The LuvShack Garage
Are Shock Extenders needed since axle is closer to the frame ???
*Ordered some, not even sure they are right, and may not need. Trying to button up all the parts so I can 6/8 this thing real soon.
Owner/Op: "TN Classic Transport Carriers" Daily Driver: "HerNameIsRio" 68 GMC SWB The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Toy Hauler: "Feathers" 14 Aluma 8218T |
#2 | |
Re: Flip Kit Question - 88 C3500
You want shock mounts extenders.
The LuvShack Garage
Thanks, appreciate the feedback...
Junior Member
![]() Join Date: Apr 2012
Correct, even with shorter shocks I still needed the extenders after the axle flip.
The LuvShack Garage
Have any pics? (No directions in the box)
You'll want the lower shock extenders as well as upper shock relocators.
Weird GM design thing.... the driver side shock dimensions @ the frame vs the rear end are different vs the pass side (about a 4" difference). On my 3/4 ton (HD/8-lug), I used the lower extensions, modded the pass side upper placement (to be closer to the driver side dimensions), & got the Bell Tech upper relocation brackets. http://67-72chevytrucks.com/vboard/s...d.php?t=817106 The flip yields an easy 8" of drop. I added lift shackles to dial in a 5/7 drop so it's still useable.
The LuvShack Garage
| Bookmarks |
| Thread Tools | |
| Display Modes | |
