Old 12-09-2022, 06:24 PM   #1
AngryPirate
AngryPirate's Avatar
Rear suspension is jarring when hitting bumps
1960 GMC 1000 series.
New POL rear coil spring, standard ride height
Shocks - replaced about 5 years ago, but they might not be correct
New POL adjustable trackbar (panhard bar).
Whenever I hit a bump (even small potholes) the rear suspension hits HARD and is quite brutal.
The only thing I can think of is that the shocks are underpowered or too short and not able to dampen the rebound from the new coil springs?
Anyone have an good recommendations for rear shocks for these trucks if we think that is the issue?
Thanks for any ideas.
AngryPirate is offline   Reply With Quote
Old 12-09-2022, 08:07 PM   #2
Backpayne
Re: Rear suspension is jarring when hitting bumps
Can you tell us the current model # of shock currently on it?
Backpayne is offline   Reply With Quote
Old 12-09-2022, 08:17 PM   #3
AngryPirate
I値l crawl under tomorrow and take a look.
Might have been NAPA brand, but I forget.
Old 12-10-2022, 03:03 AM   #4
Bob B.
Sounds like a shock problem.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 12-10-2022, 01:54 PM   #5
theastronaut
theastronaut's Avatar
Pull the two lower shock bolts out then bounce the truck to see if the shocks are too stiff.
theastronaut is offline   Reply With Quote
Old 12-10-2022, 02:12 PM   #6
Arne
Arne's Avatar
Or if the shocks are too short, and top out hard on rebound.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 12-10-2022, 08:13 PM   #7
bigmoe
bigmoe's Avatar
What he said, but try bounce on it before and after you unbolt the shocks to compare.
bigmoe is offline   Reply With Quote
Old 08-19-2023, 06:05 PM   #8
AngryPirate
So, it seems the rear shocks that were on there were too short.
60-62 GMC and Chevrolet's don't usually have rear shocks listed at all the usual places.
I found one posting that pointed towards some Race Car Dynamics Bilstein shocks that fit (Part 55-R148) .
The before and after is quite noticeable.
Thanks all for the responses and suggestions!
