Factory Rally Wheel Trim Rings - What metal are they made of?
Hey guys,
I finally got my hands on a nice set of GM 15x8 Rally Wheels. The trim rings that came with them have a few deeper scratches that I want to try and sand out a bit before polishing them. What kind of metal are they made of? They don't appear to be chrome so I'm hoping I can sand the metal a bit then buff. Anyone have any other advice on sanding out scratches on rings? Here's a pic with the truck with the bare steelies on it. Stock height, 235/70 tires on them for now
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
![]() Join Date: Dec 2009
Re: Factory Rally Wheel Trim Rings - What metal are they made of?
Some trim rings are Stainless Steel.
If a magnet won't stick to them, they are the good ones ![]() Some Stainless ones are slightly magnetic thou. Do they have any signs of rust in the scratches?
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
I just checked the 2 known oem stainless rings i have, and a high-strength magnet barely sticks to them. There are absolutely no identifying marks on the back side that identify them as stainless, or even a part number that i could see.
#4 | |
I assume they must be stainless, maybe the little bit of rust a polished off was more surface crud than the metal rusting?
There are several videos on U tube of how to sand a polish them.
Probably better than how I would Type it ![]() Yeah Without getting into Metallurgy, ![]() Different Series of Stainless has some Ferrous materials in it. ![]()
I found a decent set on a 90's Chevy van. Shallow compared to what you have but looks to
Be more original..IMO.
Stainless steel has varying degrees of nickel content, depending on the SS rating. Nickel is magnetic.
Ahh, that makes sense why it would be just a little bit magnetic! Interesting
Who Changed This?
![]() Join Date: Jan 2013
Nickel is ferromagnetic, just like iron. 300 stainless has a high chromium content which is why it doesn't corrode beyond a surface layer. And the chromium is what makes it have a very low magnetic moment (magnet sticks only very slightly). 400 series has low chrome content and is ferromagnetic.
#10 | |
This one here looks pretty good. Just searched for "stainless trim ring sanding" on YT... https://www.youtube.com/watch?v=J5vz0aLidCs -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
![]() Join Date: Dec 2013
They are stainless . Not everyone has a stand mounted buffing wheel . Harbor freight has green polishing compond and small buffing wheels to use in a angle grinder , scratches can be fixe using 400-800 grit wet/dry sand paper and then buffing . The trick to buffing stainless is high speed and heat built up from pressure . There are pictures in this thread .
![]() https://67-72chevytrucks.com/vboard/...d.php?t=765868
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#13 | |||
I Know this is a touchy subject for some ![]() Quote:
![]() Quote:
![]() Go to Harbor Freight ![]() ![]() ![]()
#14 | |
Who Changed This?
#15 |
Thanks guys, that video was exactly what I was trying to find! Should be a fun project, a lot of work but moving through all the grits should pay off
#16 |
Okay
![]() I speak for all of us that had Input ![]() We would like to See Before and After Pictures. ![]() In my experience as a Machinist, Stainless is Difficult to machine ![]() With that being said., ![]() It is also Easy to cover up (Some /not All) a Boo Boo's with fine grit sandpaper or scotchbrite. ![]()
