Old 05-03-2023, 04:23 PM   #1
slammed48
slammed48's Avatar
Hooker exhaust manifolds (will they fit?)
Has anyone tried to fit the Hooker exhaust manifolds on a 73-87 sbc with factory engine mounts?
I'm hesitant to order them before confirming.
The part number is 8525HKR and here's a picture for reference of the ones I'm referring to. Thanks
slammed48 is offline   Reply With Quote
Old 05-03-2023, 06:38 PM   #2
Dead Parrot
Re: Hooker exhaust manifolds (will they fit?)
They fit on mine. 75 C10, 350/TH350. Stock mounts. Bought a set after seeing them mentioned in a different thread on this forum. They replaced a set of worn headers. I was tired of leaks.
I went with the uncoated version. They have ceramic coated version but the break in instructions mention a requirement for several short (less then 5 minutes) runs. I live about 40 minutes from the exhaust shop that did the tie in from the new manifolds to the existing exhaust pipes that were still in good shape.
Dead Parrot is offline   Reply With Quote
Old 05-04-2023, 06:48 PM   #3
cadillac_al
I think they look pretty nice.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-05-2023, 06:43 AM   #4
rick1956
rick1956's Avatar
A friend of mine is putting them on a truck build, and after seeing them, was pretty impressed. I was most concerned about the 2-bolt flange, but those flanges are big and beefy. I think Hooker did a nice job on em. I'll be replacing the crappy headers the PO installed on my truck pretty soon I think.
I may be old, but I still enjoy the feeling
of the earth rotating beneath my wheels...
rick1956 is offline   Reply With Quote
Old 05-06-2023, 07:32 AM   #5
kipps
What's the concern with 2-bolt flanges? Cracking, or leaking?
I'm installing OEM 2010 Camaro manifolds on a LS-build of mine, and they come with 2-bolt flanges as well. I just wondered if there's more that I need to watch out for than I thought.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 05-06-2023, 09:37 PM   #6
rick1956
rick1956's Avatar
The concern was basically 'one less fastener'. I'm used to seeing manifold collectors be tri-way instead of only two fasteners. It was just different, and you know how people are with change...
Old 05-07-2023, 12:20 AM   #7
Dead Parrot
Had a decent day for outdoor pictures. Installed on my 75 C10 with 350/TH350. Easily clears both motor mounts and frame. Like others have mentioned, the 2 bolt connection did cause some worry but I have seen several OEM setups using 2 bolts. Good time to check all of your exhaust hangers if you are reusing much of the existing system.
Old 05-07-2023, 08:27 AM   #8
cadillac_al
Do they need custom pipes to connect to them or will stock exhaust pipes work and just change the flanges?
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 05-07-2023, 01:22 PM   #9
Dead Parrot
The pair of included flanges are setup for 2.5" pipes to be welded to the flange. The flange + pipe then bolts to the manifold and is sealed with a flat gasket. In my case, since I was switching from headers, it needed about a foot of pipe on one side and about three feet on the other. The shop charged just over $100 for the job. My existing pipes are 2.25" and were in good shape despite being 25 years old.
Old 05-07-2023, 02:03 PM   #10
LDO
LDO's Avatar
Those look nice. Can you use heat sheilds with them?
LDO is offline   Reply With Quote
Old 05-07-2023, 10:35 PM   #11
Dead Parrot
If you are talking about the OEM shields, don't know. Those vanished when I put on the headers back in the mid 90's.
Old 05-10-2023, 04:05 PM   #12
Android04
Android04's Avatar
Yes sir we are running them on two square bodies in our fleet.
Android04 is offline   Reply With Quote
Old 05-12-2023, 07:16 AM   #13
rick1956
rick1956's Avatar
Bought myself a set yesterday. I included these header pipes with mine--overpriced or not. I just want good mating flanges... the exhaust shop can take it from there.
Old 05-12-2023, 11:17 AM   #14
cadillac_al
They don't look like they have enough bend for that manifold that exits straight down. Are they made for these manifolds?
