Auto steering column collar conversion.
My 68 C10 was converted to manual floor shift and was wondering if there is an aftermarket collar to replace the auto shifter collar on the column to eliminate the nub left over from the shift arm vs. replacing the entire steering column with an aftermarket unit?
#2 | |
![]() Join Date: Oct 2020
Re: Auto steering column collar conversion.
There is one currently on eBay here: https://www.ebay.com/itm/16577823544...Bk9SR-Cc0ZKbYQ Your only other alternative is to grind off the nub for the column shifter, and fill it in with something like 'All Metal' body filler or a two-part epoxy putty and shape it accordingly. Last edited by 68 C10 Driver; 12-03-2022 at 02:11 PM. |
#3 | |
Disassembling the steering column is relatively easy and simple. Just take pictures with your phone of areas you disassemble, BEFORE you disassemble. Gives you a great reference when you reassemble the column. Not a lot of parts.
And in the process you can paint it what ever color you want for that professional look. |
To add a potential option to think about. I recently installed a tilt column in my 66 K10 Burban (4 speed, stock steering wheel). It started life as a 70's GM Van automatic tilt. Shift indicator was ground off, column body worked, painted. Board member 70shortfleet did the work and it is outstanding, I highly recommend him. Adding a tilt to any of these trucks really improves the driving experience and comfort.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
#6 | |
I've already slid the current column down into the dash about 2" to give me more space between me and the steering wheel. So it's a much more comfortable driving experience. |
#7 | |
#8 | |
![]() ![]() Join Date: Jan 2005
Here's a thread that shows the differences between automatic and floor shift columns.
https://67-72chevytrucks.com/vboard/...d.php?t=827926 |
![]() Join Date: Dec 2013
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Thanks all for your replies
I ended up finding the pcs I need to convert my current column from 70shortfleet here on the forum. |
![]() Join Date: Oct 2001
I built a truck yrs ago that was a 3 speed on the column and I put a 4 speed and Hurst floor shifter in. I sawed that nub off filled it with JB weld and did some sanding and priming a coat of paint and was perfect.
Things happen for a reason! |
