70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Where does this wire attach ?
Okay so took a zillion pics when taking stuff off the truck for the upgrades but I guess not of everyhing.This pic is of the heater core box and although remembered where the connector went not sure about the wire. Obviously a ground wire and thinking it goes behind one of the bolts holding the connector on. Can someone verify this is correct and if not please tell me where it goes. 72 Truck with factory A/C..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: Dec 1999
Re: Where does this wire attach ?
The relay grounds through it's casing/bracket. You are correct that the ring terminal is fastened under one of the relay mounting screws.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Thanks.
