01-16-2023, 11:27 AM | #1 |
Engine shut off ?
I was puttering around on a new project (71 C10) with a 350 motor , was running like butter then I turned around to grab something out of the garage and it was like someone turned the key off ? no sputtering or rpm difference it just shut off and wouldnt re-start . Its getting fuel and has a new fuel filter . Has an HEI not points . Any Ideas ?
01-16-2023, 11:38 AM | #2 |
Re: Engine shut off ?
The HEI has a module that can go out. It’s very common, so much so that I have been known to carry a spare in the glove box. You can test it.
01-16-2023, 02:10 PM | #3 |
assuming fuel pressure is good, I suspect HEI module.
Have you confirmed you have spark OP? By chance did the choke not open if it has one?? |
01-16-2023, 02:53 PM | #4 |
Put the putter back into it. You must've dropped it when you turned around.
couldn't resist |
01-17-2023, 12:04 PM | #5 |
Thanks for the advice , I will try the module.
01-17-2023, 12:14 PM | #6 |
if you replace module, use heat sink paste under it. Its $2 at AutoZone
01-19-2023, 07:06 PM | #7 |
Replaced the ignition module , still no start . Started messing around with the wires , found out the lead wire from the H.E.I. had somehow fallen out at the ignition cylinder ? plugged it back in and it fired right up ! Thanks to all those who commented and helped .
01-19-2023, 07:40 PM | #8 |
keep the old module as a spare
01-19-2023, 10:34 PM | #9 |
01-19-2023, 11:34 PM | #10 |
Diagnose the problem rather than throwing parts at it.
1. Check for spark. Timing light works well 2. If no spark check for 12V at HEI dizzy. 3. If 12 v at dizzy then try ignition module
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com Last edited by rockyrivermark; 01-19-2023 at 11:47 PM. |
