When I last posted, I thought the cab almost finished. After the cut and buff it became obvious I had experienced solvent pop. This means I have to redo most of the cab.
![]() Motivation… a friend came across 10 of these 1” rough cut curly maple. So all the wood will be redone! Why not, but you can’t beat the price. Today… back at it again. Thought I would start small. Just the steps. Different clear and different base reducer. I’m going to cut and buff Tuesday. If it looks ok, I’m going back to the cab.
#534 |
Re: My 56 build
Maybe you could find a rental spray booth to spray the cab. It would be cheaper than more paint supplies, not to mention the time.
Been there with solvent pop. Looked awesome till the next morning. Peeled it off in sheets like cellophane. |
#535 |
Re: My 56 build
Nice build
![]() I look threw all the pages and did no see the front "bumper" area being made??? |
#536 |
Re: My 56 build
Nice looking and hope you get the paint issue fixed. Steve
#537 |
Re: My 56 build
I took the old bumper and cut it up. Tried to make it fit, but everything I did looked terrible. So I’m going with the original bumper. It looks the best.
#538 |
Re: My 56 build
my .02 worth, this cut up bumper looks great, good job. As you can see from my front clip, I'm not a same as type person.
#539 |
Re: My 56 build
that sliver bumper is pretty sweet, maybe a touch narrowed and cut the frame back behind the chin sheet metal.
#540 |
Re: My 56 build
Some progress. I’ve decided to hold off painting until spring when I can have proper ventilation ( extensive painting that is, still priming some). I still have some prep work to do. Here’s the inner fenders bodyworked and now in primer. Ready for paint.
After everything is prepped I’m going to install a dod delete kit in the engine. I just had my new gmc 5.3L in the shop to have all 16 lifters replaced. One lifter collapsed and lost a cylinder. So replace it before it’s a problem. I Guess this means I get to put a cam in it… so why not an 6.2 cam. Easier to do now while it’s on an engine stand.
#541 |
Re: My 56 build
I mean.. while you're there...
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
#542 |
Re: My 56 build
I’ve been working on the new bed wood. It took about a month. I received it as rough cut 1”. Here’s a few pictures of the results. Last picture is for comparison. It’s the pine I started with. I originally had stainless angle on inner fenders, but didn’t care for how it looked. So I went to 7 boards with a wider outer board. Clean cut, single board around the inner fender looks cleaner
#543 |
Re: My 56 build
Time to make exhaust tips. Borrowed a TIG welder from my brother. My first experience with such a beast. Three weeks of practice and I have one side welded. Just need to finish work the weld and polish everything. Than tackle the other side.
#544 |
Re: My 56 build
that looks awesome. will you polish it or accent paint it? I would only worry about it getting hot and blistering the paint around it, especially if there is filler involved in the surrounding area. maybe use a thick gasket between it and the fender? will you use a flex pipe prior to the entry of the pipe to the bezel to keep possible rattles down
#545 | |
Re: My 56 build
#546 |
Re: My 56 build
you could look for some exhaust gasket sheet and cut your own
you could look for some silicone heat resistant gasket sheet and cut your own I would opt for the silicone sheet personally if you find the exhaust pipe shakes around and causes rattles you could use a flex pipe somewhere close to the exit and then clamp the pipe so it doesn't move so much with engine torque etc, or you could wrap the inside of the trim pieceor outside of the pipe that sits inside there with some silicone sheet just some thoughts, you may not even have an issue with rattling so no use what iffing it to death first. haha. I would insulate the trim part though, paint ain't cheap |
#547 |
Re: My 56 build
don't under estimate the amount of heat.
I notched the rear bumper on my 67 Tempest for tail pipes and now the chrome starting to discolor. just an FYI
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
#548 |
Re: My 56 build
Cab is resprayed. Working on the cut n buff.
#549 |
Re: My 56 build
Used a couple of engine stands to hold the box sides upright. Worked well. Second picture is after sealer.
#550 |
Re: My 56 build
Most of the box is painted. Just need to paint the fenders and tailgate.
