Old 01-15-2023, 05:44 PM   #3201
Wikid61
Wikid61's Avatar
Re: Post Your Craigslist Finds Part 2
2wd
Factory 402 Big Block
Turbo 400
Tilt Wheel
Original Blue paint
Clean Title
$6000 OBO
If interested please contact me at
(760) 7zero5-7four33 Call or text only. I will not look for or answer emails.
Thank you,
Cliff 1971 Chevy C20 2wd - $6,000 (Ramona) https://sandiego.craigslist.org/nsd/...578800895.html
"Envy is a declaration of inferiority". Napoleon Bonaparte.
Wikid61 is offline   Reply With Quote
Old 01-15-2023, 05:45 PM   #3202
Wikid61
Wikid61's Avatar
https://sandiego.craigslist.org/nsd/...578620049.html 1971 Chevy Suburban - $24,500 (Fallbrook) Beautiful custom restoration. 350 motor with auto 700r4 trans. Headers, 40 series flowmaster exhaust, shaved doorhandles, nice sound system, bluetooth/subs. Boyd wheels. New edelbrock carb. Very nice interior, overhead Air conditioning from front to rear. Ready to drive anywhere. No smog ever needed. Current registration, clean title. Asking $24500, much more invested.
Old 01-15-2023, 05:59 PM   #3203
Wikid61
Wikid61's Avatar
1972 Chevrolet 3/4 Ton Custom Camper Factory K20 4X4 Truck. Has a built bored 383 V8 / Jet T-700 overdrive transmission. Plenty of new or rebuilt parts that was done over time including rebuilt NP205 transfer case & front end. Currently not running, has been sitting for 10 years but ran fine when parked years ago. It cranks over (I have a video of engine cranking) the normal procedure of getting it running would need to be done as flushing all fluids including gas tank, gas lines & carb rebuilt ect. Rare K20 project truck ready to restore or get it running & drive with some patina. Asking $13,400
Has clean CA title, Protect-O-Plate, manuals & service records 1972 Chevrolet K20 Custom Camper 3/4 Ton Truck Factory 4X4 Patina - $13,400 (Lakewood, Ca) https://losangeles.craigslist.org/lg...578846022.html
Old 01-15-2023, 06:02 PM   #3204
Wikid61
Wikid61's Avatar
Prior owner did engine/trans swap.
L92/6L80, Dakota digital gauges, remote start, 2000 Watt inverter, aux battery sys, 4 whl hyd disc brakes, Vintage Air/heat, 1 piece pwr windows, pwr locks, tilt column w/shift, steering whl, carpeting, bluetooth radio, speakers, amp, alarm, LS radiator/electric fans, electric fan trans cooler, tuffy security box, backup camera is full-time rear view mirror, new badging and side molding
Starts up easily and runs great! 51 yr old vehicle does have a few minor chips and I removed the external antenna. 1972 GMC Jimmy 4WD - $55,000 (Beaumont) https://losangeles.craigslist.org/la...578836685.html
Old 01-15-2023, 06:03 PM   #3205
Wikid61
Wikid61's Avatar
1972 C-10 Stepside, Very clean older restoration, repaint of original Hugger Orange,
32K on rebuilt 350, 2K Bowtie 700r4 replaced the original 3 spd,
vintage AC installed lower in the engine bay to look stock and works as should,
original points distributor converted to HEI,
1963 corvette intake with a 4 barrel carb,
re worked trailing arms and 2" c notch in frame to lower the rear, spindles and springs use to lower the front,
shifter is still on the 3" shortened steering column,
painted guage cluster looks clean, I have a new stock black and chrome cluster if you want,
all guages including tach and lights work except reverse lights, never hooked up after auto trans installed
re uhpolstered seat and door panels with black carpet and gas tank cover all in great shape,
vintage looking stereo in dash with 10 disc cd player and speakers under the seat, dash speaker works as well,
17" wheels with BFG G-Force Comp-2 radials
front disc brakes and drums in the rear, 3.73 posi differential
painted bed to match truck with snap on tonneau cover
clean under carriage, has dual glasspack exhaust,
the clutch pedal is still installed with the trans crossmember, I was going to remove when the new exhaust went in,
I have a complete 2 1/4" exhaust kit, ceramic shorty headers, camel hump heads, HEI distributor and plug wires available
this truck runs great and is in great condition for its age but has a few flaws in the paint, most work done in 1987,
very nice driver and always parked inside since then, cover is included,
$36,000
Don. call or text for more info-see pics for number
may trade for 67-69 camaro, 63-67 non post nova, 68-72 corvette in similar condition 1972 C-10 - $36,000 (Chino Valley) https://prescott.craigslist.org/cto/...578403728.html
Old 01-15-2023, 09:18 PM   #3206
Wikid61
Wikid61's Avatar
https://losangeles.craigslist.org/la...578528425.html 1970 Chevy C10 big block long bed ( man size) - $27,500 (Somerset) 402 big block, recent rebuild, factory tach, original paint, clean body, very original unmolested truck. Had a camper shell on it most of its life. I am the second owner, had her for many years, just no longer use her. No a/c. Has high compression heads on it, but I also have a standard set. Uses only premium fuel. She is a long bed.
