12-09-2022, 11:44 PM | #2951 |
Re: Post Your Craigslist Finds Part 2
https://www.youtube.com/watch?v=-PL8-_G8JVc |
12-09-2022, 11:46 PM | #2952 |
12-09-2022, 11:47 PM | #2953 |
12-09-2022, 11:48 PM | #2954 |
12-09-2022, 11:49 PM | #2955 |
12-09-2022, 11:51 PM | #2956 |
12-09-2022, 11:53 PM | #2957 |
12-09-2022, 11:54 PM | #2958 |
12-09-2022, 11:55 PM | #2959 |
12-09-2022, 11:56 PM | #2960 |
12-09-2022, 11:59 PM | #2961 |
12-10-2022, 12:01 AM | #2962 |
12-10-2022, 12:08 AM | #2963 |
12-10-2022, 12:11 AM | #2964 |
12-10-2022, 12:13 AM | #2965 |
https://washingtondc.craigslist.org/...560964426.html 1972 Chevy C10, lowered, 350 with mods, 3 speed on Column, bucket seats with center console. Owned by shop owner. Too much info to list, must see to appreciate. Calls preferred, so please email with your contact information and I'll give you a ring. $23,500 / or best offer. Serious inquiries only please - thank you.
12-10-2022, 12:14 AM | #2966 |
12-10-2022, 12:23 AM | #2967 |
1968 C10 original patina truck. Brand new Wilwood disk brakes all around, Brand new CPP master brake cylinder, Brand new starter, Brand new drop spindles, Brand new cross member, Brand new lowering springs, Brand new C-notch, Brand new shocks, Brand new 20” American Racing torque thrust wheels and brand new tires. In-line 6 cylinder / 3 speed manual. All work done August 2022.
Please call. No emails. https://longisland.craigslist.org/ct...558037053.html
12-10-2022, 12:26 AM | #2968 |
12-10-2022, 12:32 AM | #2969 |
12-10-2022, 12:34 AM | #2970 |
1972 C10 Custom Deluxe Longbed
I bought the truck in 2017, it originated from down south. It was a highly optioned “Highlander” truck when it came from the factory. One of the previous owners was an engineer for MegaSquirt. He installed a 4.8 LS and 4l60E in it and the truck was the test mule for the MegaSquirt Ms3-Pro Engine Management System. The owner previous to me did the 3/5 drop on the truck. The rear end was pretty messed up so I got it rebuilt with a new posi unit with 3:73 gear. I went ahead and had Finish Line Transmission rebuild the 4L60E, they did the street performance upgrade and I had them also upgrade the stall to a 2000 stall speed. I put new tires on it also. The tires and rearend have less than 100 miles on them, and the trans hasn’t been installed yet. My plan was to upgrade the brakes, steering and suspension, and replace the original gas tank in the cab with a Boyds that’s installed on the frame under the bed. I bought much more new stuff for the truck, but it has sat in the garage for the last 3 or 4 years. I was going to have the cab corners and rockers installed but leave the paint alone. I’ve got a 70 RS Camaro pro touring car that I spend most of my free time driving. So, I’m putting the C10 up for sale as it sits, the engine and trans are not installed, but the steering linkage is. Can be winched up onto a trailer. Drivetrain 4.8 LS out of a 2009 Chevy van; 59k miles; newer Camaro exhaust manifolds Jet-Hot Ceramic coated. I have a Trailblazer SS engine cover for it. Dual exhaust 4l60E trans; fresh rebuild by Finish Line Transmission, Street Performance, new 2000 stall GM 12 bolt, new posi unit and 3:73 gears, Moser cover Fuel and Engine management MegaSquirt MS3-Pro engine management system BoydWelding stainless tank with fuel pump and sending unit, under bed tank New fuel line, Wix Filter, Russell fittings Wheels and tires Boss 20” rims, also have a stock set of nice GM 15x8 inch truck rims BFG G-Force Sport Comp2 245/45/20 fronts, 275/40/20 rears, less than 100 miles Brakes New Wilwood booster, proportional valve, calipers, pads and steel braided flex line kit New drilled and slotted rotors, new inline tube brake line Suspension and Steering All new Moog steering linkage components, CPP 7423 Front sway bar kit, POL tubular upper control arms, new Moog components for lower control arms CPP 50014 steering box New Belltech 4702 coil spring set, Belltech front and rear Street Performance shocks, POL front shock relocation kit Body Triplus cab corners, inner and outer rocker panels, new passenger inner fender Cab mount kit, radiator support mounts, new fender and bumper fasteners All new LED lighting and lenses, billet “8 LSX’ fender emblems, taillight trim, door handles, rear view mirrors Interior New OER carpet, new door panels, door and window rubber Grant Steering wheel New bench seat cover, Morris seat belts, new gas, brake and EB pedal covers Dakota Digital ECD-100 Electronic cable drive $12,000 no trades Located near Harvard Illinois 60033 https://rockford.craigslist.org/cto/...566419927.html
12-10-2022, 12:38 AM | #2971 |
12-10-2022, 12:39 AM | #2972 |
12-10-2022, 12:40 AM | #2973 |
12-10-2022, 12:40 AM | #2974 |
12-10-2022, 12:41 AM | #2975 |
