Old 04-30-2023, 04:12 PM   #1
hairball
Steering wheel
My 1965 C10 has the original standard steering wheel. I would like to find an exact copy but in a smaller diameter. Does anybody make such a thing? I do have power steering so I can use a smaller diameter. Maybe there is sometime available that is close? Thanks in advance.
Hairball
hairball is offline   Reply With Quote
Old 05-01-2023, 12:41 AM   #2
62bagger
62bagger's Avatar
Re: Steering wheel
I wanted the same thing for my 62. I looked into having the original cut down but the starting price was $450.00. I couldn't bring myself to spend that. I now have an aftermarket steering wheel.
62bagger is offline   Reply With Quote
Old 05-01-2023, 10:09 AM   #3
61hawk
61hawk's Avatar
Re: Steering wheel
I don't know of a smaller wheel that's identical, about the closest you're going to find is a 65-66 Chevy Impala steering wheel. They're about 16-1/2" in diameter and are being reproduced and I think are a better looking wheel.
61hawk is offline   Reply With Quote
Old 05-01-2023, 11:06 AM   #4
theastronaut
theastronaut's Avatar
Re: Steering wheel
I've modified a few wheels by cutting the rim off, grinding back the plastic to the steel inner frame, and grafting on a donor rim from a random 15" wheel found on ebay, junkyards, etc. After welding the steel cores together, I use PC7 epoxy to build up the missing areas, cracks are ground out to the steel core and filled in, then primed with SPI epoxy (sticks to plastic and works as a high build all in one), then wetsand and paint it with single stage urethane.
theastronaut is offline   Reply With Quote
Old 05-01-2023, 12:25 PM   #5
Braunschweiger
Re: Steering wheel
This is great, this is fantastic work.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 05-01-2023, 01:06 PM   #6
rideblue00
rideblue00's Avatar
Re: Steering wheel
The cut down method is the only way to get an original look, many have done it successfully. Do some research on here, I think there is a thread on this topic.
rideblue00 is offline   Reply With Quote
Old 05-01-2023, 07:49 PM   #7
62bagger
62bagger's Avatar
Re: Steering wheel
That looks great. I might have to experiment with my wheel. Thanks for showing your technique.
Old 05-01-2023, 08:01 PM   #8
SkinnyG
SkinnyG's Avatar
Re: Steering wheel
Here's my technique:
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 05-04-2023, 05:51 PM   #9
vin63
It's Better With Nitro
vin63's Avatar
Re: Steering wheel
This is how I've done a few for my projects, including the steering wheel in my current 63 C10. I did this one at the beginning of the pandemic since I was stuck at home. This one went to a customer in AZ.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-04-2023, 06:49 PM   #10
FamilyTruckster65
Re: Steering wheel
Vin,
It appears that there is enough flex in the plastic on the rim that it didn't crack much when you re-bent it to the smaller diameter. Did you do anything special other than bent and weld?
FamilyTruckster65 is offline   Reply With Quote
Old 05-05-2023, 09:28 AM   #11
verdell
verdell's Avatar
Re: Steering wheel
Astronaut,
Would you happen to remember the donor vehicle wheel you used on these exact photos?
verdell is offline   Reply With Quote
Old 05-05-2023, 01:44 PM   #12
61hawk
61hawk's Avatar
Re: Steering wheel
Originally Posted by verdell View Post
Astronaut,
To me it looks like a '55 2nd Series Chevy truck wheel.
Old 05-05-2023, 02:10 PM   #13
verdell
verdell's Avatar
Re: Steering wheel
The 15" DONOR rim from ebay, junkyards, etc. used to make the finished product is what I'm asking about. Apologies if that wasn't clear.
"donor rim from a random 15" wheel found on ebay, junkyards, etc."
