Old 02-14-2023, 12:02 AM   #1
86k10
2002 Tahoe starts and then dies
I'm working on an 02 for a friend of mine and he said after replacing the battery it started doing this. The only code I find is a 1626. I put a new GM ignition switch in it and nothing changed. The security light also stays on even when the key is removed. Also the automatic head lamps dont come on when you turn the key on but you can turn them on manually. The dome lights dont work and neither does the remote. Has anyone ever experienced this? I have read a lot and watched a lot of things but nothing covers what issues I am having.
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
Old 02-14-2023, 02:30 AM   #2
EVRLET
EVRLET's Avatar
Re: 2002 Tahoe starts and then dies
You need to do a passlock reset. Plenty of info and videos out there on the procedure.
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 02-20-2023, 06:30 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
To reset Your 2002 Chevy Silverado security system put the key in the ignition, turn the key to the on position, and leave it on until the security light goes out.
Usually abut 15 mins.
Once this happens crank the truck without turning the key backward, just turn to start.
This will reprogRam the transponder from the ignition switch.
To prevent someone from using a fake or non-registered key, GM installed an anti-theft system called Passlock.
When the wrong key or other tool is used to crank the ignition, the Passlock system disables the truck's fuel system.
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2025 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 03-03-2023, 09:48 PM   #4
86k10
That procedure doesn't work, I haven't done anything with it for a while and am still looking for an answer.
98 Neon
97 Grand Prix GT
86 GMC 5.0
77 Olds 98 6.6
Old 03-04-2023, 04:58 AM   #5
Just call me Sean
Just call me Sean's Avatar
The answer is that the security system is malfunctioning. I had to defeat it on mine.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 04-02-2023, 11:41 AM   #6
truckdude239
truckdude239's Avatar
so this works on some but most time its a 30 mins relearn so connect a charger to the battery
,1. Insert a master key (black head) into the ignition switch.
2. Turn key to the “ON ” position without starting the engine. The security light should
turn on and stay on.
3. Wait for 10 minutes or until the security light turns off.
4. Turn key to the “OFF ” position for 5 seconds.
5. Turn key to the “ON ” position without starting the engine. Security light should turn
on and stay on.
6. Wait for 10 minutes or until the security light turns off.
7. Turn key to the “OFF ” position for 5 seconds.
8. Turn key to the “ON ” position without starting the engine The security light should
9. Wait for 10 minutes or until the security light turns off.
10. Turn key to the “OFF ” position. The key transponder information will be learned on
the next start cycle.
11. Start the vehicle. If the vehicle starts and runs normally, the relearn is complete.
12. If additional keys need to be relearned, turn the key to the “OFF ” position.
13. Insert the next key to be learned. Turn the key to the “ON ” position within 10
seconds of removing the previously used key.
14. Wait for security light to turn off. It should happen fairly quickly. You may not notice
the lamp as the transponder value will be learned immediately.
15. Repeat steps 12 through 14 for any additional keys
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
