Old 03-19-2023, 09:43 PM   #101
tim_mc
tim_mc's Avatar
Re: Lets see the engine pics!!
Wow - lots of great engines! Mine is tame by comparison to most, but fine for my '67 farm truck: GM 350 crate motor w/Brodix IK180 aluminum heads, Comp Cams hydraulic roller cam & lifters, Edelbrock Performer EPS intake & AVS2 carb. I dressed it up a bit with a pair of GM Corvette LT-1 valve covers.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 03-19-2023, 10:11 PM   #102
Extended Power
Extended Power's Avatar
Try a couple more of the new engine:
Trying to get the jist of posting pix.
So, this engine was a 572/620 engine with very low miles.
But, I figured, if I’m going through all the trouble of installing a new engine, I may as well go through it first.
I sold the GM aluminum heads off of it, and bought a set of AFR 335v2 heads.
Then I messaged Chris Straub, and asked if he could make me a nice solid roller for the street.
He asked me what kind of horse power I was looking for, and when I said around 700-750, he just last he’d and said, “That’s it?”
I said it only has 9.6:1 compression.
He said we can make a lot more then that if you want it to.
Make it at least 750 then, I said.
So with the cam, I got solid lifters, which took eight months to get, due to Covid.
The Jomar stud girdle fits perfect.
I had to buy another set of taller rocker arm studs, as with the proper length pushrods, the nuts were nearly on by four threads.
Smith Brothers 7/16” x .120” pushrods.
And a set of Straub Tech roller rockers.
This is a gen 6 block, and I’m using a double roller timing chain from Straub Tech as well.
Had to get a different front cover, and modify a cam button for it.
Lots of, one step forward, two steps back, on this build.
Headers are from Dan Lemon, Lemon’s Headers. (2 1/8” primary, down to 3 1/2” collectors)
Edelbrock Super Victor intake.
And more I’m sure I forgot to mention.
Extended Power is offline   Reply With Quote
Old 03-20-2023, 04:32 PM   #103
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
It's a .060" over 427 with forged JE domes, L34 closed chamber heads, Comp Magnum roller rockers & rods, Clay Smith 304 solid cam, Howards EDM lifters, Hedman Elite headers. L34 forged crank balanced w/rods & pistons to "dead nuts" Motor for "Nasty Sally" 72 LWB C/10 400THM 12-bolt 4:56 Posi...Low 11's in the 1/4.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 03-20-2023, 04:55 PM   #104
WHYBYNU
WHYBYNU when old will do
WHYBYNU's Avatar
My ZZ6 installed 1 year ago. Drove it on power tour 2022.
71 Cheyenne super
2 tone green and white
ZZ6 - Th350
4/6 drop
20x8.5 / 20x10 Billet Specialties
WHYBYNU is offline   Reply With Quote
Old 03-21-2023, 02:57 PM   #105
schovil69
Here's a before, after, and nearly complete.
schovil69 is offline   Reply With Quote
Old 03-21-2023, 04:40 PM   #106
LS short box
Pic of the 68 I did a frame off. LS6/T56 combo.
Old 03-22-2023, 04:14 PM   #107
OregonNed
OregonNed's Avatar
A couple recently after I tidied up the plug wires.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 03-24-2023, 06:54 PM   #108
54blackhornet
54blackhornet's Avatar
Boy you guys are a tough act to follow ! Incredible workmanship…
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 03-25-2023, 05:45 PM   #109
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
No kidding right. Amazing.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-25-2023, 07:57 PM   #110
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1679788519
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
