#2326 |
Re: My 52 GMC Build
Got the front end back on, need to align the hood a bit but it all fits with a bit of room to spare lol. Now once the salt is going to go away I'll order the tuner and do a test drive.
Monday we did a 7hr road trip across the border to Detroit Steel rims to pick up my friends 20x8 delray rims he is putting on a 1987 Chev van, we stopped at our tire shop and got 2 mounted up with a low white wall. Can't wait to see these on the van. While we where there we talked with the owner Adam and right hand man Steve for about an hour. What a nice bunch of guys who are very passionate about what the build. Gave them some positive feed back on my Ambassador style rims I have had on my truck for 4 years.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#2327 |
Re: My 52 GMC Build
Well after needing new door seals for 2 years (they where falling off) and not liking the ones I put on in the first place, the new seals are installed and doors are back on. So far I like them they close much easier don't have to slam. The foam is softer than the others, they are from "Soff seal". I recommend!
#2328 |
Re: My 52 GMC Build
No weatherstrip adheasive to mess with either?!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
#2329 |
![]() Join Date: Jul 2012
Re: My 52 GMC Build
It looks good with front coming back together!
#2330 |
Re: My 52 GMC Build
OH the seals are so nice to work with, I used the same seals on the black '52 I built worked great for the summer we had that truck.
I ordered my programmer/ tuner today should be here in a week or two just about right for a test drive. ![]()
#2331 |
Re: My 52 GMC Build
Today would have been a great day for you to take it out Bob
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 ![]() |
#2332 |
Re: My 52 GMC Build
Ya I know, I wish. I'm waiting on the programmer to come in to make it run properly with the modifications I made to the motor. But I will take it around the block Friday to check out the other parts.
#2333 |
Re: My 52 GMC Build
Well quick update: I got the tuner installed and got the speedometer calibrated I have about 50mi on the new setup now. I have been driving around on the lowest power setting I have, I have yet to floor it and the amount of power scares me.
![]() Still playing with some suspension adjustments and braking in the transmission before I see what it can do.
#2334 |
Re: My 52 GMC Build
Very cool!
#2335 |
Re: My 52 GMC Build
Sounds like you need to put on a dino
#2336 |
Re: My 52 GMC Build
send it!
#2337 |
Re: My 52 GMC Build
Yes I will get it on the dyno probably end of July also to the drag strip Maybe
#2338 |
Re: My 52 GMC Build
Ok so I was fighting an oil leak at the front of the motor, and getting pissed because I though it was the front main seal that I did replace it. Bad enough it was getting on my brake rotor and wheel. Turns out it was the 2 seals I did not change because I could not get the plugs out. It is for the high pressure oil rails in the heads which control the injectors, 3500psi. The plugs where rusted in and not leaking at the time of rebuild. A couple of heat cycles and higher than stock pressure and yup.
So to get them out I had to take the front accessories off and die grind around the plugs then get my impact to get them out, the drivers side did not move with my snap on 1/2" had to brake out the big Makita 3/4", and they only get torqued to 60ftlb. As you can see the seal does not look very good. Drove it to work today, all seems good.
#2339 |
![]() Join Date: Feb 2020
Re: My 52 GMC Build
Wow. Very interesting project. Not a lot of room left under the hood!
#2340 |
![]() Join Date: Mar 2007
Re: My 52 GMC Build
Leaks are the worst. At least you located the source and are on your way to sealing it up...It is always something.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#2341 |
Re: My 52 GMC Build
never fails!
#2342 | ||
Re: My 52 GMC Build
Of course, wasn't to bad to fix.
#2343 |
Re: My 52 GMC Build
Well maiden voyage with the new motor pulling our new camper, went great. I put 156mi on the truck driving it around before I took my new 5000lb camper we built 220mi round trip for the weekend. I need to get a bit of transmission tuning changes, just to get it to rev out a bit more under normal acceleration. Over all pulls very nice, and boy does it have some balls!!! Rolled into it leaving a stop sign and started to spin 2nd gear with a 1000lb tong weight. Fuel economy was only a bit more than with the old motor with the old trailer.
#2344 |
Re: My 52 GMC Build
![]() it's really hard to get better MPG while doing trailer burnouts ![]() |
#2345 |
Re: My 52 GMC Build
Glad to hear it went well. What kind of MPG are we talking?
#2346 |
Re: My 52 GMC Build
congrats on the first trip
amazing build, well done.........Swap Meet at Rockton this weekend?
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
#2347 | |
Re: My 52 GMC Build
Yes it does not help lol But who cares.
Thank you. No can't make that one but I will be a Unfinished Nationals June 4
#2348 |
Re: My 52 GMC Build
2000km/1200mi so far, runs great and pulls like a freight train. Got a new trailer tune all set up and is perfect for my set up, holds the gear a little longer during acceleration and less fuel (almost no smoke). All the temperatures stay right where they should with or without the trailer. I'll start to play with the higher power tunes at the end of July and get it on the dyno as my friend and I are driving 9hrs to CampNdrag middle of July. In my level 3 tune (daily tune) it can spin all 4 tires shifting into 3rd at 35psi of boost and puts you in your seat.
My first official burnout, got to 3rd gear 150' long letting off.
#2349 |
Re: My 52 GMC Build
Nice burnout! Glad it's doing what it is supposed to.
#2350 |
Re: My 52 GMC Build
Very cool. I have thought about Camp N Drag but it is the weekend after GoodGuys Columbus. It's hard to do 2 back to back show weekends.
Marc
Tags |
bagged, build, diesel, gmc, hot rod |
