Old 12-24-2022, 10:39 AM   #1
Bones72Super
Bones72Super's Avatar
1972 C20 2 wheel drive GVW
I need a few pics of the GVW numbers on 1972 2 wheel drive C20 VIN tags. Your VIN number doesn't need to be in the pic just the GVW. Any help would certainly be appreciated. Happy Holidays!
WTB 71-72 Original paint Medium Red hood
WTB 1972 Very nice original Parchment seat belt set
Bones72Super is offline   Reply With Quote
Old 12-24-2022, 12:16 PM   #2
NorCalC20LWB
Re: 1972 C20 2 wheel drive GVW
Here ya go...
NorCalC20LWB is offline   Reply With Quote
Old 12-24-2022, 01:09 PM   #3
Bones72Super
Thanks! I need a few more examples y'all
Old 12-24-2022, 01:13 PM   #4
Bones72Super
Originally Posted by NorCalC20LWB View Post
Here ya go...
Did your truck come optioned with heavy front spring?
Old 12-24-2022, 01:27 PM   #5
NorCalC20LWB
I'm not sure about the springs, here's a pic of the SPID if that helps....
Old 12-24-2022, 01:30 PM   #6
jocko
jocko's Avatar
I’ve never seen a C20 (or K20) that was not 7500 lb GVWR - have had HO and D60 rear axles in them. But who knows. Had a 72 C20 with G50 Heavy Rear Spring and a K20 with G50 Heavy Rear Spring and F60 Heavy Front Spring - both were 7500 lb GVWR.
Old 12-24-2022, 02:25 PM   #7
factorystock
factorystock's Avatar
Interesting point jocko, but surely they all can't be 7500lb. AFAIK, if it had all the optional heavy duty equipment, it was rated at the max. 7500lb. For instance, Ford had a 6200lb, 6900lb and a 7500lb version of the F 250 during the same era, depending on the spring build up and tires.
factorystock is offline   Reply With Quote
Old 12-24-2022, 02:42 PM   #8
Bones72Super
Here's another with slightly different as manufactured vs max capability on the rear axle.
Old 12-24-2022, 03:18 PM   #9
jocko
jocko's Avatar
I certainly don’t disagree - I’d assume there are some different ratings out there, I’ve just never seen or owned one - so am very curious to see some new info (this was a great question Bones!). I’ve never even seen one with the lower as mfgr’ed # as posted above. Very interesting.
Old 12-24-2022, 03:52 PM   #10
Bones72Super
Heavy Springs may have been part of the" Custom Camper Equipment ". Jocko most likely will be able to shed some light on that
Old 12-24-2022, 08:55 PM   #11
mr.mud1
mr.mud1's Avatar
here's the plate on my 72 big block c-20 with a Dana 60 rear on leaf springs.the build sheet says G50 HVY Rear Spring,no mention of front springs.
mr.mud1 is offline   Reply With Quote
Old 12-24-2022, 09:18 PM   #12
Steeveedee
Who Changed This?
Steeveedee's Avatar
Same for my '70 BBC truck. It's a Longhorn, so 1T chassis and leaf springs. G50 HD Rear Spring. No mention of a change in the front. Except that my GVW plate has gone AWOL. The rivets are there, but no plate? Can't ask my F-i-L about it, he passed on in '09.
~Steven
Simi Valley, CA
Old 12-25-2022, 05:43 PM   #13
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I have 3, 3/4's. Two 71's and a 72. Here are my ratings.
71 Longhorn, 350 eng, HO rear. Leaf Springs
3000 Front
4700/5500 Rear
6700/7500 Total
71 Cheyenne (Mo Door) 402 BB, D-60 Rear, Rear Heavy Coils
3000 Front
4880/5500 Rear
6700/7500 Total
72 GMC 350 eng, SPID Painted over, Has TH350, D-60 rear, Leaf Springs
3500 Front
4700/5500 Rear
6700/7500 Total
Both my 71's have readable SPIDS.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 12-26-2022, 02:56 AM   #14
mr48chev
mr48chev's Avatar
It's going to depend on what tires and springs were on the truck when it was sold new.
As you can see here a C 20 could come with one of three gross weight capacities 6200, 6700 or 7500 depending on the wheel and tire combo and the rear springs that it has.
That found here in the 1972 Chevy truck PFD from the GM heritage center.
https://www.gm.com/content/dam/compa...olet-Truck.pdf
My ongoing truck projects:
Old 12-26-2022, 12:26 PM   #15
sloGMC
Do you have a specific question about how the GVWR works? It seems like it is typically something like this:
6200lbs - limited by base springs or base tires (3980lbs)
6700 lbs - upgraded rear springs (G50), limited by upgraded rear tires (4880lbs)
7500lbs - upgraded springs (G50), max upgrade tires, limited by rear end (5500 lbs) or other component
There are some variations in the "max rear weight at ground" if alternate tire/spring combinations were ordered.
1971 Pontiac Firebird
1971 GMC C2500
sloGMC is offline   Reply With Quote
Old 12-26-2022, 12:59 PM   #16
factorystock
Excellent documentation, thanks for posting!
Old 12-26-2022, 04:37 PM   #17
mr48chev
mr48chev's Avatar
I've posted it on the 47/59 group before but you can find the pfd for most years by scrolling down this list from the GM Heritage center archives https://www.gm.com/heritage/archive/...tion-kits.html
Old 12-28-2022, 12:07 AM   #18
Mike C
Mike C's Avatar
I’ve owned 4 different C20’s. The 69 GMC didn’t have the GVWR listed on it’s tag. The others were 6200 GVWR for a 127” wb, 6 cylinder 3 speed and 4.57 gears. A Longhorn 133” wb with 350, SM465 with a 6600 GVWR and a 400/TH400 127” wb with 7500 GVWR.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