Old 01-16-2023, 08:05 AM   #3207
Wikid61
Wikid61's Avatar
https://denver.craigslist.org/cto/d/...578498466.html 1972 Chevy C10 - $8,500 (Keenesburg) 1972 Chevy C10
4 wheel drive
454 engine
Tires In excellent condition
New duel exhaust
Serious inquires only.
Cash only.
Clean Title in hand
Call To set up time drive and take a look!
do NOT contact me with unsolicited services or off
Old 01-16-2023, 05:15 PM   #3208
Wikid61
Wikid61's Avatar
https://portland.craigslist.org/mlt/...578934856.html 1967 Chevrolet Pickup C10 - $30,000 1967 Shortbed Chevy C10 Pickup for sale. I have owned this truck for 20 years with no regrets. Truck has a 496 stroker Big Block with 650 hp and a 350 auto Transmission built for the horsepower. Ford 9" tubed rear. Real fast street truck
No disappointments. Too much to list
Old 01-16-2023, 05:17 PM   #3209
Wikid61
Wikid61's Avatar
https://portland.craigslist.org/mlt/...579113534.html 1967 Chevy shortbed - $6,500 (Se Portland) Project-1967 Chevy shortbed
3” chop
No motor or transmission
Very little rust
Great body
$6500 cash or 7500 trade
Send pics of trade offers
Old 01-17-2023, 01:56 AM   #3210
Wikid61
Wikid61's Avatar
https://sfbay.craigslist.org/pen/cto...578881757.html 1971 chevy c/10 pickup - $25,000 (daly city) 1971 chevy c/10 shortbed stepside,was a 307 v8 with a 3 speed now has a targetmaster 350 with turbo 350 automatic,power steering.power brakes,aftermarket power windows, sliding rear window, bed cover,truck has leaf spring rear suspension,heavy duty rear bumper,american racing wheels, original owner,original paint, truck has been garaged since new any questions just ask
Old 01-17-2023, 02:21 AM   #3211
Wikid61
Wikid61's Avatar
1972 Chevy C10 - $10,000 https://southbend.craigslist.org/cto...577854023.html 1972 Chevy C10 V8 4 barrel carburetor, manual 3 speed. Runs and drives. $10,000 or best offer. If
Old 01-18-2023, 01:43 AM   #3212
Wikid61
Wikid61's Avatar
https://pittsburgh.craigslist.org/ct...579364148.html 1971 Chevrolet C-10 Long Bed 2wd - $22,500 (Canonsburg) 1971 Chevrolet C10 Cheyenne Long bed 2wd. Came from Texas in 2020. New suspension (2''/4" McGaughys drop), gauge cluster, carb, rebuilt driveshaft, completely rebuilt transmission, radiator and new inspection. Fresh A/C charge. Clean truck! 22,500 obo
Call/Text: 724 - Six One Two - Four One Nine Two
Old 01-18-2023, 01:46 AM   #3213
Wikid61
Wikid61's Avatar
https://allentown.craigslist.org/cto...579430355.html 1971 Chevy c10 c20 - $14,500 (Jim Thorpe) Deciding to sell my 1971 c20 long bed. I purchased it about two years ago for cruising around on nice days and runs to hardware store but I am starting a business and could use the extra capital. It is an automatic trans with a Chevy 350. Just had the mechanic in town do a tune up and new plugs and wires. The entire truck Has been restored. I cruise up and down the turnpike with no issues, no rotted panels as they were replaced during the restoration. Paint is good but shows some signs of age here and there. It’s a great truck to drive as is. Everything works with no quirks that are often found in the older cars and trucks. Give me a call if you have any questions.
