69 c/10 lwb fleetside
2002 s10 wont run after new distributor install
got a call from a buddy this morning wanting me to install a new dist. after his had started making alot of noise. took the cap and and it had alot of slop in it, so went to oreillys and got a new dist. assembly i marked where the rotor was pointing and raised it up and marked it after it spun.
dropped the new one in but the oil pump didnt engage fully so i turned the motor with ratchet untill it dropped down, went to crank it and it just grunted and struggled to turn over like it was out of time. so i pulled the dist back out and put it on top dead center, atleast i think so. i dont see no timing tab on the engine like in the picture that i attached. but i have the first balancer mark on the ridge on timing cover and can feel the 2nd mark up where the tab shows to be on the pic. i confirmed that it was the compression stroke by putting finger over the #1 plug hole. reinstalled the dist and does the same thing. for giggles i aligned the 2nd balancer mark with the timing cover ridge #1 and 3 on the pic, the truck cranked right up and idled good so i took it back to my buddy, on the way once i got on the highway and around 45mph it would have a shutter to it, would go away when i accelerated. i thought maybe that was just a already existing problem, but he called and told me that the truck wasnt idling right and was shuttering pretty bad. he drove it back here to the house and it died as he pulled it into the shop from rough idling. any help on what i am doing wrong? any and all help is appreciated. thanks in advance.
69 lwb fleetside 67 swb fleetside (2) 72 lwb fleetside 50 swb no bed 65 impala ss 65 1 ton flatbed
#2 | |
Re: 2002 s10 wont run after new distributor install
Check for codes. I'm sure it will tell you the distributor isn't installed correctly.
i got the gunked scraped off of the timing cover and found the upper tab mark, according to the marks i had it timed up perfect.
after i made sure it was on compression stroke i noticed that the piston wasnt at tdc when the marks where lined up, so i turned it over untill it was tdc and put the dist. back in and it runs like new now. the timing marks ended up being at 6 and 3 oclock instead of the 4 and 1 like supposed to be. could the chain be wore that much to throw the balancer marks off that much, or has it had a timing set installed and they didnt get the chain and sprockets timed right, thats the only 2 options i can think of
You didn't mention which engine you're working on. It may be that the marks are used to set the distributor timing and they don't actually indicate TDC. Some new engines are that way.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
just realized i didnt post what the problem ended up being, and it could help somebody later on.
the marks on the balancer ended up being wrong for whatever reason. i felt of the #1 piston and it wasnt at tdc yet so i turned the motor untill it was and then put the dist. back in and it ran like new again. so dont just trust the marks on the balancer.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
