Old 03-30-2023, 07:19 PM   #1
1968chevyfever
Need help cross referencing pitman arm
Hello, I’m rebuilding the front suspension on my 1967 c10 2wd shortbed pickup with manual steering. I need help decoding the pitman arm casting number in my truck and cross referencing it to a modern pitman arm part number. The casting is 3889239A. Anybody know what that old part number shows up as?
1968chevyfever is offline   Reply With Quote
Old 03-30-2023, 07:54 PM   #2
RustyPile
RustyPile's Avatar
Re: Need help cross referencing pitman arm
You're making it hard on yourself. No need to "decode" anything. Took me less than 2 minutes. I went to the Moog website, entered your vehicle information and came up with this part number.. K6130.. Summit among others can get it for you..
https://www.summitracing.com/parts/mog-k6130?rrec=true
RustyPile is offline   Reply With Quote
Old 03-30-2023, 09:13 PM   #3
Grumpy old man
Grumpy old man's Avatar
This list may help on other parts you may need .
These are the parts I used on my 67 C-10 , Always double check part #'s before ordering . When I swapped out the manual steering and drum brakes
Moog parts from rock auto
2- Moog upper ball joints - K6023
2- Moog lower ball joints - K6024
1- Moog Pitman arm - K6131 -- Power steering
1- Moog idler arm - K6096T
2- Moog lower control arm shafts - K6147
2- Moog upper control arm shafts - K 6098
2 - Moog tie rods - ES 370R
2- Moog tie rods - ES 350L
2- Moog tie rod sleeves - ES 350S
From Summit
Summit price matches so you can find these parts listed on Ebay and save $$ Ordering Cpp parts thru Summit gets you fast free shipping
1- Classic Performance 2.5" Drop Spindles CP4S2 ( L&R)
1- Classic Performance Upgraded Disc Conversion Rotors CP4R-6 (L&R)
2- Classic Performance Wheel Bearings CP4B
2- Dorman Axle Nuts 4993
For power steering gear I used https://shop.advanceautoparts.com/p/...omer-reviews-d
With a lares coupler (rag joint) https://shop.advanceautoparts.com/p/...rm=201+coupler
order online with Advance discount code and save 25 % and pick it up from your local store
Old 03-31-2023, 06:46 PM   #4
1968chevyfever
Grumpy old man, thank you for the complete list. Very helpful from someone who has been down this road!
1967, c10, pitman arm, shortbed
