Old 02-15-2023, 01:25 PM   #26
mongocanfly
mongocanfly's Avatar
Re: No start issue
I have already checked pin/wire location and continuity from what psi sent me
This is what I got from them
And the are correct going by this
Here is the wiring, check all three wires for continuity
BROWN TO BLUE PCM PLUG 73
PINK TO BLUE PCM PLUG 61
RED TO GREEN PCM PLUG 39
PLUG LABELED A,B AND C
But i needed to know which of the 3 is signal wire...
And I agree , I need all the help I can get..haha
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-15-2023, 03:36 PM   #27
biketopia
Re: No start issue
hope this helps
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 02-15-2023, 04:24 PM   #28
mongocanfly
Re: No start issue
Thanks..that does help.. I saw several pics like this, but they were all diff wire colors and pin functions..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-15-2023, 04:31 PM   #29
RustyPile
RustyPile's Avatar
Re: No start issue
^^^^^^^^^ I agree^^^^^^
{EDIT} I don't know how my post ended up this far down the thread.. I intended it to appear as post #26, right below Acelo's post #25..
RustyPile is offline   Reply With Quote
Old 02-15-2023, 05:42 PM   #30
mongocanfly
Re: No start issue
Pin C..red..has 12v with switch on
Pin A...brown...has 12v pulse while cranking
So cam sensor is working..
And I've got 12v pulse from crank sensor while cranking
So crank sensor is working..
Sighhhhhhh...
I'm bout ready to burn it to the ground
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-15-2023, 05:55 PM   #31
RustyPile
RustyPile's Avatar
Re: No start issue
Sighhhhhhh...
Where did you take these readings?? You should check Both signal wires (cam sensor and crank sensor) at the ECM plug.. This will determine if the wire has continuity..
Old 02-15-2023, 06:02 PM   #32
LS short box
Re: No start issue
I hate wiring also.
So is it maybe time to put it on a trailer and take it to some one with HP Tuners? They should be able to see what is working and what isn't.
Old 02-15-2023, 06:42 PM   #33
mongocanfly
Re: No start issue
Rusty, I did check them at the ecm plug...I backpinned the wires there.
LS, I agree.. thats probably the next step..
I've got alot of putting together before it can leave my shop though
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-15-2023, 08:43 PM   #34
RustyPile
RustyPile's Avatar
Re: No start issue
Have you discussed with PSI the possibility of a defective harness?? Since the ECM will run in another vehicle, the problem almost has to be with your vehicle..
Something is preventing the ECM firing the injectors.. Sounds like the ECM is "seeing" a wrong feedback somewhere... Pick a shop that has the experience working with these type issues and possibly one that has experience tuning (modifying) GM engine management systems.
Old 02-15-2023, 08:56 PM   #35
mongocanfly
Re: No start issue
Yep
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-15-2023, 10:10 PM   #36
LS short box
Re: No start issue
On my first LS swap a 79 Camaro I brought it to the chassis dyno tuner with no doors, no front sheet metal, no glass and the radiator support just kind of hanging on. It was a pretty basic LS1 swap but it allowed me to drive it after the tune so I could get it to the muffler and alignment shop. Took it back later to the tuner for a few touch ups on the trans shift points.
Old 02-16-2023, 08:53 AM   #37
Joyridin
Re: No start issue
Did you double check the cam sensor wires and/or crank wires to see if they are in the correct location? If they are crossed, you might have an issue there. I saw it on another forum where his harness from PSI had the cam sensor wires crossed and it would not start.
Just a thought.
Joyridin is offline   Reply With Quote
Old 02-16-2023, 10:01 AM   #38
mongocanfly
Re: No start issue
I checked the wiring pin location once....but I havnt doubled checked it..
But I will
The tuner guy said hes seen 3or4 harnesses in the last yr with wrongly pinned plugs
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-17-2023, 08:21 AM   #39
Joyridin
Re: No start issue
But I will
If I read the story correctly, the wires were crossed at the sensor, not at the computer. I had that happen once on a LS3. Two of the wires going into the MAP sensor were crossed. It wouldn't start.
Old 04-19-2023, 12:53 PM   #40
Rich84
Rich84's Avatar
Re: No start issue
Any updates?
Rich84 is offline   Reply With Quote
Old 04-19-2023, 05:09 PM   #41
mongocanfly
Re: No start issue
no... i put cranking on the backburner to try and get my painting finished..
ive got a tuner guy thats gonna look it over when i get ready
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-15-2023, 10:07 PM   #42
RustyPile
RustyPile's Avatar
Re: No start issue
What's the latest on the no start? Any progress?
Old 05-15-2023, 10:33 PM   #43
mongocanfly
Re: No start issue
Still trying to fix my primer disaster..
Mongo...aka Greg
RIP Dad
RIP Jesse
