Project Heaven in my 67!!!
Headers and engine mount headaches…
67 c-10, lowered. Wanted headers that weren’t long tube for ground clearance issues. Ordered a set of chevelle mid length headers as many people on the forum said they fit perfectly and come out perfectly in line with the frame.
Truck is an original 2wd, and now has a 350/350 in it. Correct sbc mount perches and engine mounts from the 67. Headers won’t fit in between the frame and engine block. It almost appears the engine is sitting too low in the bay. Is there a solution or am I just stuck trying to send these headers back and ordering something else? |
#2 | |
Re: Headers and engine mount headaches…
It's a big job to trim the frame if the truck is all put together and some disassembly is required, but it can be done.. If you use a torch, just be sure you don't set fire to something... Otherwise, just keep shopping for headers that fit... |
Hedman 69010 are midlength and fit between the frame rails.. I have used them on 67-72 and Squarebody trucks with factory frame mounts and they fit great.
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
IM using Doug Thorleys. A bit pricey, but fit and work great.
Steve ___________________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=618848 |
What brand headers are you using? Got pictures?
![]() Join Date: Feb 2016
The PO of my 67 Burban installed some Chevelle headers and used a torch to get them to fit. Apparently he didn't have a grinder or any paint to clean up the mess after he torched the frame. See photos of the slice out of the passenger side and the piece off of the drivers side motor mount stand.
I'm not advocating this kind of work but it hasn't caused any problems other than of being visually annoying. I did go in and grind and paint the areas when I had the engine out so it's quite a bit less annoying than it was. I don't know what brand but I believe the were for a 71 Chevelle.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#7 | |
I wonder if I could use some tubular engine stands and solve the drivers side figment issues and I had already planned on removing 1/2” (roughly) from the passenger side frame rail in order to install a big block when it is done being built (building it slowly as $ permits so I get exactly what I want) |
The PO of my BBC equipped truck had it set up for the dragstrip. Solid Morroso front engine mounts along with a funky transmission crossmember made for a bad ride on the street. I removed all those parts and install POL engine mounts.. I have cast iron exhaust manifolds so I don't know how headers would fit...
https://www.performanceonline.com/19...-Brackets-V-8/ |
#9 | |
#10 | |
I removed the fan clutch and fan shroud. Hooked an engine hoist to the engine and lifted it slightly. Removed all the Morroso stuff and bolted in the POL parts. Let the engine down and everything lined up perfectly.. [EDITED to add additional information] OEM motor mounts fit POL mount brackets or they offer an assortment of mounts that also fit.. https://www.performanceonline.com/19...engine-mounts/ Last edited by RustyPile; 04-12-2023 at 02:43 PM. |
The Older Generation
Headers should clear stock '69-'71 big block frame brackets. They have a dip where HO455's brackets are cut.... LockDoc
Ok, so after looking at the mounts and stands I decided that I was going to use the big block aftermarket stands and mounts. Not tubular but cnc plasma cut. Summit brand. (Mainly because there’s a summit in Arlington and I can go pick them up) after I trim the passenger side frame rail and get those installed I’ll let y’all know if everything played out right.
