![]() Join Date: Mar 2022
Driveshaft - transmission tail piece
About how long is the front section of the driveshaft (tail piece/yoke) that inserts into the transmission?
After centering my wheels in the wheel wells and mounting the new lowering but multi-leaf springs and getting the axle bracket lined up with the springs center bolt, my yoke/tail piece is out of the transmission a smidge more that it was with the mono spring that were on the truck from the previous owner. How much yoke shaft sticking out of the transmission is too much?
1953 Chevy 3100 - 5 window 1/2 ton pickup My 1953 Chevy Work-In-Process Photo Gallery "I don't have a carbon footprint, I drive everywhere." Last edited by TX3100Guy; 12-06-2022 at 09:12 PM. |
Re: Driveshaft - transmission tail piece
you really gotta post a pic. some slip yokes are longer than others. somebody here may have the knowledge but maybe won't be inclined to research what you are running for a transmission so they will carry on to the next posting. a pic and some better info would help
after doing all that work and change you should block the truck up on it's frame and run the suspension through a full suspension run, from one end to the other, just to make sure the driveshaft is gonna stay where it is and also so it doesn't bottom out on the yoke or the shocks. yup, I know, its easy to do the suspension hung but not that easy to do a full jounce. taking a chance is just that, chancy. |
#3 | |
Here are two photos of both the transmission and the yoke. Given all the custom aspects of the truck and the fact that now the wheels are centered in the wheel well, I may ultimately need to have the drive shaft lengthened if the yoke is pulled out too far. There is approximately 2 inches of the yoke showing.
1953 Chevy 3100 - 5 window 1/2 ton pickup My 1953 Chevy Work-In-Process Photo Gallery "I don't have a carbon footprint, I drive everywhere." |
personally I wouldn't trust that. if the front of the driveshaft comes out of the trans it can make a real mess under the truck and if the fuel tank is also under there it could be a really bad day for you.
like said though, do the full suspension travel and take dimensions on that yoke each time. then you will have a good idea of how much change you will need in the shaft length as well as if the shocks bottom before the suspension hits the jounce stops, etc. for leaf spring suspension also factor in a bit for spring wrap which can cause the pinion angle to change. |
#5 | |
if you get a dimension for the new driveshaft you could also check if an OEM vehicle shaft is kicking around that would be the right length. might save you some bucks but tke you some time.
when you gat the shaft off slipit all the way into the trans and get that dimension as well, so you know the absolute bottom out dimension.
I'll probably pull the drive shaft out later this week to get its current measurement. I just found a decent drive shaft shop a few miles from my home. I'll call them in the morning to see what their quote it on working on this one, then go from there. Thank you.
The way it is now it will probably knock the tailshaft bushing out in a couple hundred miles just like mine did on the way to the Street rod Nationals in Tulsa in 1973. I had the same issue, when I put my wheels back where they were centered in the wheel well my driveshaft was too short.
If you look real close the seal used to ride pretty close to where I put the arrows. If you know Bob Davis who used to teach Auto mechanics at TSTI in Waco and at least used to be heavy into early F100 trucks you can ask him about helping me change the tailshaft on the trans in a wrecking yard in Marietta OK in 1973. That was after I burned out my coil crossing the red river.
When I was struggling with the leaf springs today, at one point the yoke was all the way in, but the wheels looked awful in the wheel wells, almost scraping the front edge. It was obvious that wasn't going to work, so I changed up the spring mounts and the earlier photo is the end result. Wheels look great, leaf springs fit properly, yoke is too far out......go figure.
#11 | |
I concur, that is sticking out too far.
this table might be useful: https://www.demandaam.com/technical-...l-of-materials I had a driveline place make a new driveshaft about 5 years ago and it was not that horrible, 350 ish Canadian as I recall. That is a lot cheaper than hating the way your wheels look in your fenders every time you walk up to your truck. |
If you can find another shaft that's too long it may be cheaper to shorten that than retube yours.
#14 | |
Posted via Mobile Device |
#15 |
Making the driveshaft is the last thing I ever did.
With everything mounted up and sitting at ride height then you can get an accurate measurement. Add some fuel to the tank too or the fuel tanks full weight in the box. Barbell weights help in that. Rule of thumb was push the yoke in all the way and then pull it out 1 inch. |
#16 |
Yikes! I wouldn't drive that one foot. If it failed i wonder which way the forward end go? Up on down?
#17 |
I had the same problem When I installed the Flatout crossmember and changed the motor mounts the yolk didn't have enough engagement with the TH350 trans. I replaced the 4'' yolk with a longer yolk, I believe 6'' yolk from Summit. I don't know if this is another option or if I was just lucky it worked out.
#18 | |
Based on measurements of the drive shaft, I need to have the shaft lengthened about 1 to 1 1/2 inches. I counted the splines on the transmission yoke at 27 and see longer yokes at both Summit and Speedway at a fraction of the cost of lengthening the driveshaft (best quote this morning is $300-395). I may consider this route. Thanks.
#19 |
longer yoke could / might lead to vibration or bushing wear.
At some point an unsupported shaft starts to rotate off centre I would not run a longer yoke with the stickout you show on a LS swap pushing a $5,000 t56 magnum, but would probably give it a shot on a 235 twisting a $75 Saginaw 3 speed |
#20 |
Wheel centered with lowering but multi-leaf springs. Also 1 1/4" wheel spacer/adapter installed. Wheel rotates clear of the caliper and is clear of the wheel well.
#21 |
How’s your pinion angle?
Or what’s your pinion angle? |
#22 |
I've been told that I"m incorrectly measuring the pinion angle with my gauge. Given that the driveshaft is currently off, how would you suggest I measure the pinion angle. When I put by magnetic gauge on the output yoke of the differential, it is showing 0 degrees. When I put the gauge on the output shaft of the transmission it is between 2 and 3 degrees.
#23 |
Depends on the measuring tool you have.
Put it on the yoke ear or the yoke face. With 2-3 down on the trans and at zero on the pinion you should be fine. The rear end tends to climb (rotate) upwards a couple degrees making them equal. Leaf sprung does that, coil spring doesn’t. |
#24 | |
#25 |
that angle may change slightly with a longer shaft due to the trans end going further forward. should be a minor cange though
