Old 08-11-2004, 01:04 AM   #1
skokie
skokie's Avatar
Starter and exhaust pipe distance
With a stock setup of 2 inch pipe coming from a ramhorn exhaust manifold that is angled down. How far is the pipe supposed to be from the starter?
skokie is offline   Reply With Quote
Old 08-11-2004, 02:12 AM   #2
skokie
skokie's Avatar
Forgot to add. How far is the exhaust pipe supposed to come down from the exhaust manifold before it straightens out and goes toward the end of the truck.
Old 08-11-2004, 10:02 AM   #3
skokie
skokie's Avatar
Ttt
Old 08-11-2004, 04:12 PM   #4
skokie
skokie's Avatar
Ttt
Old 08-11-2004, 04:18 PM   #5
thisolechevy
I am not sure on rams horns, I have hedman headers and mine are VERY close 3/4" and I have to have a heat shield installed and a mini starter.
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 08-11-2004, 05:47 PM   #6
krue
Designated A-hole!
krue's Avatar
If it's not raining I will check and try to get a pic of mine when I get home.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 08-11-2004, 05:59 PM   #7
skokie
skokie's Avatar
Thanks Krue, I appreciate it.
Old 08-11-2004, 07:16 PM   #8
crazy longhorn
Fabricate till you "puke"
I have Hookers, & 1 tube is within 1/8 " of the starter.....doesnt cause a bit of problem here in the midwest with 95- 100 degree temps IMO, set the exhaust up as tight to the bottom of the truck as you can, fit it(within 1/2" of the crossmember).....just make sure there is enough room to drop the starter out , if you need to. if that 2 " tube is 1/2 - 3/4 " from the starter, it shouldnt cause any problems best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-11-2004, 08:49 PM   #9
krue
Designated A-hole!
krue's Avatar
Here's what I came up with. I have ramhorn manifolds and what I assume is the stock y-pipe.
www.daveramsey.com
Old 08-11-2004, 10:55 PM   #10
skokie
skokie's Avatar
Thats about the distance I have on mine but its not a y I have duals.
Thanks Krue
I apprecaite the pics.