Old 01-18-2023, 02:19 PM   #3214
Wikid61
Wikid61's Avatar
reply
favorite
hide
flag
share
Posted 31 minutes ago
print
1967 Chevrolet C10 Stepside Shortbed - $23,000 (placerville Selling the pride and joy!
1967 Chevrolet Stepside Shortbed
350 Crate motor purrs.... 5000 miles on motor
New automatic transmission
Not Factory Air conditioning
new heater
Disc brakes on front
no leaks, no squeak's
Dual Exhaust
Small rear window
New Paint no dents...scratches
heavy duty bumper
must make appointment to view this
located in the Placerville area
I can send a video of it running so you could hear the sound
do NOT contact me with unsolicited services or offers https://sacramento.craigslist.org/ct...579884317.html
Old 01-18-2023, 02:20 PM   #3215
Wikid61
Wikid61's Avatar
https://sacramento.craigslist.org/ct...579691205.html gmc - $20,000 (Pine grove) 1969 gmc c/10 this vehicle has a fresh built 383ci stroker motor. With a 400 turbo hydromatic transmission. Interior is clean and custom seats, new wheels and tires it’s not perfect but on its way..
Old 01-18-2023, 02:22 PM   #3216
Wikid61
Wikid61's Avatar
https://modesto.craigslist.org/cto/d...579531273.html 1968 Chevy - $49,000 Could be the last one out here!
Let's go for a ride!
1968 Chevy CST Shortbed......... Rebuilt 327, New 350 Turbo Auto., Rebuilt 3:08 Posi, PS, PDB, AC cab (non op) Bucket Seats, Tilt Column, Tachometer, SoftRay Tinted Glass, New Coker Tires, Dual Exhaust, New Brakes....... plus much more! Very minor almost non-existence area of rust, but the cleanest rockers, cab corners and floors on a 55-year old factory painted truck, plus no radio cut out or unsightly speaker cut outs! Definitely worth taking a look at....... Looks awesome as is with a slight lowered (correctly) stance. Turns a lot of heads wherever it goes, something very stock this nice is hard to find nowadays. No hurry to sell, $49K will negotiate some with a cash in hand buyer!
Old 01-18-2023, 02:35 PM   #3217
Wikid61
Wikid61's Avatar
https://sfbay.craigslist.org/sby/cto...579380769.html reply
favorite
hide
flag
share
Posted a day ago
print
1968 Chevy C10 - $15,500 (san jose downtown 1968 Chevrolet C-10 ORIGINAL SHORT BED stock 350 edelbrock carb A/C runs and Drives relocated tank very rare truck it’s in very good shape Clean Title $15,500 Firm No trades Cash Only No Rush To Sell Price Is 200% FIRM Thanks For Looking Any Question Feel Free To Text Serious Buyers Only!!
Old 01-18-2023, 02:36 PM   #3218
Wikid61
Wikid61's Avatar
https://reno.craigslist.org/cto/d/re...579235782.html 1968 El camino 383 stroker - $25 (Reno) Finished the rebuild in 2020.
383 stoker motor billet surpentine belt system, edelbrock performer heads and intake manifold, 700R4 transmission
Ac, disc brakes front drums rear. Bucket seats horse shoe shifter.
Dakota gauges, graiger wheels, air shocks
check the photos out for more.
Only selling because I need the money to finish my new build.
