View Poll Results: transmission type
700r4 transmission 19 70.37%
350 transmission 8 29.63%
Voters: 27. You may not vote on this poll
Old 08-07-2004, 03:44 PM   #1
junkyardpartseeker
transmission type poll
As most of you know, I have a 84 suburban with a 350 motor. I know the 700r4 transmission needs rebuilding. I do a lot of towing with this suburban and am deciding whether to rebuild the 700r4 trans, or put in a 350 trans with a 9 inch tailshaft.
I am letting the majority decide for me on which one to go with.
Thanks for the help
Tommy Davis
junkyardpartseeker is offline   Reply With Quote
Old 08-07-2004, 08:21 PM   #2
Tom
driving is in my blood
Tom's Avatar
Why would you want to loose overdrive? I don't get it.....
Old 08-07-2004, 10:06 PM   #3
junkyardpartseeker
Not wanting to loose the overdrive, just wanting to know which one would be better on the heavy towing it will be going thru. I am not too familiar with them, so I thought I would let the ppl here decide for me.
Thanks for the help.
Looks like I will try to get the 700r4 rebuild. I know it is a 85. Is there other years I should look at that would be better?
I am not running any emissions and am not sure what all I would need to install it after rebuild.
Tommy
Old 08-07-2004, 10:14 PM   #4
RockHQ
ROCKET POWER!
RockHQ's Avatar
If possible get a 1988-1992 year 700R4 from a K-truck (4wd) and have it rebuilt.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 08-08-2004, 12:04 AM   #5
Destructo
You can update your 85 transmission with later parts. But I would just add extra clutches in the 3rd-4th gear, add corvette servo, .500" boost valve, shift kit setup for towing, good transmission cooler and a lockup kit so you can lockup the torque converter in 3rd gear. You could also just get a later model valve body too I think, thats the only real difference bewteen the early and later model transmissions, I don't remember if the valve bodies interchange though. You could also upgrade to a heavier sprag but for our year 700r4 its kind of expensive because the whole thing needs to be replaced, also the sun gear shell can be replaced with a stronger unit.
How much weight are we talking about here?
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 08-08-2004, 10:00 AM   #6
junkyardpartseeker
Not sure on exact weight. I do know my wife has a 26ft trailer loaded with her flea mkt items. Just want to be prepared if she gets more in there.
Tommy
Old 08-08-2004, 08:07 PM   #7
Tom
Tom's Avatar
Do get a newer style 700R4, don't bother updating yours. It should be cheaper to just buy a core newer model and rebuild it instead of updating the old one.
Old 08-08-2004, 08:10 PM   #8
SanitysBane
a 700R4 is suposedly a turbo350 with an overdrive, i would go 700R4 all the way, i've got one in my truck and i love it. just gotta build them right if you want them to last
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 08-09-2004, 12:46 AM   #9
1972C10
1972C10's Avatar
I belive if i was wanting a heavier duty for towing id put in a th375 or th400
1972C10 is offline   Reply With Quote
Old 08-09-2004, 01:56 AM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Rebuild any core from 85 and up. I have an 85 and beat it pretty good. No problems with a stout rebuild.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
