Old 08-10-2004, 12:53 PM   #1
68 Suburban
68 Suburban's Avatar
Polyurethane Panhard Bushings?
Does anyone know where I can get polyurethane panhard bushings for my stock panhard bar?
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 08-10-2004, 01:06 PM   #2
FormerMember
www.classicheartbeat.com
Ordered mine from Wes.
FormerMember is offline   Reply With Quote
Old 08-10-2004, 01:11 PM   #3
Custom 68
Custom 68's Avatar
chris
I think I got mine from GMCPauls. Yep found the receipt the PN was J-RTAB302 for the "Track Arm Bushing" This was actually in 2002 so you probably could check the number.
They were 17.00 at the time
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 08-10-2004, 01:12 PM   #4
68 Suburban
Thanks guys.
Old 08-10-2004, 04:12 PM   #5
cdowns
cdowns's Avatar
my local autozone,pepboys and advancedauto all carry them over the counter
Old 08-10-2004, 11:15 PM   #6
68 Suburban
are they pretty much the same for all GM vehicles that call for them?
Old 08-11-2004, 07:23 AM   #7
JJR
JJR's Avatar
The Energy Suspension part number is 3.7104 (60-72 Rear Tracking Arm Bushing Set). You re-use the outer sleeve of your existing bushings. I got my set at the local parts store for under $10. My original bushings were shot so you could shake the bed side to side and get a lot of movement (and a clanking noise). The new poly bushings made things tight again.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 08-11-2004, 02:08 PM   #8
68 Suburban
Is for the actual panhard bar, or is this the number for the trailing arm bushings? Thanks
Old 08-11-2004, 02:23 PM   #9
JJR
JJR's Avatar
That is the part number for the 1/2 ton panhard bar (tracking arm) bushings. The part number for 3/4 ton panhard bar is 3.7116 . The part number for the rear trailing arm bushings is 3.3123 . Here is the link for Chevy 2wd Trucks: http://www.energysuspension.com/pages/c2wd1.html
