Old 12-11-2022, 01:58 AM   #526
jimbosprint
jimbosprint's Avatar
Thumbs down Re: '72 Cheyenne K10
This is not what I was hoping to find in the box.
I returned it.
EFI upgrade on hold.
jimbosprint is offline   Reply With Quote
Old 12-11-2022, 10:14 AM   #527
Jiggers72-GMC
Jiggers72-GMC's Avatar
That sux ^^^^ it almost looks used ........
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 12-17-2022, 12:56 PM   #528
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
That sucks.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 11-19-2023, 09:33 PM   #529
jimbosprint
Putting my old truck to work today. Picked up materials to redo the deck on the back of my house. 24 16ft Trex boards on the rack - no problem!
Old 08-06-2024, 10:48 AM   #530
jimbosprint
Took a trip out to the Thompson Fire area the other day to help a buddy recover some items from his RV. Good excuse to drive the 4x4.
Old 08-06-2024, 11:43 AM   #531
Ol Blue K20
Hopefully his stuff survived. Nice to see you post.
Dale
Old 08-08-2024, 09:36 PM   #532
best view
Thats the way I like to see them
best view is offline   Reply With Quote
Old 11-23-2024, 12:21 AM   #533
jimbosprint
Today I started a project that has been on my list for a little while - electric fans. The engine temp always stays cool while driving, but it gets warm in the summer sitting at idle for any length of time. This should fix that.
Cost for everything was about $600 with coupons, so this is not a cheap upgrade.
Parts:
- Maradyne Jetstreme 2 (MJS26K) dual electric fans
- Maradyne 185° fan controller wiring harness (MFA102)
- Jegs Jetstreme mounting brackets (555-52117)
- Vintage Air trinary switch (11086-VUS)
- Tuff Stuff 100amp alternator (7127D12)
As you can see in the photo below, the previous owner cut the bottom half of the shroud off to make clearance for the body lift. And yes, I know a new shroud might have solved the problem.
Old 11-23-2024, 09:21 AM   #534
landarts
landarts
That will be a good upgrade. Love the way your truck turned out.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is online now   Reply With Quote
Old 11-23-2024, 08:48 PM   #535
jimbosprint
I got the fans installed today and started on the wiring. It took two sets of brackets - I cut the end off of one set and used them as spacers so that the shroud would fit properly against the radiator. The bottom brackets just sit on top of the frame. I might drill and attach them to the bottom of the core support, but it seems really secure as is. The top of the fans are attached with 1/4-20 clip nuts to the top radiator brackets.
There's a stupid amount of room between the engine and radiator now. I like it.
Old 11-23-2024, 10:09 PM   #536
72 tigger
72 tigger's Avatar
Looks nice!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 11-24-2024, 04:42 PM   #537
jimbosprint
I finished up the fan wiring, but the fans didn't kick on when I tested it. I discovered the inline fuse for the fan relay was blown, so I replaced the fuse and the fans came on. I am letting the engine cool off a little then I will test it again.
The alternator that I ordered was not in stock, so I am still waiting on that.
And like I said yesterday, the space between the engine and radiator is huge.
Old 11-24-2024, 05:20 PM   #538
jimbosprint
It immediately blew another fuse.
After researching, I found in fine print on page 13 of a Maradyne sales brochure that the Jetstreme 2 (dual fan) requires a dual fan adapter harness (MFA111). It's a second relay for the second fan. I'll get that ordered and report back here when I have a chance to get it installed.
Name:  Screenshot 2024-11-24 150406.jpg
Old 12-02-2024, 08:41 PM   #539
jimbosprint
Today I installed the second fan relay. Credit goes to Maradyne for making it easy to connect to the first relay. Now both fans kick on without blowing fuses when I ground the sensor wire. I also swapped the thermostat housing with an adjustable one to make a little clearance for the sensor.
The new 100amp alternator is here, and I ordered a new alternator bracket which shipped today. I'll put a fresh belt on too.
Old 12-04-2024, 12:51 PM   #540
jimbosprint
I may have opened a can of worms.
Moving the upper radiator hose caused a leak. So it is off to the radiator shop.
And the Ebay seller made a label but didn't ship my alternator bracket. Probably didn't even have the part.
Old 12-04-2024, 10:21 PM   #541
jimbosprint
Ace Radiator here in town was fast to fix my radiator! $79 is a lot better than a new radiator.
It's all back together with a new lower radiator hose. I also used up the old can of engine degreaser that I had in my shed.
Still waiting on Ebay alternator bracket.
Old 12-06-2024, 03:56 PM   #542
jimbosprint
It is super frustrating that this factory alternator bracket does not adjust correctly. With the new alternator the belt is super loose adjusted all the way to the end of the bracket. I don't understand why at all, and I was mocked on Facebook for asking the question.
UPS finally has the Ebay bracket I ordered. Saying Monday.
Old 12-07-2024, 10:41 PM   #543
jimbosprint
The Ebay alternator bracket showed up today, but the tension rod is too long to attach to the bracket bolt and too short to reach the intake. I ordered a shorter tension rod from Amazon that should arrive tomorrow.
Changing the alternator is turning out to be more of a challenge than the electric fans.
Old 12-09-2024, 07:40 PM   #544
jimbosprint
It works!
The shorter tension rod is still almost too long, but it works. I think the bracket is ugly, but it works.
The fans kick on and off as necessary, the engine stays cool, and the battery charges.
And I got some cheap floormats.
ochre