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 05-13-2023, 11:36 AM   #15
rick1956
rick1956's Avatar
Yup, the flanges exit the manifolds at angles... they're made for em. I'll let you know how they fit when it's all said and done!
Old 05-21-2023, 07:53 PM   #16
slammed48
slammed48's Avatar
Thanks everyone! I finally received my back ordered pair of these manifolds (Haven’t even opened the box yet).
And Rick1956, that would be great to hear how those pipes work out for you and, if you don’t mind sharing where you bought them.
Old 05-21-2023, 08:23 PM   #17
Dead Parrot
Three pics of the pipes the exhaust shop made for my switch from old headers to the Hooker manifolds. The 90 degree bend continues as the longer pipe in the pic with both. The blurry one is the end of the new passenger side pipe.
Old 05-22-2023, 09:14 AM   #18
rick1956
rick1956's Avatar
Bought mine at Supershops. I still haven't received the manifolds yet, but that doesn't surprise me--everyone seems to have a waiting list for them. Good price on t-shirts at Supershops too btw... haha
Old 05-30-2023, 07:09 PM   #19
slammed48
slammed48's Avatar
Rick1956- any chance you have a link to those header pipes? I couldn’t find them on the site.
I got my hooker manifolds and they do, as others have said, look like they’re gonna fit, so I painted them with the Eastwood exhaust coating today…
Old 06-19-2023, 10:57 AM   #20
rick1956
rick1956's Avatar
Well, I finally got all my parts and was able to play with the fit. My assessment: the head pipes I mentioned do not fit.
The good news is, the quality of materials is excellent in them, so rather than send them back I am going to customize (butcher) them and use them anyway. The flanges look too nice to pass up.
Time to get the welder out!
Old 06-19-2023, 06:57 PM   #21
cadillac_al
Can't you get them bent a little more?
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 06-26-2023, 09:40 PM   #22
rick1956
rick1956's Avatar
I finally finished 3 days worth of cutting, fitting, and welding after putting my new manifolds in. The fit on the manifolds is phenomenal (but as everyone knows, exhaust work is always 'one thing leads to another' etc). Lots of room on all sides, perfect bolt placement and sizing, and plenty of room for spark plug access--possibly even slightly better than stock. They're beefy and heavy too. I smeared Calyx all over them to keep them from looking like a saltwater attack the first time it rains.
I ended up buying Hooker headpipes to ensure a good fit with the manifolds, but as I stated earlier, they did not fit. They did, however, furnish me with perfect, beautiful flanges to use after a little butchery. It felt somehow sacrilegious cutting them up but I figured, if Hooker sold only the flanges with a short length of straight pipe on them they'd probably be over a hundred bucks anyway. So, a shoulder-shrug later I had the saw out.
I opted for an H-pipe and the longer Magnamufflers to keep everything quiet. The current sizing is 2 1/2" all the way to the rear of the mufflers, where I tied into the 2 1/4" OEM tailpipe. I'm really happy with the sound!
Old 07-18-2023, 01:10 PM   #23
slammed48
slammed48's Avatar
Nice! It’s helpful to know the head pipes aren’t gonna work as is, so I can plan accordingly.
I’ve finally terminated my plug wire ends. I’m happy with it.
I coated my manifolds with Eastwood exhaust coating.
The only gripe I have regarding the manifolds so far is that one of the bolt heads would not fit without me grinding the manifold slightly.
Old 07-19-2023, 12:00 AM   #24
SunSoaked
SunSoaked's Avatar
Been running them for a good 6 months now. I got the black ceramic ones. Built a new y+pipe, magnaflo high flow converter and muffler on a single 3 inch exhaust. System turned out excellent with the exception of the lousy POR 15 hi-temp paint.
SunSoaked is offline   Reply With Quote
Old 10-14-2023, 07:43 PM   #25
slammed48
slammed48's Avatar
awesome! I still haven't had a chance to do the rest of the exhaust on mine. My goal is to quieten it as much as possible, and I've considered running a catalytic converter and single exhaust as well, but obviously it's easier to just run two pipes out the back than the y pipe.
No chance you have a sound clip of it running, huh?
