01-26-2023, 12:50 AM | #1 |
ride height help ?
Could I get a few of you to get me a couple measurement?
I am looking for the Front SHOCK installed height. Centerline of mount bolt to Centerline of mount bolt. In the REAR I am going to run a 5" rear drop spring. So, I am looking for a 5" drop SPRING installed height. I am assembling a 67-72 shortbox truck frame and would like to mock things up at ride height. I'm going with a 4-1/2"-Front & 5"-Rear drop. Running a 4-1/2" front total drop by using a 2" drop spring and a 2-1/2" spindle. But anyone with a aftermarket (not cut) 2" drop spring will work. Looking for the SHOCK installed height. Centerline of mount bolt to Centerline of mount bolt. Then in the REAR I am going to run a 5" rear drop spring. So, I am looking for a 5" drop SPRING installed height. Could a few of you get me these measurements? Looking for this measurement while your truck is sitting on the ground at everyday ride height. Also...If any of you have 6" rear spring, feel free to let me know that measurement. Just let me know what rear drop spring you have. Front Shock Installed Height= ?? Rear Spring Installed Height= ?? Thank you
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 02-01-2023 at 07:31 AM. |
01-26-2023, 05:18 AM | #2 |
Re: ride height help ?
I cannot help with actual measurements as I do not have a 2wd. Can say that stock length shocks will work in your application, even with cut down bump stops. A shorter shock is only needed if bump location is raised.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
01-26-2023, 08:04 AM | #3 |
Can't help with the measurements but be sure to look closely at your front travel.
I bought a 68 SWB that was dropped in the front with springs and it was sitting on the bump stops. Had no suspension travel at all in the front.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
01-26-2023, 02:37 PM | #4 |
Thank you for the input.
But, I am simply looking for these dimensions to mock up a ride height. I have or will address the issues you both have mentioned, as this is not my first build. I simply do not have the installed height of these 2 things. So, still looking for any of you running a 2" front lowering spring and/or a 5" rear lowering spring... are any of you able to get me the 2 dimensions referenced in the 1st post? Thanks
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 02-01-2023 at 07:26 AM. |
01-26-2023, 11:15 PM | #5 |
My 69 is a small block and auto. It's on ECE 2" springs and 2.5" spindles. Center to center of the shock mounting bolts is 11.5" The rear is apart right now for trailing arm paint and bushings.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project Last edited by basketcase; 01-26-2023 at 11:25 PM. |
01-29-2023, 10:54 PM | #6 | |
Anyone else out there able to get me these dimensions?
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
02-01-2023, 07:33 AM | #7 |
Anyone else...
Still looking for a 5" rear drop spring installed height.
02-01-2023, 12:36 PM | #8 |
Some of this might help .
https://www.qa1.net/tech-center/tech...avel-do-i-need I wanted Bilsteins my 67 has 2 1/2" drop spindles I cut 1 coil off of factory 292 front springs I ended up with a 12 1/2" installed height of the front shocks that put the front shock travel at 2" off the bump stops and 2 1/2" before the shock will bottom out right in the middle of the shocks travel , I'm running 255x70x15 tires so it should work fine . on the rear I have 5" drop springs and rear shock relocators the top of the wheel opening measures 28" with a wood bed and empty rear fuel tank . So with a full tank of gas the fender should hide the top 2" of tire +- filling out the wheel well . https://www.suspensionlifts.com/shop...et-c10-pickup/ http://67-72chevytrucks.com/vboard/s...d.php?t=684343 Posted by GMC PAULS 1/6/2016 Re: Quality Shocks for 3/5 drop " I'm surprised none of our customers have responded as we've told all that ask. ANY, I REPEAT AMY, shock that is made for your stock 1967-72 truck at normal ride height is ALSO the correct shock for those trucks with front & rear drop kits of ANY DROP Height. So if you use 1-5 1/2" drop in the front you still use the same shock. If you use 1-6" drop in the rear you still use the same shock. ECE, No limit, Classic, Brothers, everyone is selling shocks that are made to stock travel specifications. Now your asking why this is true. The reason is with any of the drops I listed above the stock shocks minimum & maximum travel distances are not exceeded. Since the shocks travel limits are still within spec, the stock shock length is still used. NOW in the rear once you hit about a 5" rear drop the shock has become to horizontal to absorb vertical travel effectively. So you then install rear shock relocators in the rear to make the shocks more vertical again so that they can then absorb the vertical travel of the truck. ( It's also my understanding though I have not tried it yet, that if you move the rear lower shock bracket from left side to the right, and the right side to the left this will also correct the shock angle back to a more vertical position eliminating the need for rear shock relocators. ) But again I've not checked this myself on just swapping the lower mounts from 1 side to the other. I'm just reporting what I've heard from several low budget builders. So everyone should determine the type of ride that you want based on you and your driving habits then look up the shocks and look for comfort, sport, off road etc.... based on your driving style & preference's and then purchase the stock shock for your truck in that type of shock. KYB GR-2 soft comfortable ride, KYB gas a just shocks give a firmer ride , etc..... Then buy from who you choose. If your already buying parts from 1 location and the shocks they have only cost a little more than the cheapest place you've found get the shocks from where your buying your other parts unless your getting free shipping. Hope everyone is Healthy, Happy, & Prosperous in 2016 and beyond. http://67-72chevytrucks.com/vboard/s...d.php?t=693745 Paul @ GMCPauls " __________________ Secure Online Catalog for-GMCPauls Truck Parts Email- GMCPAULS@GMAIL.COM2016
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
02-01-2023, 11:34 PM | #9 | |
Let's say, before you installed the springs in your truck they measured 11" tall... then you mounted them in the truck, mounted up all the shocks, wheels & tires and drove around the block. As your truck sat in the driveway or possibly currently sitting in your garage. That spring, compressed mounted in the frame measures... what? So, from bottom of spring to top of spring. Thanks
02-03-2023, 02:48 PM | #10 |
I have that exact drop on my lwb 72 right now.im at work, but I'll see if I can get you a measurement later today or tomorrow.
Fwiw the truck has an aggressive rake. More than I like, but I anticipated using a 1" lowering block for more flexibility in tire sizes when if all gets dialed in. Also, it depends on what shock mounts you'll decide to go with too. I'm using ECE lowers, but haven't drilled out the rivets for the upper mounts yet. |
02-03-2023, 04:03 PM | #11 |
Installed height of the 5" drop coils is 7 1/2" between the lower frame rail and the top of the trailing arm 67 short bed with wood floor and empty rear fuel tank , upper rear shock relocators and I also used the earlier lower shock mounts for the double shear mounting vs single shear of the stock 67-72's .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 02-03-2023 at 04:38 PM. |
02-03-2023, 04:57 PM | #12 |
This picture shows a 4' level on top of the bed rail , Once the rear bumper is installed along with some gas it should be close to level .
02-05-2023, 07:37 AM | #13 |
Awesome... Exactly what I was looking for. Thank you so much.
02-05-2023, 07:40 AM | #14 | |
