Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 01-01-2023, 02:20 PM   #276
KFF 1
KFF 1's Avatar
Re: New project : 72 Suburban
Originally Posted by BAD1916 View Post
That turned out great! Hope you have a great New Years!
Thank you BAD1916. Happy New Year to you all !
KFF 1 is offline   Reply With Quote
Old 01-21-2023, 07:37 PM   #277
KFF 1
KFF 1's Avatar
My winter knit picking list is just about complete. Received the new throttle cable today and had to make a bracket out of the existing one on the TB. Tomorrow I should have the Burb back together and ready for when the weather turns nice in a few months
Old 01-22-2023, 01:28 AM   #278
LockDoc
The Older Generation
LockDoc's Avatar
That will be great if you can just jump in and drive it when the time comes....
LockDoc
Leon
Old 01-22-2023, 01:11 PM   #279
KFF 1
KFF 1's Avatar
Well the bracket I made yesterday was off by a country mile but thats what I get for getting in a hurry. So this morning I started all over again and now the throttle cable project is complete.
Old 01-22-2023, 01:12 PM   #280
KFF 1
KFF 1's Avatar
LockDoc
Yes sir Leon ! Burb is all ready just have to wait on the weather for a couple months now
Old 01-29-2023, 01:30 PM   #281
KFF 1
KFF 1's Avatar
Just getting around to posting this upgrade but before I do I want to give a shout out to LockDoc and 70 CST. I found out about this upgrade in a thread that was posted by 70CST and I wanted to post my results. I did the Jeep Wrangler headlight conversion with LED bulbs and it came out really nice. Thank you gentlemen, the upgrade looks great !
Old 01-29-2023, 11:15 PM   #282
3757chevy
3757chevy's Avatar
They worked well for me. https://67-72chevytrucks.com/vboard/...8&postcount=59
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 01-30-2023, 01:11 AM   #283
LockDoc
LockDoc's Avatar
Good deal! I have not had any trouble with mine and they work good.
LockDoc
Leon
Old 02-04-2023, 12:11 AM   #284
Average Joe
Average Joe's Avatar
The Burb looks great. I may have to copy that LED Jeep conversion in mine.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 09-02-2023, 07:59 PM   #285
KFF 1
KFF 1's Avatar
This coming winter I plan to make some changes to the Suburban as far as the motor, so I started researching a hydro boost conversion. I also reached out to member LockDoc who was very helpful with tips and info he had acquired during his conversion. For my conversion I used the hydro booster from a 2004 3500 box van. Junkyards are pretty non existent where I live so all i could source was the pump itself from a salvage/used auto parts yard. The lines I purchased at Napa for a 2003 Chevrolet 2500 (info compliments of LockDoc) After some tweaking at the power steering pump and a slight adjustment at the steering box the lines fit very well. I did remove the oring end for the steering box and double flared the end with the standard fitting end. Came out nice and the Suburban has NEVER stopped like it does now. So phase one is now complete and I dont have to worry about vacuum for the brake system.
Old 09-02-2023, 11:09 PM   #286
D.B
D.B's Avatar
That's great. I have a few questions you might be able to answer for me.
Did you change master cylinder or keep the one you originally had.
The firewall mounting. How did you mount the hydro boost.
The brake pedal rod. Did you have to make one or did the one from the 2004 3500 box van work.
D.B is offline   Reply With Quote
Old 09-03-2023, 07:08 AM   #287
KFF 1
KFF 1's Avatar
I used my 3/4 ton MC. You use the mounting plate on the hydro boost to mount it to the firewall. You will have to drill some holes and mb weld some holes up. The brake pedal rod I just modified by cutting the eye off of the hydro boost rod then used the end of the rod off the vacuum booster and welded it together. Some guys weld a piece to the brake pedal itself the redrill the hole as well. Do a search on here and there are a couple threads that go into greater detail than what I did for this conversion.
Old 09-03-2023, 08:55 AM   #288
kev2809
low n' slo
kev2809's Avatar
sounds like a nice upgrade! mine stops a little sluggish too, I figured because I have over sized wheels. I might have too look more into this down the line
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 09-03-2023, 08:40 PM   #289
LockDoc
LockDoc's Avatar
Glad you got it finished up. Looks like a good install.
LockDoc
Leon
Old 09-18-2023, 06:30 PM   #290
KFF 1
KFF 1's Avatar
This past Saturday we went on the Ohio Historical Bridge Cruise with the C-10 Club of Ohio. 70 mile trip 7 covered bridges. Nice ride, great group of people. This was the 5th year for the cruise and this year was the largest group so far with 31 trucks total.
Old 10-03-2023, 02:18 PM   #291
LockDoc
LockDoc's Avatar
Per our conversation here is the steering box re-seal thread I used. It was posted by TX Firefighter.
http://67-72chevytrucks.com/vboard/s...d.php?t=619634
LockDoc
Leon
Old 10-03-2023, 06:02 PM   #292
KFF 1
KFF 1's Avatar
Thank you Leon, I owe you one
Old 10-03-2023, 10:30 PM   #293
LockDoc
LockDoc's Avatar
No problem....
LockDoc
Leon
Old 10-21-2023, 04:27 PM   #294
KFF 1
KFF 1's Avatar
I started on the winter tear down on the motor in the Suburban today. Made some good progress and I have it down to the long block so far. Had to remove the intake and strip it down so that it can be port matched to the heads and then flow tested as a unit. Tomorrow I may continue on it and try to get the heads removed and possibly get the cam and lifters out but at this point I am undecided. No hurry, I have plenty of time to get it back together, I may tackle the steering box rebuild while waiting on parts for the motor.
Old 10-21-2023, 07:43 PM   #295
LockDoc
LockDoc's Avatar
I always enjoyed doing that if I had plenty of time. It sounds like you do so that is good.....
LockDoc
Leon
Old 10-22-2023, 02:18 PM   #296
KFF 1
KFF 1's Avatar
More progress made today. I have the motor down to the short block and took the old camshaft out, then installed the new one so that much is done. now its just a waiting game for parts to start coming in. I did discover that number 3 plug wire was burnt. It wasnt burnt through to the point of causing a misfire but its bad enough to where Im going to have to make some changes to get it away from the header when I replace the wires. Hopefully that is the only gremlin I find the rest of the way
Old 10-22-2023, 11:23 PM   #297
Madkidd007
Madkidd007's Avatar
For headers on an LS, Taylor wires with the 45 degree boots are the best option. Not the traditional big one with the T logo, but the thinner grey color end
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 10-28-2023, 07:53 PM   #298
KFF 1
KFF 1's Avatar
Didnt get to work on the Suburban very long today but made some progress. Parts have been coming in here and there this week so tomorrow we are planning on changing the converter and getting the short block set back in and that will probably be it. Heads and intake should be finished up soon so hopefully in a couple weekends the motor will be back together.
Old 10-28-2023, 07:58 PM   #299
KFF 1
KFF 1's Avatar
Yes went with the 45 degree boots and even with the heat boots on I now have plenty of room. Set the head on the bench and bolted the header to it so I could mock up the wires, worked out nice.
Old 10-28-2023, 10:50 PM   #300
LockDoc
LockDoc's Avatar
Sounds like you are working yourself out of a job.... You better slow down....
LockDoc
Leon
