1967 3OTT transmissions?
What transmissions came behind the inline sixes with the 3OTT in 1967 C10's?
![]() Join Date: Oct 2009
Re: 1967 3OTT transmissions?
67 CS10 3OTTs:
Standard: Chevrolet synchromesh (2.94, 1.68, 1.00 and 3.14 reverse - only 2nd and 3rd were synchronized). Optional: Chevrolet fully synchronized (2.85 1st and 2.95 reverse) - this trans was standard for CE10. Optional: Chevrolet fully synchronized trans mentioned above - with overdrive. Hope that helps ![]() |
Well I was trying to see if it was a Saginaw or a M20, etc.....
Was looking to see what the torque rating on these transmissions are. I'm looking at a 1967, longbed Six cylinder/ 3ott, and getting up to speed on this year-only items. |
![]() Join Date: Oct 2020
It is a Saginaw, mine was similarlyequipped. I replaced that transmission with a M20, which is a 4 speed. The truck was converted to a floor shift back when my father-in-law owned it, so to me the M20 made sense...and it is period correct for the truck.
Here is a pic of my M20, I have since changed out the rods for the correct ones for the truck and eliminated the plate aluminumshifter mount and mounted the shifter on the tailcone like it should be: |
#5 | |
For a 68 I6 3OTT truck, there were only three possibilities - all posted above. Have you seen the SPID yet?
I "think" all the 3-speeds available in that year were Saginaw, but don't quote me on that... Don't know the torque ratings. Do the torque ratings matter? It's a 3OTT... none of them were made for racing but they're all stout enough for a 68 CS10. The real difference between the 3 3OTT possibilities isn't necessarily their torque ratings - rather it's just different variations of synchronization & 1st and Reverse gear ratios - and whether there is an overdrive gear. A 3OTT truck would not have an M20 RPO listed as that is a truck 4-speed option - generally the SM465 in 1968. Not to be confused with a car 4-speed of the same era, different animal. |
I haven't even seen the truck yet. The seller says it's a 292 with a 3OTT. I was doing homework to see how it was equipped.
#7 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
It gets confusing with GM using M20 for completely different transmissions.
#9 | |
a) Yes - RPO codes do get reused during different eras of production b) Also - the RPO code is not intended to indicate a specific brand or supplier. Even if the code is consistent (ie, "manual trans - non overdrive", or "Rear Axle - 3.42 ratio") it doesn't mean it's tied to a manufacturer like Dana, or New Process, or Saginaw or American Axle or whatever. Only the enthusiasts try to do that. K
HERE'S the gem. I suppose I could have done worse.
More
Engine 250
