![]() Join Date: Jul 2000
AAW Classic Update kit -- ALT, BAT, and panel feed wiring
I'm trying to decide how I want to wire the charging and panel feed circuits on my 69 C10. The kit comes with a "charging" sub-kit with 6 gauge (!) wire and 175 amp fuses that is total overkill for me. I'm actually considering using 10 gauge wire, which is one size larger than stock, or possibly 8 gauge, which I used on an 82 C10.
As for routing, I may just duplicate the factory routing from battery to alternator, but use a maxi-fuse instead of a fusible link near the battery. I do not want to feed the alternator and fuse panel off of the starter BAT terminal, because things are very tight down there with my headers. What have you guys done? The truck probably draws no more than 30-35 amps through the fuse panel with everything turned on. No killer stereo, power windows, or radiator fans. The Vintage Air system is powered directly off the battery through a breaker.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
![]() Join Date: May 2012
Re: AAW Classic Update kit -- ALT, BAT, and panel feed wiring
I installed a classic update from AAW also. Here's what I've done, and it's in anticipation of heavy amp draw.
I ran a 4 gauge alt wire. I bypass the starer and go straight to the battery. I have a 200 amp breaker inline to the bat. I also grounded the crap out of everything winch related with heavy gauge welding wire. I know you're not running a winch but this is my deviation from stock. I would go ahead with their instructions if no need to deviate. Then you will have instructions to pass on to the next owner, or even yourself a few years down the road. But I'm always a fan of overkill whenever I have my hands on someting... But I often find myself scratching my head a few years down the road wondering why I did things off the beaten path! ![]() j
White K20 |
#3 | |
By feeding the Vintage Air system directly from the battery does not take any load off the alternator. Any current draw taken from the battery HAS to be replaced by the alternator, no matter where the "draw point" is located. All current consumption is "replaced" through the wire connecting the alternator to the battery. Not to sound argumentative, but I find it hard to believe there is only a total of 35 amps going through the fuse panel. Besides that, headlight current doesn't pass through the fuse panel. The headlight switch is feed directly, but separately, through a fuse link from the battery.. On average, and I don't know exactly how much current your system draws, but I'd guess more along the lines of 40 - 55 amps. Remove the main feed wire from the starter and move it to a buss bar mounted near the battery. I suggest you run an 8 ga. wire between the alternator and battery. Run a 10 ga. wire from the battery to the fuse panel. If you're running an internally regulated alternator, connect the voltage sensing wire to this wire near the bulkhead connector. Tie these circuits in with the existing feed to the headlight circuit and you should be fine. |
Yeah, I'll at least need some notes a few years down the road. Sometimes I can't even remember what I did yesterday!
#5 | ||||
As for headlight current draw, you're correct that it's not through a fuse, but it is through the fuse panel BAT bus which is fed by the single fuse panel feed wire. The switch itself has an internal breaker. Quote:
Not sure what you mean by the second statement. As I mentioned above, the headlight switch gets power from the fuse panel BAT bus. But thanks for your comments and suggestions. ![]()
#6 | |
The idea for the modifications is to provide sufficient wire sizing in the charging circuit to handle the higher output produced by the alternator. Current flow through a wire is similar to water running through a hose.. The hose can very easily be too small to provide sufficient flow for the job at hand, but there won't be any problems if the hose is too large. As you mentioned, the 6 gauge wires are probably "overkill" for your application, but on the other hand, 10 gauge might not be big enough.. |
#7 | |
I just confirmed the above on my old stock harnesses, which are now laying on the floor and not connected to each other. One red wire from the "splice" feeds the battery buss. Then the headlight switch and ignition switch are on the same buss. No separation at all. Maybe that isn't the case for a 67-72 C20??? I do know that on my old 82 C10, there were two separate 12 volt wires feeding the fuse panel, and maybe the configuration is as you described, but I never looked at it. Photo shows the GM "splice". Just a little crude, huh? It was wrapped in a thick rubber-like tape. The black wire was one of two used used to send a voltage drop to the stock ammeter (which is really a -/0/+ voltmeter).
#8 | |
The point I'm making and trying to phrase it so you understand, is that every single electron of current (amperage) used by an electrical system has to be replaced by the alternator or the battery will run down.. The wire feeding the current from the alternator back to the battery has to be heavy enough to handle those electrons. You seem offended because I didn't agree with your total electron count (amperage of 35 amps).. It wasn't my intention, and I so stated at the beginning of that statement, to argue the point or start a pissing match. |
I mentioned the 82 truck wiring as an example of a fuse panel fed by two 12-volt feed wires.
Just in case my eyes and ohmmeter were deceiving me, I went to a factory wiring schematic. It shows a single 12R (red, 12ga) 12-volt feed wire running from the battery, through a fusible link, to the bulkhead panel. Along the way, on the driver's side of the radiator, it connects to the alternator via the splice I mentioned earlier in this thread. However, the 12-volt feed wire does not connect directly to the fuse panel battery bus, as I said or implied, but instead it runs through the dash harness to another splice (buried in the harness). From that splice, 12ga red wires run to the panel battery bus, the ignition switch, and the headlight switch. So yes, headlight current does not run through the fuse panel battery bus, but it does run through the single 12ga wire feeding the fuse panel, headlights, and ignition switch. So, that feed wire IS a valid place to measure current draw, including headlights, unless relays are used. Do you have a factory schematic showing two 12-volt red feed wires used on late 60s/early 70s cars and trucks? All I can find is variations on the routing I mentioned above. The two main differences are where the horn relay was mounted, and where the 12-volts was picked up -- starter terminal, horn terminal, or splice. Happy Motoring!
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 03-12-2023 at 07:06 PM. |
#10 | |
Mike, what is it you're trying to accomplish? In your original post you asked about the gauge requirement on the charging circuit.. I've answered that question.. If you're wanting to debate current flow, how or where to take the readings, then, I'm sorry... I'm done here.. |
