#26 | |
Re: Firewall or Under Floor Mounted Master Cylinder?
This is the style of mount I have in my 51. Hydroboost may have been better but I didn't want the extra hoses.
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
#27 |
I mounted my booster on my street rod underneath and I never cut a hole in the floor, never liked that idea. Here's my truck's engine with the booster on the firewall and I think it looks fine and easier to maintain. My .02 worth
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
#28 | ||
![]() Join Date: Sep 2002
I don't plan on hiding the AC and heater hoses coming out of the firewall so I think a few components on either side of the engine will look fine. I think I have decided to go with a vacuum booster on the firewall. I just need to finalize the mounting method. |
#29 | |
Laid it out on chip board and traced it. Then put the old pedal arm down and sloooooowly ground and filed down until they mated. Pinned, then tapped the pin holes. Counter sunk screws. Less than 1/16" inch movement thru stroke. Took an entire weekend. I hate it when I come up with these screwy ideas, only to spend hundreds of hours building. Still beats the best day at work though.
Chip '51 Chevy 3600 5 window C4 Vette front/rear suspension & drive train full Rusto-Mod ![]() '92 GMC Sonoma GT VIN #0015 '91 GMC Sonoma GT extended cab 1 of 1 |
#30 |
![]() Join Date: Mar 2007
I have had it both way. Currently I have a Wilwood unit mounted on the frame under the body. Once you get your system bleed and assuming you have no leaks there is really no maintenance or reason you need to be fooling with it much. I made a metal cover wrapped in the same leather as my interior. It fastens to the floor utilizing nutzirts in the floor. My floormat covers over this access door. I just wanted at well thought out/functional solution.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#31 |
There are plenty of remote reservoir systems out there to be able to easily fill under the floor master cylinders without a hassle.
#32 |
Guess which one this Ogre used
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#33 |
if you get a master cyl with the plastic reservoir you can use the push in hose connectors and a remore reservoir from something else. like Ogre did. just make sure the master cyl matches the brake system you have, disc disc, disc drum, drum drum etc.
#34 |
there are also kits that give you an aluminum cap to put on a standard style cast master with wire clips for cap. The cap has 2 hose connections and a remote reservoir.
Could make your own with a piece of plate, a drill, tap and some hardware store fittings. |
#35 |
I opted for the firewall for a couple of reasons, but admit that under the floor is cleaner.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
#36 | |
#37 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. Last edited by Rickysnickers; 04-15-2023 at 09:38 AM. |
#38 |
nice job. everybody knows you need brakes so a booster on the firewall isn't so bad after all, is it? hydroboost gives awesome boost too.
#39 |
I'm staying with the under cab setup. I have Wilwood 12.88" disk with 6 piston front and 4 piston rear. I'm running a Wilwood master and prop valve with remote polished reservoirs and hydraulic throwout bearing on my Tremec TKO 600. Duel diaphragm booster with Leed vacuum pump because of my 6-71 on my 292. I'm running electric P/S from EPAS Performance and a 1.5 steering quickener on stock column and box. I'm also running an electric A/C compressor from RenCool in Australia that mounts under the truck with a hortazontal mount remote condenser and spal fan. I have lots of shiny stuff on my 292 and want to keep the engine compartment looking stock. JMHO.
#40 |
mick, if you put the master under the hood all that shiny stuff would burn the seals outta the master, lol.
your stuff looks awesome by the way. gonna need sunglasses to look under the hood on a sunny day. nice job with the pics too. |