I have just under 50k into the el camino. Super straight rust free body,
Took me two years just to find a clean car body,
$25-000
Text or phone, no emails
Old 01-18-2023, 02:37 PM   #3219
Wikid61
Wikid61's Avatar
https://sfbay.craigslist.org/eby/cto...579380494.html 1968 GMC Half Ton Handy Van Original Patina - $3,900 (dublin / pleasanton / livermore) Hello guys I’m selling the perfect opportunity to restore or leave it as is and make it a business opportunity because it’s a blank canvas you can do what you want . It’s a 1968 gmc half ton panel van , it’s all complete & there engine does run but does need some assistance maybe a new carburetor, has clean California black plates since new , these are getting more rare & pricey every year, here’s a chance to grab it at a steal of deal. If interested best to call no emails 9️⃣2️⃣5️⃣-2️⃣5️⃣2️⃣-5️⃣9️⃣3️⃣0️⃣ serious buyers only thanks
Old 01-18-2023, 02:42 PM   #3220
Wikid61
Wikid61's Avatar
https://merced.craigslist.org/cto/d/...579681664.html 1972 Chevrolet Suburban - $20,000 (Atwater) 2005 Chevrolet 5.3 vortex engine
Leather seats
New Tires and Wheels
Any questions feel free to call or text
Old 01-18-2023, 02:45 PM   #3221
Wikid61
Wikid61's Avatar
Runs great 350 bf goodwrench crate motor with stick shift.new full clutch kit with new pressure plate.brand new soft 6 inch lift kit with new shocks.new wiring harness everything is hooked up and works except heater,stereo and windshield wipers just needs hooked up. gages work except gas gage.theres alot of new stuff that has been replaced too much to list. Has rust on inner fender under battery.no other rust. Has some dents not too bad with that said it needs some body work and interior work. Tags up to date with clean title in my name currently on non op. This is a bad ass truck. $12,500 obo https://visalia.craigslist.org/cto/d...579334706.html 1972 gmc k10 custom 4x4 lwb - $12,500 (Woodlake)
Old 01-18-2023, 02:50 PM   #3222
Wikid61
Wikid61's Avatar
https://sacramento.craigslist.org/ct...579610282.html 1972 GMC 4x4 - $20,000 (Pine Grove) 1972 GMC 4x4 K25 383 stroker motor w/ 350 th transmission. This truck is in good shape and runs
Old 01-19-2023, 08:44 PM   #3223
Wikid61
Wikid61's Avatar
https://sfbay.craigslist.org/eby/cto...580065025.html 1972 C10 chevy truck - $15,500 (fremont / union city / newark) C10 long bed front wheel disc brakes 350 v8 automatic runs on 20” rims and registered.
Runs great power steering conversion. Brand new gas tank and sending unit.Truck body is in excellent condition. Downsizing on my projects im too busy at my shop.
No nickle and diming it is what it is Price is firm.
If i dont sell it, ill continue restoring the truck. Pink slip on hand.
Call only Text will be ignored.
(510)552-nine two two seven.
Old 01-19-2023, 08:48 PM   #3224
Wikid61
Wikid61's Avatar
https://phoenix.craigslist.org/nph/c...579651050.html 1970 Chevy K-10 SB 4x4-350 AT Factory AC Solid Desirable Project - $22,500 (Scottsdale) 1970 Chevy K10 SB 4x4 - Factory 350 Automatic with factory AC. 350 Motor, AT tranny and the desirable 205 transfer case is out of the truck but I do have everything. PS, Power Brakes, rear slider, auxiliary gas tank, lock and hubs. The body is straight with very old paint. Some minor rust in the floor but overall very solid K10.
Has the original SPID ( build sheet ) on top of the glove box.
Over all the truck is pretty complete.
Great desirable project.
Clean Arizona Title.
This is a original K10 short bed 4x4.
$22,500.
If serious please leave your phone number and I will get right back with you.
I can get you a great wholesale price on shipping if you need that service.
Thank you.
Old 01-19-2023, 08:55 PM   #3225
Wikid61
Wikid61's Avatar
https://phoenix.craigslist.org/evl/c...580358018.html 1967 Chevrolet C10 Short Bed Step Side - REALLY NICE! - $35,000 (Mesa) Please read entire ad. Don't ask if it's available as I'll assume you're a scammer. Call or text # within the photos.
I bought this truck last year and have found my interests are different now and I'd hate to have her sit in the garage and not get enjoyed.
- 1967 Small Window Step Side
- 383 Stroker
- 700R4 Transmission
- AC/Heat
- Recent Resto
- no dents or damage
- Paint is good but not perfect
- Gear drive timing
She's a really nice truck but please don't expect a 50-60k truck, otherwise I'd be asking 50-60k. She runs good and strong but does have some drips here and there. I guess I'm saying don't expect a perfect truck. She's really nice but not perfect.
If you want a truck that gets looks and "thumbs up" driving it, this is it!
35,000 OBO.
Clean/Clear title in my name.
I'll accept cash coming directly from your bank or bank wire.
